Question about EPoX EP-8RDA3I Motherboard
EP-8RDA3I bios error problem with flashing bios info on screen BIOS ROM check sum error
    Problem Solver:
  • 5 Answers
The file could be corrupt.
Re-download and try again.
Posted on May 14, 2010
    President:
  • 1,851 Answers
Retry downloading you bios update and use another removable media (floppy or USB) with suficient free space.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Drive A media error bios checksum error
your current bios is corrupted since the check-sum that was generated when your bios eprom was flashed with your current bios version doesn't match the check-sum that is generated as now, meaning that your bios changed for a few bits. you can fix this problem by re-flashing your bios with a good ROM file that you can download from your computer maker site or your motherboard bios maker site, also upgrading your bios with a newer version will take care of the issue as well.
Mar 07, 2011 | Computers & Internet
Just bought this Samba 1845 system. Upon power on receive bios rom checksum error, insert system disk. Is the battery dead, bios need to be flashed again, please help
A BIOS sum check error is usually due to a near flat BIOS battery.
Replace the BIOS battery and configure the BIOS Date & Time setting etc.
Oct 27, 2009 | FIC Samba SM-1845 (SM1845GV) Barebone
Epox EP-9NPAJ
Go into the BIOS setup and select 'Load setup defaults', save and exit.
Sep 19, 2009 | EPoX MB EP-9NPAJ NF4 RET Motherboard
EP-8RDA3I not booting on CD ( win XP ), but I tried the cd rom and the cdto other PC, and it boot. I have found while booting.. " Athlon XP......... bios update successfully.." I dont know that I have...
please go in your bios menu by pressing the del key or f2 or f10, then select integrated peripherals
and there you will see boot device priority or first boot device change it to your cd rom and save the setting and reboot it should take care.
Mar 24, 2009 | EPoX EP-8RDA3I Motherboard
When i'm turn on my pc this message would appear ''bios rom chesum error'' what should i'l do?
the ram has some error
better remove the rom blow air to it wipe it wit a clean soft  material
then replace the same
Mar 06, 2009 | Computers & Internet
Rom bios error
turn off your comp.,go to cmos setup,go to boot option,make your cdrom as the first boot device.insert the support cf of your mboard to cdrom to recover the original rom bios because your bios file was corrupted already.dont turn off your comp, while flashing.
May 19, 2008 | EPoX EP-4PEA+ Motherboard
ACPI error message
Hey there rcrozier, your solution is to disable ACPI in the BIOS. To do so, follow these steps. 1/ When set up is loading, a blue screen will appear asking if you have RAID devices, indicating pressing F6. Instead press and hold F7. This should prevent ACPI from installing. Alternately at the blue screen mentioned above, press F5 and hold. It should advance eventually to a new screen prompting you to press F2. Keep holding F5. It will give you another screen telling you it cannot recognize your pc type. It gives you two choices: standard pc or other. Choose standard pc. resulting in ACPI not being installed. Unfortunately the other result of this ACPI not being installed is that your power management will be reduced. Overclocking is not advised. Hope this helps. Good Luck!
Jan 29, 2008 | EPoX EP-8RDA3I Pro Motherboard
Port Debug LED: 50
Hi, two possible things to try. First reinstall your O/S [I am assuming you are running XP] To save your current settings do not select the first prompt by WIN setup to repair the current instalation, press enter install. At the second prompt to repair press "R" to repair.The drivers for USB2 are in XPservice pack 2. Second , if you are unable to get to the setup stage then go online with a friends computer and log onto your mobo manufacturers home page and download the latest BIOS for your board, burn this to a CD, then set your computer to boot from CD and flash the bios to the new version. goodluck, regards mistyman
Aug 09, 2007 | EPoX EP-8RDA3I Motherboard
EPoX EP-8RDA3I Motherboard Logo
365 people viewed this question
Top EPoX Computers & Internet Experts
David
David
Greg Cann
Greg Cann
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
