Question about Dishwashers
Kitchen aid dishwasher
I'm in the process of replacing the plastic control panel on our kitchenaid dishwasher as the screws were tightened to tight and broke. The thin plastic device over the control buttons appears to be glued in place. Is it possible to remove it and re-install in on the replacement panel or do I need to buy a new botton cover device as well? Thanks, Lumy
  • 53 Answers
HI Lumy,
it's hard to say for sure with out seeing it but, if it looks like it will peel off easily and you can remove it without damaging it then it should be ok to reuse.
Posted on Mar 30, 2008
How do I fix this. Kitchen aid dish washer?
It appears to be the door switch sensor. http://www.searspartsdirect.com/model-part/kudl03fvss0/0593/0130000/w0808049/00002.html
I suggest replacing it.
Mar 20, 2016 | KitchenAid Kitchen Aid - KUDE40FXBT...
Need door latch diagram Kitchen Aid dishwasher (Part No. 9744033)
I thought the metal bar had to be locked into place somewhere in the black latch. This was not the case. I just put the white plastic latch in place in the slot in the door and closed the panel and the metal bar went into the correct position against the black latch.
Jan 22, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
Kitchenaid dishwasher, control panel is not
I don't know your technical ability, but there is a fuse located next to the control board inside the console, this is a good place to start. Kitchen Aid is good about putting tech sheets on the back of the kickplate and it should have wiring and diagnostic info there. Just be sure to put the sheets back so the next service tech to work on it will have them :)
Sep 01, 2009 | KitchenAid Dishwashers
Minutes don't display
DROPPED WIRE ON FRONT LOOM WHEN RECONNECTING OR BAD EARTH RETRACE STEPS
Aug 31, 2009 | Dishwashers
My Kitchen Aid dishwasher runs for about 2 hours. Is this normal
It depends on your water pressure. Mine runs a cycle in about 25 minutes, with 92 psi water pressure. Before changing all the pipes in my house, I had about 30 psi and it took about 45 minutes. The longer it takes to fill, the longer it takes to do a wash.
Apr 06, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Loose Oven door handle
Ok you need to use plastic or rubber washers against the glass so it doesn't break. To stop the handle comming loose again you need to put "Lock Tight" on the screw threads then tighten carefully only untill the handle isn't loose. You can get this from any good hardware store. cheers
Please give feedback
Mar 23, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Want to replace dishwasher panel with stainless steel
Yes indeed! If you know the measurements, you can buy a stainless panel from www.applianceart.com cut to any size you would like. THey also have a cheaper "faux" stainless option too. Many colors and designs as well.
Mar 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Kitchenaid dishwasher - door will not latch
The latch needs to be replaced. Kitchen Aid has made two updates to this latch. I.E. 2-revised latches. I just replacd the latch assembly and the dishwasher works fine now. Do a search for kitchen aid repair parts online and hav them shipped to your home. The repair takes five minutes. Un-screw all torx bit screws on door and the latch is under neath. One electrical dip switch held on by another screw and a two prong tab to undo the old latch. This seriously took me five minutes to repair and the parts were $40.00 online shipped.
Hope his helps.
Dec 16, 2008 | KitchenAid 24 in. KUDP02CR Built-in...
Kitchen aide dishwasher KUD101IL control panel not working
1. Check plug outlet.
2. Check electrical box underneath the d/w where power cord connected to d/w (you have to take the kick panel off . The box located on right side). Sometime you can find burn wire there.
3. Check the thermal fuse on computer board. It is inside the control panel on right hand side. The fuse has 2 white plastic connector which sticks out, easy to find.
Dec 08, 2008 | KitchenAid Dishwashers
Blinking normal and cancel lights
I had the same problem- needed a new control panel. good luck. Didn't bother going through kitchen aid even though its still under warranty- figured they'd nail me on labor (it's in the 2- 5 yr warranty period) and I'd be waiting forever. had a private appliance tech take care of the problem.
Aug 25, 2007 | KitchenAid 24 in. KUDS02FRSS Stainless...
Dishwashers Logo
104 people viewed this question
Top Dishwashers Experts
