Question about Philips Senseo HD-7810 Coffee Maker
Senseo won't turn on after running vinegar thru it to clean.
I was careful not to let the machine get wet. After cleaning, I turned it off, then went back to it that night and it would not turn on.
  • 24 Answers
If it doesn't respond at all then make sure the plug is in the wall socket and the wire isn't damaged. If it's plugged in properly, the wire is intact and other electrical appliances work OK when plugged into that same wall socket, the macine will need some tender love and care from a mechanic.
Posted on Oct 28, 2010
Keurig Coffeemaker says to descale. How do I do that?
Hi, unplug the coffee machine and remove the cup.
Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
Unplug the machine and dump the water into the sink.
Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue.
Apr 28, 2011 | Microwave Ovens
The coffemaker won't brew and showed a descale message. What does that mean?
Scale---or mineral deposits---form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water
1.Unplug the coffee machine and remove the cup.
2.Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
3.Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
4.Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
5.Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
6.Unplug the machine and dump the water into the sink.
7.Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue
Dec 10, 2010 | Keurig B70 Coffee Maker
Accidently left coffee pod in coffee pot while went on vacation now the machine smells really bad . tryed vinegar but nothing seems to help
Try the rinsing procedure that's in the manual, and use citric acid. The parts that usually come into contact with hot water or coffe can also be cleaned in a dish washer.
Sep 01, 2010 | Philips Senseo HD-7810 Coffee Maker
Water doesn't come down when brewing
I had the same problem, and it turned out it was the top needle that was clogged. I used a safety pin to clean out the needle and it worked again . . . I descaled immediately, just in case it needed that too. I am back to coffee goodness!
Jul 07, 2010 | Keurig B60 Coffee Maker
HOW DO I DESCALE MY SENSEO?
run vinegar thru it... go buy a gallon of it... and run a couple cups thru it...
then use filtered water or distilled water to flush that vinegar out...
then go buy yourself a Brita Pitcher... and use that... cheaper then using distilled water...
May 06, 2010 | Philips Senseo HD-7810 Coffee Maker
My senseo coffeemaker has stopped pumping hot water through the coffee pods. What do I do to fix it?
When was the last time you clean it with vinegar? Run vinegar through it and you will see hard water scales that were built on the heater. Coffee makers should be clean out every month then with 2 rinse cycles after that.
Jan 24, 2010 | Philips Senseo HD-7810 Coffee Maker
I live in a limestone area and the flow through my Senseo coffee maker is slowly reducing. How should I descale it?
Believe it or not, vinegar is a blessing for cleaning nearly anything out of your coffee maker.
Fill your water reservoir 1/4th full with vinegar, then fill it the rest of the way up with water.
Run the coffee maker, then let it sit for about 10 minutes. Pour the mixture back in to the reservoir and run it again. Let it sit another 10 minutes.
Dump the mixture and use plain water this time. Let it sit for another 10 minutes. Dump the water, then repeat with clean plain water.
Wash the filter basket and pot with hot soapy water. If the vinegar smell is still present, just run it again with plain clean water.
Oct 10, 2009 | Philips Senseo HD-7810 Coffee Maker
Coffee tastes stale even after cleaning
A few things you can do. Buy less pods at a time and store them in a jar. Shake or aerate the water when you put it in the unit. Don't put it in, the night before.
Jul 26, 2009 | Philips Senseo HD-7810 Coffee Maker
Descaling
Just use vinegar. Fill the reservoir with white vinegar, put a pot or big bowl under the spout, get ready as if you were going to brew and then press BOTH the one cup and two cup buttons together.
Run the vinegar through again when it's done, and then run clean (filtered, preferably) water through twice. You're done.
Feb 11, 2009 | Philips Senseo HD-7810 Coffee Maker
Amount of coffee produced
you clean the filter with what vinegar you need to use descaler descaler melt calcium vinegar vinegar remove calcium in pieces that might block the machine use descaler 1 part descaler 1 part water put solution in the water tank start the machine after a few second turn it of wait 10 to 15 minute after repeat untill empty rinse very good 2 or 3 full rinse that stuff is corosif thanks for using fixya pierre
Feb 09, 2008 | Philips Senseo HD-7810 Coffee Maker
Philips Senseo HD-7810 Coffee Maker Logo
827 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
just-ice
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
