Question about Toshiba Televison & Video
HDD/DVD Video Recorder: RD-XS34SU: two problems... my tv listing are not showing up... and now I can't get the TV Guide button on the record or the remote to work so I don't have access to the TV listings.
  • info23915 May 14, 2010
    tried it but it didn't make a difference... it probably is the analog-digital .
  • Toshiba Master
  • 736 Answers
Please try disabling the remote control first. You do this by pressing down and holding the ch buttons on the front of the unit for more than 3 seconds. The unit display window will say DR-off. Then enable your remote control again by performing the same step. Hold down the ch buttons on the front of the unit for more than 3 seconds. The unit display window will say either DR-1, DR-2 or DR-3 depending on your setting.
Then try the tv guide button on the remote again.
Now if there have been some recent changes like if you've recently changed cable companies or they have recently made changes to your service they may no longer support TV Guide. They may no longer have a deal with TV Guide to allow their signal to come through their system.
Posted on May 14, 2010
  • Loretta Northcutt
    Loretta Northcutt May 14, 2010
    I am also wondering if you may be experiencing a problem due to the tuner being analog only. There was a consumer alert placed on this unit regarding the digital transformation:
    Consumer Alert: This component has only an analog broadcast tuner and will require a converter box after February 17, 2009, to receive over-the-air broadcasts with an antenna because of the Nation's transition to digital broadcasting. Analog-only TVs should continue to work as before with cable and satellite TV services, gaming consoles, VCRs, DVD players, and similar products. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission's digital television website at: www.dtv.gov
Cant retune recorder to pickup tv channels
Hello,it is not easy to describe here..Instead pls visit the link below to read a detailed instruction...Manual is listed as downloadable.
the web page below contains the Installation Guide that came with the machine as well. This actually tell you how to use the machine, just to install and configure it. There is the help built into the recorder ..
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
http://www.home-entertainment.toshiba.co.uk/consumer/products.nsf/manuals?openview&restricttocategory=%3C!--dvd--%3E§ion=support
Jun 22, 2011 | Toshiba RD-XS25 DVD Recorder/HDD Recorder
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
The TV guide on screen no longer lists the tv schedule
Look online for the AVS Forum about TV Guide ON Screen (TVGOS).  there are lots of posts there about specific locations and providers,
May 18, 2009 | Toshiba RD-XS55 (250 GB) DVD Recorder /...
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ? I have the...
Got the same problem today. I found the solution online on the installation guide. You need to push the two channel changing buttons on the recorder at the same time for 3 seconds.
Jan 11, 2009 | Toshiba RD-XS32 DVD Recorder
DVD - Video Finalization rejection
1. The message can appear if the disc has already been finalised.
2. The disc may be faulty.
3. Try copying again from HDD to another disc. Performing a copy and finalise together by using 'DVD Video Creation' from the Edit menu can be more successful than doing each step separately.
4. When you transferred from your video camera, did you use firewire? If so, did you record at the maximum (default) bitrate of 14+ ? If so, you must copy (rate conversion) to the DVD at a maximum bitrate of 9.2, which is the maximum for the DVD playback standard.
Jan 01, 2009 | Toshiba RD-XS34 DVD Player/HDD Recorder
Will not power up but is still showing time
I changed my IR code by accident and now nothing works. I can not get back to the IR 1 code. Everytime I hit a button the DR3 appears but nothing works. How could I fix this.
Oct 01, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Firmware update failed RD-XS34Su
If it was a toshiba supplied disk, then I should follow up with them with the failure, as it was their fix, that caused this problem, they should replace/repair this unit for you
Oct 15, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
Refuses to Record Program onto HDD
I have exactly the same problem. The difference with mine is that mine actually starts up - thsn won't shut off until I manually when I set it to record when I'm away.
Jan 01, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
Remote control problems
Answering my own question,Switch on recorder manually then hold down SETUP KEY and No 2 key at the same time.As this is a common fault with this recorder would advise taking note of this solution.
Oct 21, 2006 | Toshiba RD-XS34 DVD Player/HDD Recorder
Televison & Video Logo
60 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
