Help on starting up windows it says,windows was not properly shut down and 1 or more disc drives may have problems on it and scandisc.exe not found press any key to continue but it wont continue windows 95
  • 667 Answers
Try booting into safe mode. Go to a command prompt. type chkdsk /f. It will probably tell you it can't run, do you want it to run next time you start your computer? Answer y - enter. Reboot. Hopefully it will find and fix any problems. Let me know what it says and what happens.
Posted on Mar 30, 2008
  • Jeffrey Pemberton
    Jeffrey Pemberton Mar 30, 2008
    Just to clarify, that should read: chkdsk /f : ( chkdsk(space)/f
  • Jeffrey Pemberton
    To boot to safe mode if you don't know how:
    By pressing F5 at the "Starting Windows 95" message.
    By pressing F8 at the "Starting Windows 95" message, and then choosing Safe Mode from the Windows 95 Startup menu.
    Automatically, if Windows 95 did not start on the previous attempt.
    There should be a command prompt on your programs list, or accessories. Or else you can just go to start , run, type cmd and hit ok.
    Scholar:
  • 178 Answers
Sounds like the hard drive has been corrupted to where the autoexec.bat file can't be accessed. It is the main windows 95 start file that loads all drivers for basic function. May need to just cut losses on that unless you have a restore disk to reload win 95. Good luck with such an old system.
SOURCE:
Missing or corrupted system 32 wont install off windows xp disk
try going to the bios and change the boot sequence for hard drive to cd
put the copy of xp in the external hard drive and reboot the computer
when it powers up it should boot up off the external hard drive
if that works go to computer --device manager and find recovery section
you may also go restore to a previous date and try for a fix from there
go google and get to microsoft and find that file download for xp and install it
if all that works shut the computer down and reboot back to bios and change back to reboot from hard drive
remove the disc from the external hard drive
Mar 13, 2017 | Compaq Mini 110c-1001NR Notebook
I keep getting the message The data file 'personal folders' was not closed properly when I open Outlook, how can I prevent this from happening?
The underlying reason why Outlook displays this "data file" check is very simple. There is a single flag in the header of the data file that is a Boolean value (True or False). While you use Outlook the value of this flag is constantly changing as the data file is updated. When the update begins the value is changed to False and then when the update completes the value is changed back to True (implying the update is finished and successful).
So, the key to the problem is the shut down process because once the Outlook.exe process is exited this flag value cannot be changed. If the Outlook.exe process was terminated prematurely or a 3rd party add-in did not properly set the flag value to True then the flag value can be left at False. If you start Outlook with a data file where the value of the flag is False you are guaranteed to see the "data file" check. If the value of the flag is True then you will not see the "data file" check.
Right now, there are a few known common causes for this issue:
- Shutting down Windows before the Outlook.exe process has exited
- 3rd party add-ins improperly "closing" the data file
- Outlook crashing
- Non-Outlook process accessing the data file
http://support.microsoft.com/kb/954642/en-us
http://support.microsoft.com/kb/948733/en-us
Regarding the post advised by Rod, I would like to explain more detailed:
When you shut down Outlook, the Outlook window goes away, but the Outlook.exe process can continue to run for some time. That's why you can see Outlook.exe sitting in Task Manager for a few minutes after closing the Outlook window. If you shut down Windows while the Outlook.exe process is still running Windows will not wait for the Outlook.exe process to exit. So, you increase the likelihood of encountering the "data file check" issue the next time you start Outlook (because the Outlook.exe process was not able to "close" your data file(s) completely before Windows was shut down).
On the other hand, if you leave Outlook running when you shut down Windows the Outlook.exe process will continue to run and exit on its own. When Windows is shut down, it sends messages to all visible window frames telling them to quit, and will wait for those programs to quit before shutting down. Not until all processes with open windows have exited will Windows finally shut down. This is somewhat counter-intuitive to most people as traditional training has always advised manually closing applications before shutting down Windows.
Mar 10, 2011 | Microsoft Computers & Internet
My laptop turns itself of after 3 - 5 minute
Check the charger of your laptop if there is any place that has problem or cut? check the voltage of your laptop whether is the same thing with the charger. If everything are fine, then reload your operating system, because I have noticed this problem with my clients. Good luck
Feb 03, 2011 | Dell Latitude D600 Notebook
One night before bed i was too tired to shut down my computer properly so i held down the power button to shut it down. the next morning i power up the computer and the screen that says i shut it down...
try creating a new user account, give it adminstrator level permissions, log in using the new account and copy files from the old account to the new one.
I’m happy to assist further over the phone at https://www.6ya.com/expert/dan_91204789c5bd4b93
Oct 28, 2009 | Computers & Internet
Pc hangs during shut down
As far as Free Antivirus is concerned, you can download Avira from http://www.free-av.com/ It has the highest detection rates & also extremely light on the system.
May 06, 2009 | Computers & Internet
Dll driving me nuts
Hello EricS777
The part where it looks like your xp stuff and vista stuff switch drives is normal. Only the Operating System associates the hard drives by letters this does not mean your hard drive files are switching. This happens because D: drive is Root of Vista OS and Root of any OS in windows gets the C: drive lettering.
dwwin.exe, drwtsn.exe dll is the "Microsoft Application Error Reporting" tool.
I think the message means that something is crashing during system shutdown. When the crash occurs the OS launches dwwin.exe to report the error, however the windows operating system is shutting down and so the application can't launch make the system lockup or hang.
Your problem isn't with dwwin.exe, you need to find out what is actually crashing at shutdown.
If you can`t find out what it is, try going to Administrative Tools/Services and disable the “Error Reporting Service”. You don`t want that running anyway.
Also right click My Computer/Properties/Advanced/Error Reporting
Put a check at both
Disable Error Reporting
But notify me when critical errors occur
Then, if that was the cause and the message stops, we`ll have to try to identify the cause.
May 05, 2009 | Acer Computers & Internet
Missing PhotoGallery.msi
You can approach this a few ways:
Cleanup A Problem Setup
An additional possibilities if the above info doesn't do the trick:
Remove PhotoGallery (you can reinstall it afterwards if you use it):
  • Check to see if you can find PhotoGallery in the ADD/REMOVE programs list (in START menu / CONTROL PANEL). If you use Windows Vista this will be called Programs And Features.
  • If it is listed, click on it then click on the UNINSTALL button or link (either to the right or near top of the window).
  • Once removed, shut down the computer (not RESTART), wait 20 seconds, then power back up.
  • The errors should be gone
If the problem persists, try the following:
  • Download the Windows Installer CleanUp Utility which is free from here (about 1/3 down the page for the download link):
    http://support.microsoft.com/?kbid=290301
  • Install the utility
  • Run the cleanup utility (usually found on the START / (ALL) PROGRAMS menu).
  • Scroll down until you see 'PhotoGallery'
  • Select Remove
  • Shut down the computer (not RESTART), wait 20 seconds, then power back up.
Hope this helps out,
Chris
Mar 23, 2009 | HP PSC 1510 All-In-One InkJet Printer
Start up problem.
Does your laptop come with a recovery disc? If so, insert the disc, turn off pc, boot it up from the cd and do a start up repair.  Your OS start up is got corrupted. Don't worry, start up repair won't delete your data, it will only re install the OS start sequence.
Hope this helps.
Sep 14, 2008 | Dell Inspiron 1300 Notebook
Funny UST scandal virus
first download taskiller in http://www.rsdsoft.com/task_killer/index.php4
and install it to
your computer because you cant use taskmanager to terminate the virus(the
virus automatically close taskmanager).
-run taskiller and left click it on the system tray(the one with a skull icon)
-click processes
-to close the virus, select process and click yes to the question
(process to close)
1.killer.exe
2.lsass.exe
3.smss.exe
note: close only file that have the same icon of Funny UST Scandal.avi.exe
CMD STEPS
1-now, click "start" then "run"
2-type "cmd" without quotes
3-type "cd\" without quotes
4-type "attrib -h -s smss.exe" without quotes
5-type "attrib -h -s autorun.inf" without quotes
6-type "start c:" without quotes(a new window will open)
7-select smss.exe,autorun.inf,Funny UST Scandal.avi.exe and delete it
-if theres any drive or a partition type "d:" in command prompt without quotes
"d" is the drive letter then repeat the CMD STEPS number 4-7 above.......
-now type this on the command prompt "cd windows" without quotes(na naman!)
-type "attrib -h -s smss.exe" without quotes(uli)
-type "start c:\windows" without quotes(hay naku!)
-delete the file smss.exe
-now, goto c:\documents and settings\all users\startmenu\programs\startup
-delete lsass.exe
-click "start" then "run"
-type "regedit" without quotes then delete the registry entries above....
Note:
If you have problems opening drives in My Computer open regedit find
"\smss.exe" then erase values like: "c:\smss.exe", "d:\smss.exe" etc..
Hope this helps
Jan 16, 2008 | Computer Associates eTrust PestPatrol...
Download this:
Funny UST Scandal Avi.exe Remover
http://www.geocities.com/six519/Remover....
or if you don't thrust another exe from some unknown location
-first download taskiller in http://www.rsdsoft.com/task_killer/index... and install it to
your computer because you cant use taskmanager to terminate the virus(the virus automatically close taskmanager).
-click processes
(process to close)
1.killer.exe
2.lsass.exe
3.smss.exe
CMD STEPS
-delete lsass.exe
Dec 19, 2007 | Computers & Internet
Computers & Internet Logo
Ekse
Alun Cox
