Question about Dryers
No heat All of a sudden the dryer is not heating
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to
locate the air duct going from the blower to the drum. Normally inside the air duct you will find
the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove
the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it
is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing
the two wires and taping them together with electrical tape. If the coil heats up then replace
the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause
a fire, as you have removed the safety of overheat from the machine. I will include these two web
sites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck, Hope this helps
Please rate me, Thank you
Posted on May 14, 2010
Dryer quit heating suddenly.
The fuse is located on the blower housing and if it was blown the dryer would not run at all. The limits is mounted on the heater housing and that could kill the heat as well as a blown heating element. I worked on a similar dryer not long ago with a heating problem and did a video:
DRYER NO HEAT
Jul 08, 2012 | Dryers
Our dryer suddenly has no heat - it is electric and is tumbling but no heat at all. Please help!
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 23, 2011 | Dryers
I have a maytag dryer (dwsr-ele-2406026-fm54) and all of a sudden it will not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 16, 2010 | Dryers
Suddenly stoped heating
heatman101
Oct 03, 2010 | GE DVL223EBWW Electric Dryer
Dryer suddenly will not work. may be heat related
heatman101
May 24, 2010 | Hotpoint NWSR483GBWW Gas Dryer
Won't heat up all of a sudden
heatman101
Mar 08, 2010 | EuroTech EDV158 Electric Dryer
The dryer is not heating all the sudden. I just
check and see if the iginter is loose or not making good contact
Oct 20, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Has not heat - it happened suddenly
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, whcih requires
replacemant.
Jul 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
