Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
All hidraulics funtions are dead, no hydraulic power in machine.
I have a John Deere Back Hoe 410E with Piston pumps AT180926. Ok the problem is the machine lost hydraulic power in all funtions rear back hoe and front shovel and the stabilizer cylinders work but too slow. We supoussed the main pump was broken but it didn t we dessambled it but nothing was wear or broken we reassembled but the problem still there, then we changed the oil and the filter for a new one sold by local John Deere dealer. Please give an advice to try to find the problem, how I can find the problem?
  • 370 Answers
First thing I would do is test the pump itself even if no wear is found you could have a GPM loss.
So you need to do a flow test on it to find otu how much the loss is and check it to the specs of that hydrolic pump first.
Posted on May 14, 2010
My john deere 4200 hst tractor quit moving,power steering quit,frt loader quit all at once fluid level is ok
hydraulic pump problem
check drive connection to the pump
check input line to the pump has no air leaks and sucking air
Oct 25, 2016 | John Deere Garden
Low hydraulic pressure to raise implements 8650 john deere
Could be the charge lube in the rear differential. It supplies oil to main Hydraulic pump up front on engine. The charge pump drive can strip and not turn pump. To remove pump drive remove third link plate on rear frame, remove plug behind plate, pull out hex shaft, about 5 foot long and inspect.
Oct 01, 2016 | John Deere Garden
Hydraulics 3130 john deere
hydraulic pump not working
filter to the pump blocked
valve stuck open
Sep 06, 2016 | John Deere Garden
How do I increase the hydraulic power in my 1985 john deere 1050. Speed of hydraulics is fine. Just changed oil and filter with no difference
Power in a hydraulic system is perceived as Pressure ! there for more power is more pressure , id use a pressure gauge plugged into a remote port , to test your pump . an 85 id bet sure has some wear to pump , pressure for that id suppose should be right about 1200 to 1500 psi at 1050 rpm , if its less than that you could have pump rebuilt or replaced
do ck all the simple things 1st , filter, belts, hoses ,leaks
Jun 23, 2015 | John Deere Garden
Ive got a john deere 4055. Has a new clutch and pto release bearings and piston. The pto will not ingage and there is no pto pressure.
did the mechanic that installed the new parts pre prime the hydraulic pump on install , ive had limited luck using another tractors pump on remote circuit to back feed on the return line to "externally) prime the pump , but it has worked a few times , worth a try if you have the means
Mar 28, 2015 | John Deere Garden
Three point hitch when up all the way the pump continues to. Pump
Springs, or valve seats in the control valve need repair. Or at least my wild guess, with some understanding of hydraulics, in general.
Mar 25, 2015 | John Deere Garden
John Deere 310 A Hydralic problems
Jd 310 A, boom down to dig then back off stick alittle and circut loses power.
May 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Three Bottom Rollover Plow
Hey, the "round cylinder" is a power steering motor for a John Deere 630. If you start looking for one of those instead, I'll bet you'll have better luck. Deere dealerships tend to not care unless you're buying a half million dollars in equipment.
Sep 27, 2009 | John Deere 3 Pt. Hitch Moldboard Plow...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
450 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
