Question about Goodmans GTVL19W17HDVF 19 in. LCD TV/DVD Combo
I have a goodmans GTVL19W17HDVF machine that is will play cd`s, but, if I put a dvd into the slot is says no disc. I have tried cleaning the lens as I was told this may help, but the problem is still there. do you know of any way I can fix this. Thanks
  • 321 Answers
At this state if the cleaning didnt work you may hato figure to replace the dvd ...
that all i can say or from here.
regards Alan..
or you can use a external dvd.
Posted on May 14, 2010
DAEWOO/DVN8100N / After you put dvd in slot to start the play process , it will not load the dvd. it will close, start, stop ,( no disk) in display window. what is the fix?
Clean its optical pickup lens. Insert a lens cleaning disc into the machine, and play it. It will clean the optical lens automatically. If this do not help you, the optical pickup unit should be replaced.
May 27, 2012 | Televison & Video
Some discs play in CD/DVD, some do not. One
Its none of the software related issue, try cleaning the lens, may be the lens is weakened
Jul 28, 2010 | HP (377402-B21) CD-RW/DVD-ROM Combo Drive
My goodmans TV/DVD model GTVL19W17HDVF about 18 months old has stopped loading CD's or DVD's. the TV works fine and the cd's will load into the unit but will not move on from the loading icon on the screen
Have you tried unplugging the unit, and waiting for 5 minutes and then restarting from the FIRST TIME setup screen. If you do that and then get a can of liquid air cleaner spray and blowing the area inside the slot with the cleaner and then reloading a disc that you know works. If this does not work then the reader transport mechanism is probably pooched
Nov 15, 2009 | Goodmans GTVL19W17HDVF 19 in. LCD TV/DVD...
Apex AD-1100W dvd/cd/mp3 player quit playing movies
hi,
Does it happen for all dvd disc or some particular dvd disc. If it is with some particular disc then clean the dvd and try them. If the problem exist for all the dvd then try to clean the lens by dvd lens cleaner and try to play. dvd lens cleaner will be available in dvd stores.
Thanks,
May 23, 2009 | Apex Digital AD-1110W DVD Player
Place DVD in any slot and it says "reading disc" then "no disc"
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
May 04, 2009 | JVC THC5 Home Theater System with 5-Disc...
Player won't play any disc now
Time to look inside the dvd player. try readjusting the variable trimmer under the laser lens of the dvd player assembly. It is usually located under the lens assembly. try to adjust the lens at every 1 degree angle up to +/-5deg. sometimes it can be done. if not. time to change for new lens. damage lens is caused by using pirated DVDs or bad disc as the lens is trying to read the data on the cd.
guest.
Mar 13, 2009 | JVC DR-MV7 DVD Recorder/VCR
Disc error when reading dvd
try to clean dvd plaer lens with a lens cleaner...
Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Keeps displaying error cdc
you can try to use a cd lens cleaner CD. Put the lens cleaner in slot 1 and load disk 1 the cleaner shouls be dropped in place and begin to clean the cdrom lens.
Sep 18, 2007 | Cherokee Jeep Grand CD Changers - 10-Disc
Bad Disc
If you sure that the system supports the disc's format, the disc is clean, and its the right region.. try to clean the DVD lens. DVD lens cleaning discs: Every CD, stereo equipment, department, discount, store - and even sidewalk venders - carries CD lens cleaning discs. Are they of any value? Can they cause damage? I generally don't consider CD lens cleaning discs to be of much value for preventive maintenance since they may just move the crud around. However, for pure non-greasy dust (no tobacco smoke and no cooking grease), they may not hurt and could even do a good enough job to put off a proper cleaning for a while longer. However, it's also possible they will ruin the lens. Consider that the worst thing to do to a precision optical surface is to wipe it with a dry cloth as this is likely to scratch the surface as it rubs the dust over it. To the lens, a speck of dust is like a boulder. Once the lens is scratched, replacement of the entire optical pickup is the only remedy. And, since there are absolutely no sorts of standards for these things, it is possible for a really poorly designed cleaning disc to damage the lens even if the dust itself is non-abrasive. In addition, if the cleaning disc doesn't look like a CD to the optical pickup or disc-in sensor, the lens it may not even spin. So, the drawer closes, the drawer opens, and NOTHING has been accomplished! (But at least no damage will be done.) As if this isn't enough, NEVER put one into a high-X CDROM (DVD player or DVDROM drive). The high speed rotation may cause the cleaning disc and/or player/drive to self destruct. And, don't try a cleaning disc on an automotive CD player that sucks in the disk - it will get stuck.
Dec 20, 2005 | Emerson AV301 System
DVD won't play
Is this happens on every disc? The NO PLAY message appears when "The disc that this unit cannot play is loaded (from the user guide)". Maybe it's something to do with the DVD region? If you sure that the system supports the disc's format.. And it won't play other discs... try to clean the CD lens. CD lens cleaning discs: Every CD, stereo equipment, department, discount, store - and even sidewalk venders - carries CD lens cleaning discs. Are they of any value? Can they cause damage? I generally don't consider CD lens cleaning discs to be of much value for preventive maintenance since they may just move the crud around. However, for pure non-greasy dust (no tobacco smoke and no cooking grease), they may not hurt and could even do a good enough job to put off a proper cleaning for a while longer. However, it's also possible they will ruin the lens. Consider that the worst thing to do to a precision optical surface is to wipe it with a dry cloth as this is likely to scratch the surface as it rubs the dust over it. To the lens, a speck of dust is like a boulder. Once the lens is scratched, replacement of the entire optical pickup is the only remedy. And, since there are absolutely no sorts of standards for these things, it is possible for a really poorly designed cleaning disc to damage the lens even if the dust itself is non-abrasive. In addition, if the cleaning disc doesn't look like a CD to the optical pickup or disc-in sensor, the lens it may not even spin. So, the drawer closes, the drawer opens, and NOTHING has been accomplished! (But at least no damage will be done.) As if this isn't enough, NEVER put one into a high-X CDROM (DVD player or DVDROM drive). The high speed rotation may cause the cleaning disc and/or player/drive to self destruct. And, don't try a cleaning disc on an automotive CD player that sucks in the disk - it will get stuck.
Dec 18, 2005 | Yamaha DVX-S100 System
Goodmans GTVL19W17HDVF 19 in. LCD TV/DVD Combo Logo
132 people viewed this question
Top Goodmans Televison & Video Experts
Kolbrun...
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
