Question about Refrigerators
My fridge freezer plug got wet and now doesnt work is it because it needs drying thoroughly. only its been two hours and ive tried using ahair drier on the plug
5 Suggested Answers
philbran
  • 242 Answers
SOURCE: Fridge on Fridge freezer not working
Ok there is a drain pan under the evap. coil under the fan that may be clogged and full of ice there is a 3/4" hole the water drains out of that needs cleared if there is a puddle of ice over it , the ice will also effect the airflow traveling down the duct to the fresh food section of the unit.
If there is no ice puddle at the bottom of the refrigerator then make sure the unit is cooling well by making sure it has been running for 10 min. or so and checking the coil in the freezer , it should have a small layer of frost on it showing its getting cold the whole way through it. Let me know how this works.
Phil
Posted on Jan 02, 2009
  • 122 Answers
SOURCE: Fridge got wet, now it sparks and shorts power
It sounds like the thermocouple is either faulty or incorrectly installed. In other words the sensor bulb may be very slightly to far away from the flame to get sufficient temperature to keep the gas flowing. This is a safety device to cut off gas supply should the flame blow out. But if you are parked at a bit of an angle, the flame will also angle away from the sensor, causing it to shut off gas supply. With regards the freezer being temperamental, this is a strange one, because on this model of fridge/freezer, the actual cooling starts from the freezer coil and ends in the fridge. Try to check the thermocouple first. Also be sure there is nothing obstructing the flame
Posted on Apr 15, 2009
rylee_smith
  • 8619 Answers
SOURCE: all items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 30, 2009
SOURCE: Fridge doesnt work, freezer works
You need to change the freezer fan motor. FF means problem with the Freezer Fan.
Posted on Oct 19, 2009
Fridge freezer
HI jACQUELINE.well i reckon the fridges r a bit temperaMENTAL.:).Before u do anything well u can check weather u have ice build up on the rear panel inside freezer compartment.either way i would first turn it off for 24 to 48 hours.then remove bottom plinth panel (bellow the door).thoroughly clean condenser coils right to the end.then try u could get lucky.if it doesnt work then the problem could b inside the panel.def/heater,fan motor,t/stat,or the board.good luck Ali
Aug 24, 2012 | Refrigerators
My phone got wet just a little bit and ive tried drying it with a blow dryer and taking the battery out and stting it alone.what do i do? i only touched it while my hand was a little wet
the blow drier was a bad idea, any time electornices get wet, you should power them off if not already done so, then take them apart (battery and any other parts that are not going to ruin warrenty) and then just sit them out and let them dry naturaly, the heat from a drier could damage components, do not attempt to re power the device until you 100% know that it is dry on the inside to prevent short circuting
Apr 20, 2011 | Cell Phones
I have a Kenmore Elite refrigerator model number 59673503201 and there is a terrible fish smell coming from the bottom portion of the appliance where the freezer is. It is not coming from trash, or food...
Please note when you keep fish in freezer once, the smell will be longer even you remove it. O.K. Now solution for your problem- Please unplug power.Keep fridge door open. Take wet cloth dipped in soap water and clean all compartment including freezer . Keep freezer door also opened.Then clean with dry cloth. Spray room spray in your room not into the fridge. And allow 5 hrs to circulate fresh air to pass thr' your fridge and then close fridge and freezer doors. Plug fridge and run for one hour on empty. After one hour store items in fridge and/or freezer.
Keep all food items in closed style which will avoid odor spreading and also be a hygienic. Thanks.
Jan 30, 2011 | Refrigerators
The freezer part of my refrigerator started to have an odor around the holidays. Since then, we have cleaned it several times. The smell/odor still exist quite strongly in the freezer section. It is not...
Hope you would have cleaned fridge and started using immediately. Don't do it.
Power off. Takeslightly wet cloth (dipped in soap water) andclean all portion.And after 5 minutes clean with dry cloth. Keep fridge door opened for minimum 6 hours to allow fresh air passing into fridge compartment. And then place foodsin airtight containers to prevent the transfer of odors. Now close fridge door and plug power.
Hope, it's helpful.
Jan 29, 2011 | Kenmore 63074 Top Freezer Refrigerator
Hi I have a fridgemaster mftr280r and it doesnt seem that cold in the fridge,the freezer is a bit over-iced and needs a defrost.Will this help the fridge from becoming cold??
whatever,it cant not help,as long as you do a COMPLETE defrost(leave it for at least 24 hours.then dry out thoroughly.clean any drains/vents then restart as new.let it settle for at least 24 hours then check/refill.fridge is +5C...freezer is -18C,optimum temps...
Nov 01, 2010 | Refrigerators
The freezer is cool but not frozen
u'r defrost time clock needs replacing if u have a defrost refrig , u'r fridge is psobably warm as wellOR u do have a freon problem OR COMPRESSOR loosing capacity , it doesnt seem good for u :(
if its a defrost problem the freezer will be all frozen up and the fridge will be not cold
Oct 16, 2010 | Samsung Refrigerators
I was chiping ice from my danby fridge freezer section, and chipped a notch out if the freexer, and now its leaking something that smeels bad, and the fridge now does not get cold and the freezer doesnt...
guess who is going to buy a new unit....NEVER USE ANY HARD/SHARP OBJECT TO AID A QUICK DEFROST.use only car deicer,then wash out with clorine bleach then dry thoroughly.
the cost of repair/recharge/callout, is going to be nearly the cost of new.
Aug 25, 2010 | Danby DCR412SS Stainless Steel Compact...
Liebherr frost free fridge/freezer
Try these solutions in these order:
1. Switch off the fridge and leave the door open overnight. Switch it back on in the morning.
Explanation: The sensor inside the fridge gets frozen and cannot control the temperature properly.
2. Switch off the fridge. Unplug it. At the back of the fridge (behind the unit, not inside) there is a large grid. Clean it with a hoover thoroughly. Open the fridge. Dry the back of the fridge if wet (inside the fridge). If frosted wait for it to defrost and then dry it. Plug in the fridge. Switch the fridge back on. This one worked for me.
Explanation: The dust in the grid deprives the fridge from cooling down and the unit can't control the temperature in the fridge section.
3. Switch off the fridge. -Unplug it. Empty it. Turn it upside down. Plug it in. Switch it on for 24 hours. Switch it off. Unplug, return to normal and switch on.
Explanation: This has to do with the pressure of the gas inside the compressor. I have not tried it but this advice as given to me by a qualified electrician when I commented the (in)famous F2 problem in Liebherr fridge/freezers.
Hope it helps. Regards. Albert
Sep 07, 2008 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Fridge problem
you have a defrostion issue reed to remove the back panel in the freezer behind this panel is the evaperator coil needs to be melted down because it is full of ice and frost, ahair drier will work well,put several towells down under the bottom of the evaperator to catch water runoff, after defrosting the coil inspect the defrost heater or heaters some of these can have one or two heaters the heaters are located behind metal gaurds in the evaperator if either of the heaters are bad (both)need to be replaced, if they show good then bad defrost timer or bad defrost termination thermastat wiring diagram behind frount bottom grill
Apr 12, 2008 | Refrigerators
Refrigerators Logo
120 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
