Question about Frigidaire FRS26ZSG
Warm Fridge Sorry bout that. It's FRS20ZRGD7
    President:
  • 1,314 Answers
Look open the freezer door pull the lower kick plate off look for a small little hole there its a mechanical timer model should be close to the wheel in that hole will be a plastic piece open the freezer door you will hear the fan running in the freezer take out the four or five screws on the lower panel where you keep seeing the frost and remove it you will see a silver honeycomb looking piece that's the evaporator on one of the tubes will be clipped a silver dome looking piece with two wires on it that's the defrost thermostat now turn the timer with a screwdriver that's the piece in the little hole slowly to your right till you hear a click and the fan stops in the freezer now as your turning it it will make a ratchet sound you want the click and the fan to stop look at your watch and note the time then wait about 5 minutes and look at the heater to see if its on if its all frosted up the frosted should look all watery if the heater is on then just let it run if not then reach up and turn the freezer control to the off position then un plug the two wires on the defrost thermostat and take the two wires that you unplugged the thermostat from and plug them back together and turn the freezer control back on and wait stay there and watch the heater come on let it defrost the evaporator if the heater comes on when you do that .that means the thermostat is bad if the heater comes on without you having to by pass it that means the timer is bad if you do all that and the heater does not come on then the heater element is bad now its going to get red like an oven and pop and sizzle but don't let it freak you out now if you had to by pass the thermostat and the timer cuts the compressor on before the frost is all clear just turn the timer around again till the fan cuts off and the heater will come back on if you by passed the thermostat then when all the frost is melted then reach up and turn the freezer control back off and reconnect the thermostat.Now after about 30 mins after turning it off the timer should cut back on if its not bad when you change the timer back out the two screws reach under the fridge and turn the timer and its shield till the screws are in the removal position when the timer is loose remove the shield and unplug the timer plug your new one back in then put the shield back on and back where it goes now id recommend changing both the timer and the thermostat as they fail pretty close together the stuff i described above is to make the unit defrost to save your food with out having to use your hair dryer also when all the frost is melted at he bottom of the evaporator on the right hand side is a hole in the cabinet that has to be clear of frost for the fridge to cool properly now any time during this defrost technique if you have a problem turning off the freezer cold control will turn off the defrost systemWarm Fridge - 1.gif too if i can be of help or you need to know something just reply to this post
Posted on Mar 30, 2008
I have a kenmore bottom freezer refrigerator model # 795.78304.804 bout 10are11years old just stopped working nothing will come on . checked power at box and it's good
main switch/thermostat control inside of fridge needs replacing...to prove...tap/bump switch a couple of times and you should hear fridge power up...if so replace switch/thermostat...
Oct 16, 2016 | Kenmore Refrigerators
My 2004 dodge Durango a/c don't work well it blows out air Luke warm air I put it in cold buts it still blows out Luke warm please help I'm bout to take a trip the texas
hi sorry about your troubles . start by popping your hood and listen to your ac compressor and see if it cycles on and off if it doesnt more than likely you have a leak and are low on refrigerant and or have a power issue check all your fuses make sure none of them are blown
Jul 31, 2015 | Dodge Cars & Trucks
Why does our Smeg fridge drip water internally and externally all the time?
It may have a loose connection on the water/ice maker. It would be best to have a serviceman check it out.
Sep 20, 2014 | Smeg Refrigerators
Gsc3pgxcfss warm fridge, freezer working fine
It could be the servo on the diverter door, but it's most likely to be the main control board. Sorry.
Mar 23, 2014 | GE Refrigerators
Fridge admiral ac2224gekb stopped working
1 this is not compressor because it's starting and it's not starting realy because is part of compressor.
2 You my have problem mainboard or temperature sensor name of part thermistor work like(thermostat) cost less then mainboard
Nov 02, 2013 | Admiral 26 cu. ft. Side-By-Side...
Samsung fridge warm
check the rubber on doors,if they are good.but you need to let check the liquid
Jul 26, 2012 | Samsung Refrigerators
In the fridge i have there is a hole for water to drain just above the draw it keeps freezing every couple of days then water builds up under the draw and leaks out i clean it so the hole is free frm ice...
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Frigidaire Refrigerators
Westinghouse Upside down Fridge Freezer Model #BJ504T-R5. Fridge will not go cold, cannot have a a Cold Beer out of it. Any suggestions on how to fix this problem? Freezer works OK
put the beer in the freezer for 30 mins,that should cool it nicely.....
oh, the fridge aint working, sorry,poss the thermostat or (still thinking about drinking warm beer, ugh...)have you tried cleaning the vents...
Aug 18, 2010 | Refrigerators
Freezer cold, not fridge
24 hours It should be good Do check temp settings.
Aug 05, 2009 | Candy CPCA240FFK Bottom Freezer...
Frigadaire freezer cold but fridge compartment is warm
i need the complete model number to narrow it down they still make the frs20zrg to this day the last two numbers like frs20zrgwo or frs20zrgw9 is what will tell me what kind of defrost system it has the serial plate is in the fridge side up by the light bulb or on the left hand side or right hand side of the fridge compartment up near the top sorry to be a bother but its necessary
Mar 30, 2008 | Frigidaire FRS26ZSG
Refrigerators Logo
117 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
