Question about HP Pavilion dv6000z PC Notebook
Can not connect with my home computer.Router and modem working,just won,t connect
    Genius:
  • HP Master
  • 1,354 Answers
Configure the Router 1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
Posted on May 14, 2010
My modem and router won't work simultaneously
They chain together. Connect the modem first to the ISP drop. Then the modem to the routers main port. Then the connect the PC to the router.
Modem > Router > PC
Jan 09, 2013 | EnGenius Technologies ESR-9752 300mbps...
New modem installed and router won't work now
First step is to make sure if the modem is working. Connect your computer directly to modem with ethernet cable and see if you can log on to internet! if yes
next step connect modem to your router's WAN port with an ethernet cable and then connect your computer to one of the LAN ports of router with ethernet cable. Power down all devices and power up modem first wait until all lights are on and then router wait until all lights are on then your computer! 9 out of 10 times this works! try good luck!!
Sep 23, 2011 | Dynex 4-Port Ethernet Broadband Router...
Electricity went out in my home and now my computer will not connect to the internet. I checked with my internet server and the problem appears to be with the router. I have a D Link N150 home router. Can...
Ok...the first thing to try is to power everything down....modem, router, and PC.
Then power them back on in this order: Modem (wait for lights to go solid) then Router (again wait for solid lights) and then PC.
I am assuming you are trying to connect wirelessly. So if it's not working on wifi, try it plugged in using an ethernet cable. Make sure that the connection from your provider comes from the wall to your modem, then from your modem to router, and from the router to your PC.
If you can't get a connection wired, take the router out of the mix. Plug your PC directly into the modem. (rebooting them both in the same order that I mentioned above.)
If it works with the modem, then the problem is with your router. You may need to press the reset button for 30 seconds or so and start over with a fresh configuration. If the modem connection does NOT work, you may want to get on the phone with your providers support team to check the connection coming to your house.
May 17, 2011 | D-Link Wireless N 150 Home Router 4Port...
Toshiba Satellite A135 S4527. Will not connect to internet through home wireless router. Was not a problem until recently and no changes to home wirelss router. Computer will connect to all other wireless...
Power down router and modem.
Wait for 30sec.
Power up modem wait about 5 min.
if modem is powered then power router.
wait for 2 min.
than power up computers.
if not yet Internet choose repair connection.
Jan 13, 2011 | Computers & Internet
I do know if im supposed to connect my router to my modem in order to get an internet connection on both computers in my home
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Oct 24, 2010 | Dynex Computers & Internet
My F5D7234 is not working w/ Windows 7. Watsup?
Is your modem connected to the main computer or the router ?
If the main computer is connected to the computer then you will need to connect the modem to the router .
Check the connections.
check the settings on the router.
I hoe the following link will help you.
Nov 09, 2009 | Belkin F5D7234-4 Router
Can you help me set up my home computer my time warner modem n vonage modem with my belkin router?
So you are trying to set up the router.
you can connect the router to the modem and the computer to the router.
Set up your router properly sothat your computer can go online through the router.
Pnce your computer is online through the router, then connect the Vonage to the router and it should work.
First make sure that your computer will be able to go online when connected directly to the Time Warner cable modem.
Click Here for step by step solution on how to set up router.
Nov 04, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Need to connect another tower to the 2 wire modem to work fr home
To connect more than one computer to this 2wire you will need to buy an access point (or a router, either one will do). Since the 2-wire is a modem and a router, it can support more than one computer. However, the 2-wire only has one Ethernet slot to support one computer. This is why we need an access point or a router as this will give you more Ethernet slots allowing you to connect more computers to the same Internet connection.
Jan 19, 2009 | 2wire HomePortal 100W (1000-400026-000)...
Wanting wireless hookup
1)Prepare your modem. Unplug the modem's power cord and place the wireless router unit next to the modem. If the router has antennas, make sure they are raised to their full upright position.
2)Reassign your networking cable. Unplug the cable currently connected from your computer to your modem and plug it into the port located in the wireless router. This port is usually colored blue.
3)Connect the router and the modem. Use the networking cable that came with your wireless router to connect the modem and router unit. The router port is typically colored in green.
4)Start up your modem. Plug in the modem's power cord and wait 1-2 minutes while it configures its settings and prepares to connect to the Internet.5
5)Start up the wireless router. Plug the wireless router's power cord into an outlet and wait 1-2 minutes to get it started. The router is ready when the 'wired computers' and 'modem' icons light up. These logos or icons vary by make and model of your router so consult the owner's manual if needed.6
6)Insert your installation CD. Use the wizard or assistant to check the configurations of your computer settings and launch your wirelessnetwork clip_image001.gif
Things You’ll Need:
  • Wireless Router unit
  • Networking cable (comes with router unit)
  • Installation CD
  • Modem
  • Modem power cord
Dec 02, 2008 | D-Link DI 713p (DI-713P) Wireless Router
HP Pavilion dv6000z PC Notebook Logo
117 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
