Question about Panasonic TC-32LX60 32 in. LCD Television
Panasonic TC-32LX600 red blinking power light
This is actually a TC-32LX600, same as 60 but a little more expensive. Bought it 13months ago, so it's just out of warranty. Last night TV shut off off while watching a DVD, power light was blinking red and tv would not respond to the remote. I shut off the surge protector for about 2 minutes, and when I turned the surge protector back on I was able to turn TV on. It seems ok now. Is this an indication that there is a fan problem, a bulb problem, or something else?
  • Caterina Apr 16, 2008
    I also have a TC-32LX60 and had not watched tv for about 1 wk. Tonite the tv would not power on, the red light kept flashing. 2 flashes, pause and repeat.
    I also have a power surge cord and shut it off, waited the 2 min and now it is working again.
    Thanks for your tip.
    Caterina
  • bucketnut Jul 31, 2008
    Turns itself off after about half hour. I unplug and wait for a while, works fine. Then does it again
SOURCE:
djchillsnyc
  • 152 Answers
SOURCE: red light blinks 9 times on Panasonic TH-42PZ77U
hello, panasonic plasmas have a safety shut down circut to protect the main panel when a short is present or internal circut panel is non functional some info i found in the service manual for 10th generation plasma
if your tv is still under warantee take advantage of the pany free service other wise it is a matter of exchanging the defective board then you will need electronic skills for this repair if you plan to do it yourself. it would be wise to have a skilled tech check it out and give you a estimate there are some techs that will come out and check it for free and give you a repair price.
here are some repair manual tips for blinking panasonic .. i didnt find 9 blinks on this manual i may be using a different manual but these are panasonic plasma blinking fault tips for 10th gen
becuase all models have different blinking codes you may need the model specific service manual
for 10th gen model some models 2008,2007,
8 Blinks SOS:
Pin 91 of the MPU IC9003 monitors the status of the SS board. During normal operation, pin 8 of connector SS23 outputs a low to pin 91. If the SS board becomes defective, a high is provided to pin 91. As a result, the unit shuts down and the power LED blinks 8 times.
9 blinks panel config sos
10 Blinks SOS:
The SUB5V and DT9V sources created on the A board are monitored by IC1100. If they are not present at pin 30 and 34, the MPU shuts down the unit. The power LED blinks 10 times.
10 Blinks SOS:
The F_STB_15V of the P board, as well as the derived SUB5V and DT9V sources are monitored on the A board for excessive current. If a short circuit is developed in one of the supplied lines, pin 114 of IC1100 receives a high. The SUB5V and DT9V lines are also monitored for excessive voltage. When an over-voltage condition is detected, a high is also output to pin 114 of IC1100. The DT9V is provided to a DC/DC converter to create the BT30V for the tuner. If the BT30V becomes excessive, a high is output to pin 114 of IC1100. A high at pin 114 of IC1100 causes the unit to shutdown and the power LED to blink 10 times.
hope this helps..
Posted on Dec 09, 2008
SOURCE: My TV TC-32lx600 have a
if this is under warranty u can request service technician to reset it. from where u buy it. dont do anything if you dont know any mistakes will avoid your warranty. or tell them to guide you by phone etc.
Posted on Jun 02, 2011
  • 104 Answers
SOURCE: I had to unplug my
There should be a surge release button on the surge protector to bring the protector back to normal (should be red in color) Some surge protection devices have this option so just check if your s has it. If that is not the case than I think that you might have blown a fuse in your TV.Might just have to open it up and change the fuse within with the same ratings, but please be careful because do have high voltages so get an experienced technician to do this for you.
Good Luck.
G.
Posted on Jun 29, 2011
Prof  Henry
  • 209 Answers
SOURCE: I have the Panasonic Viera
Press the power button on the remote if it does not come up then you return it for replacement.
Posted on Aug 11, 2011
  • 8457 Answers
SOURCE: panasonic viera TC-P50G15 tv cut
Tries tv unplug,replug it back like about an hour later,for the tv to a resetting itself back to the factory setting.The tv might work again,if not the tv power supply board is the problems and the causes.The tv power supply board it is shorted and dead some how.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Posted on Sep 22, 2011
Received for Christmas 2010. Worked great! Few nights ago, made something to eat, and it shut off. Light, clock, everything. After a few minutes, it came back on. Used it last night, same thing. But this...
The joys of purchasing items with a bought out warranty. Check the plug and contacts on the fuse.
You could either call a microwave repairer and pay for callout and repair or purchase a new one.
May 30, 2017 | Oster OGG61403 Microwave Oven
I have Sony Bravia X Series 46" Full HD. The Picture froze during a TV show last night. After that it says it cant pick up anything from any channell. It works if you just play DVD's. I've tried...
you will have to check the terms of the warranty, you might have to bring it to where you bought it. Also, if its to expensive, for the age of the unit, you might end up with a new tv.
Mar 13, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Toshiba 46RV525U are JUNK!
The LCD panel is defective. They are expensive. Call customer service and they may extend the warranty for you if you complain enough.
May 27, 2010 | Toshiba Regza 46RV525U 46 in. LCD HDTV
I bought my plasma tv over 1 year ago but only set
it's a defect. we call it red blinking death. the boards inside the tv has gone bad.
Oct 17, 2009 | Panasonic TH-50PX75U Plasma HDTV
Hi i bought LG plasma model no RT-42PX11 2 years
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Aug 02, 2009 | Televison & Video
Insignia TV is only showing 1/2 picture
You are having problems with component failure. This could be a simple problem of over expanded solder connections that have expanded beyond the contact points on the board. This is reffered to as cold or broken solder joints. The other problem amy be actual component failure, such as bad capacitors or semi-conductor components. The unit need to serviced. You can call the Best Buy customer support telephone line at 1888-237-8289 and give them the model number of your television and the problem you are having. They should be able to give you a evalution and esimate of the repair costs. I hope this information helps you with your problem.
May 09, 2009 | Insignia IS-LCDTV32 32 in. Television
Tv shuts itself off
pls check the a.c. cord is good,then check fuse of the unit if deffective need to replace it and check the horizontal output if is good or not.
Jan 11, 2009 | Sanyo DS27510 27" TV
Panasonic TC-32LX60 32 in. LCD Television Logo
396 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
