Question about Faema FA60081
My faema x1 says "push cleaning button" but after i push it nothing happendsand i have same message again
Where do I find a Faema Smart A2 replacement touch pad? The left push panel is not working and the guy fixing it wants me to order a new one but I can't find a matching part anywhere on the internet.
You're looking for part number 3301135601. I've come across a few Smarts with Due front panels - so measure your keypad: if it's 68x58mm you need a Due version instead.
Feb 09, 2015 | Faema Smart A2 Automatic Espresso Machine...
I have a Faema Due espresso machine and I need to know about the correct use of the red cup symbols over the heads. Can you help please.
Faema Due depending on the model semi or auto has either 6 buttons for auto and any where from 1 to 2 for semi. There are 2 short level cups single and double and 2 long level cups. They are for ristretto or restricted and lungo or long, but if you only use 2 ounce or 3 ounce shots depending on your preference. I usually set all buttons to shop preference because in the US most shops either do 2oz or 3oz espresso shots. The cup with the dots above it is continuous run and ofcourse the stop is... On the semi you have one cup and stop or a push button.
Mar 23, 2013 | Faema Coffee Makers & Espresso Machines
I have a faema x1 grandaitalia machine , the water coming out of the boiler is only getting to 33 deg can you send me or a diagram of hot water system thanks or tell me what to fix problem
Ope you mean from hot water spout if so several problems exsist as this machine has a cold mix system to bring the roughly 120c water from boiler down to roughly 94c to use for americano. check spout and descale hot water nozzle or see if any black/brown particals in defuser(fine mesh in spout)as boiler pressure is roughly 1.3/1.4bar and mains water is roughly 2/4bar thus cold water will win if black brown particals in mesh poosible boiler contamination causing restriction to which once again cold water will win. question did any one take any pipes apart about 5 months ago????? as there are restrictors within the system.
Aug 15, 2012 | Faema Coffee Makers & Espresso Machines
Nothing happens when I push starter button. Oil light only is on and headlight seems bright.
Is the clutch pulled in? Is the kill switch put in the run position? Both of these things will do that - of course you might just have a bad starter button too...
Apr 28, 2011 | 2001 Buell X1 lightning
I have a faema no stop 2 head espresso machine from 1983. how do i start the machine?
Just turn on the main on/off switch wait about 20-30 min. for the machine to get up to temperature once is ready you can use it.
To make an espresso, put the espresso in the warm portafilter and push the down oce is ready push it back up.
If you need more details, Let me know
Jan 13, 2011 | Faema FA60081
Hi need to know the program system for a faema smart 2 group
Press the stop button and the button you are programing together, then keep them held down until you get your level then release.
Feb 20, 2010 | Faema Coffee Makers & Espresso Machines
Espresso water is dripping not streaming
Try replacing the brew solenoid on the grouphead. Its the black or blue electrical box assembly connected to the side of the group.
Apr 17, 2009 | Coffee Makers & Espresso Machines
My screen has cracked on my Sony Ericsson W890i phone.
COPY CONTACTS TO SIM CARD SEQUENCE W890i
press contact button (the one above and to the left off the red call end button) x1.
Press options button (the one above and to the right of the green call button) x1
Press menu up arrow x1
Press select button (silver button in centre of joystick) x1
Press select button x1
Press menu up arrow x4
this will copy your contacts to your sim card.
Not sure re texts
Feb 25, 2009 | Sony Ericsson W890i Cellular Phone
Coffee Makers & Espresso Machines Logo
118 people viewed this question
Top Faema Coffee Makers & Espresso Machines Experts
richie46
ray gallant
Are you a Faema Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
