Question about Lexmark C534N Printer
I keep getting a paper jam with message check fuser. Even after I clear it, it just keeps jammimng the paper when it's about to finish feeding it.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 108 Answers
On most laser printer fusers there is a black exit switch to detect paper exit. Look for a thin black finger that would be in the middle of where the paper exits. If the paper is stopping as it is coming out of the printer it sounds like the switch broken off. Or popped out of place.
Posted on May 14, 2010
Minolta di350 jam at fuser
IF you can find a fuser. The Di 350 is a legacy Minolta, now Konica Minolta. mite be able to find refurbished unit. If accordion check to make sure the pick fingers are not broken they prevent paper from wrapping around the fuser roller. one mite be broken causing it to hit it.
Dec 10, 2013 | Minolta DiALTA Di350 Laser Printer
Error message 093-424
it;s usually an orange feed roller assembly in printer that gets warm and causes toner to cure on paper it is most likely close to being worn as the printer keeps history of how old the fuser is by counting prints or you will start getting paper jams as the feed roller wears down.
Jan 21, 2013 | Laser 3115cn All-In-One Printer
201.08 paper jam The paper continually jams - I clear it and hit the continue but it jams over and over. there is nothing stuck in there!!
201.08
Description
Exit sensor is never made.
Possible causes:
• Improper loading of manual feed slot
• Paper wrapped in fuser
• Damaged paper exit sensor or paper exit sensor flag
• Damaged fuser autoconnect
• Faulty fuser DC cable connection
• Faulty fuser
• Faulty system card
Action
• Check for anything in the paper path that might cause the paper to jam.
• Load paper in the manual feed slot.
• The fuser exit sensor may not be functioning properly.
Jul 14, 2011 | Lexmark C530dn Laser Printer
Sir my printer problem is on printer menu write a clearing paper path what is this massage and give me solution.
Thank you contacting FixYa for your printer inquiry.
This error is associated with either a sheet of paper blocking the paper path or a partial piece of paper that blocks path or trips a sensor. The printer will usually throw up a error code 13.XX on the display and the XX is a number that will indicate where in the paper path this error most probably occurred. Just follow the steps for your error on the below chart.
This link will take you to the user guide which will be helpfull identifying components and providing guidelines for most of the helpful hints and things you will need to know about this printer.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00218691/c00218691.pdf
Locate your error on the matrix below and follow the steps. Comment back if you need more help. Thank you again for contacting FixYa.
TF
HP Laserjet Error Codes 0 - 19 Message on printer Display Panel What it means. What to do. 13.XX PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation. 3.0 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation. 13.1 PAPER JAM OPEN INPUT TRAYS Paper-delay jam at paperfeed area. 1. Ensure that paper trays are loaded and adjusted properly so media can feed from the tray. It might be necessary to reduce the stack height of media in the tray. 2. Check the input area for obstructions such as media in the path. Also check to see if the registration assembly damaged or unseated. 3. Replace any defective sensors or flags. 4. Verify the media meets the specifications. 5. Check the pickup feed and separation rollers for unusual wear. Replace as needed. 6. Rotate the media in the input tray by 180° and/or turn it over On NX engines this is most likely the fuser flag or the ACPM. The ACPM has a photosensor hard-wired to the back of it. 13.10 PAPER JAM CHECK DUPLEXER Jam at duplexer. 1. Check the duplexer and the rear area of the printer for obstructions or damage. 2. Check the duplexer for proper operation. Replace the duplexer if a sensor is defective. On a 5si, 8000, or 8100 series laserjet a Duplex Jam can be caused by a tray 2 and 3 feed assembly failure. 13.14 For Laserjet 5si. This error is caused by a defective paper control PCA Replace paper control PCA. 13.2 PAPER JAM OPEN INPUT TRAYS Paper-stopped jam at paper-feed area. 1. Check the input area for obstructions such as paper in the path. Also check to see if the registration assembly is damaged or if the transfer roller is out of place. 2. Replace any defective sensors or flags. 3. Ensure the media does not exceed the maximum length. 4. If multiple sheets are feeding, it might be necessary to fan the media and reduce the stack height. Also, replace separation pad. 5. Verify that the fuser is properly installed. On NX engines this is an input jam. 13.20 PAPER JAM CHECK REAR DOOR Media stopped in the paper path during power on or when the top door was closed. 1. Remove all media in the paper path, and then open and close the top cover. 2. If the message persists after all media is removed: Check if media is jammed in the prefeed area. Replace any defective sensors or flags 13.21 DOOR OPEN JAM The top cover was open while printing. 1. Clear the jam and close the top door. 2. If the message persists, check the top door switch for proper operation. 13.5 PAPER JAM CHECK REAR DOOR Paper-delay jam at fuser. 1. Check the transfer roller and small media belt to ensure they are operating and can feed print media. 2. Check the paper path for obstructions at the transfer roller, toner cartridge, paper feed assembly, and fuser. 3. Replace any defective sensors or flags. 4. Turn the media stack over and/ or rotate it by 180° in the input tray. If still persists - replace fuser, then DC controller. 13.6 PAPER JAM CHECK REAR DOOR Paper-stopped jam at fuser. 1. Check the paper path for obstructions at the fuser and output/delivery area. 3. Replace any defective sensors or flags. 13.99 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation
Jun 09, 2011 | HP LaserJet 4350 Printer
My printer keeps showing the message "Clear paper jam, then press (check mark), there is no jammed paper in the printer.
If I load my paper at the 'proper' height, it will not feed. If I push the paper down too far, I get a 'paper jam' message. What works for me (even though it's a royal pain) is to feed 1 sheet of paper at a time. Put 1 sheet in so it's level with the top of the feed tray, then gently push it down 3/4 of an inch. That works for me. Good luck.
Sep 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Display ... ''clear paper jam''
First clear the possible paper jam using a air blower on the rollers and sensors most possible cause is the paper dust which block the sensors. then do a power cycle by unplugging the cable and leave it turned off for 5 mins and then reconnect, it should take care of the issue.
May 04, 2009 | Canon Office Equipment & Supplies
How to remove the scanner unit on Canon PC1060
you sould not have to remove the scanner unit to clear a jam in the fuser
open all doors and remove anything marked green
remove the the cartridge assembly if it will come out
open the fuser section (usually a release that takes pressure off of the fuser rollers
remove the paper feed cartridge
you now should be able to follow the paper feed path from the time paper goes i until it comes out
if you are not sure of path take a piece of card stock and simulate it goig through feed ara
there are small microswitches/ poto eyes that sense paper lok for an small pieces also clean thes poto eyes with q tip and rubbign alcohol
reassemble
unlug from the wall then plug back in and turn on p roblem sould be solved
Jan 05, 2009 | Canon PC1061 Copier
Canon imagerunner 2230
YOU HAVE A PROBLEM WITH THE PAPER FEEDING CENSOR. IT COULD BE OUT OF PLACE, BROKEN, A PEICE OF PAPER STUCK OR PULL OUT THE DRAWERS MAYBE PAPER STUCK INSIDE. GOOD LUCK
Aug 04, 2008 | Canon Image Runner 3320I Copier
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
Lexmark C534N Printer Logo
323 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
