Question about Nokia 6300 Cellular Phone
Nokia 6300 incompatibility with Nokia PC suite
Hi there! I just got my phone reformatted. When it came back to me, the computer said that eventhough it was detectable, it wasn't compatible for data transfers and the likes. Sheesh, please help. Thanks!
  • Alana1027 Mar 31, 2008
    Thank you very much! It really saved me...=D
How did you reformat your 6300?
Posted on Apr 26, 2008
    President:
  • 1,017 Answers
You need the latest Nokia PC Suite installed on your PC.
Then do an update of your phone software. Nokia PC Suite v6.85
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don’t unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you’re up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
Posted on Mar 30, 2008
SOURCE:
In my nokia 6300 phone , phone memory is running when i receiving data via blue tooth. how to change it to memory card?
Hello 000Krishna,
While receiving the data via blue tooth data will store in phone memory always.
If you want to transfer in memory card.
Then connect the phone in computer using the PC suite.
Please download the Nokia PC suite from
http://www.nokia.co.in/support/download-software/nokia-pc-suites
Then transfer your data from phone memory to memory card.
Mar 18, 2011 | Nokia 6300 Cell Phone
Hi i have N-6300 and having photos store in it and i want to transfer to my laptop
This is a very simple problem.
Step One: Download Nokia's desktop software here.
Step Two: Install the software and restart your computer.
Step Three: Plug your phone in to your computer with it's Micro USB cord, and open the Nokia PC Suite.
Step Four: Follow the instructions for downloading your pictures that are found in the Nokia PC Suite software.
Mar 06, 2011 | Nokia 6300 Cellular Phone
My nokia 6300 device were hanged & my device have started with blank display .what can i do
You can restore
Take a full backup.
First Try it:
You may try default phone and security code to remove it
Defalt phones codes is 12345 or 00000 you can use it
if the problem is same do the next,
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
If
Soft reset( factory setting)
On Sybmian phones:
*#7780# - Restore factory settings
*#7370# - Reformat your phone (back up your personal data with PC Suite or to the memory card first!)
Hard reset
Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3" "green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you dont understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory stetting.
Hope this helps.
Feb 20, 2011 | Nokia 6300 Cellular Phone
Reformat nokia 6300
To reformat your Nokia 6300, turn off your phone first.
Then press the following buttons:
Power button + * + 3
This will jumpstart your phone to turn on in factory settings as if it was brand new from the box.
Everything that was on the phone before will be deleted, remove your memory card prior to reformatting your Nokia so that everything on the memory card doesn't get deleted.
I suggest to you to back up anything important before reformatting your Nokia 6300.
Hope I have been of assistance to you,
Cheers :)
Apr 23, 2010 | Nokia 6300 Cellular Phone
Pc suite recognize phone but will not backup phone
have u installed pc suite which is match for nokia 6300. if not then it may be. so u need pc suite for nokia 6300. u can download it from www.noka.com thanks.
Aug 03, 2009 | Nokia 6300 Cellular Phone
Send file via blue tooth
Hi Friend,
Actually u can transfer directly from your Laptop to mobile around 10 mb.U can use the Nokia PC suite and transfer the files from PC to Laptop or Vice versa.
U can download the Nokia PC suite from the Below Link
http://www.nokia.co.in/get-support-and-software/download-software/nokia-pc-suites/compatibility-and-download#download
Copy and paste the link in the browser and scroll down u will be able to see your model(Nokia 6300) download it and install it in your Notebook.
Then u can access mobile from your notebook with the help of datacable or bluetooth
After installing u will be getting a in the desktop as nokia pc suite double click it and connect the mobile as per the steps given over there (its user friendly).
Then u can access the mobile from Notebook and transfer the files.
Kindly check it and revert back
Regards,
Ayyasam
Jun 25, 2009 | Nokia 6300 Cellular Phone
I want to transfer my sms's from my nokia 6300 to my computer.
hi there...
please download the Nokia pc suit from here and you can transfer all your data from handset to Computer
Regards,
May 13, 2009 | Nokia 6300 Cellular Phone
How to save all the phone numbers to the PC
jst copy all ur contacts to u r phone and go to pc suite connect u r phone6300 with tht datacable the list of phone number ill come jst copy it and save it to the computer......
Apr 03, 2009 | Nokia 6300 Cellular Phone
Nokia 6300 problem
I have the same problem on my nokia 6300. "only 70 sets allowed setting discarded"
Mar 26, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 can't transfer music using pc suite. connected using blue tooth.
I have Nokia 6300 mobile.
I am not able to connect it PC via DKE-2 cable.
Please help me
Feb 03, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
181 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
ASHRAF CA
ASHRAF CA
