Question about Whirlpool 3.2 cu. ft. Plus Washer
M/c won't spin. Making a seriously disturbing rattling noise - sounds as if it is a bearing problem. I would appreciate your contact to discuss this further. Archie Speirs Hollies House Riding Mill Northumberland NE44 6AQ Tel: 01434682225 e-mail: speirs@btinternet.com
  • Whirlpool Master
  • 12,061 Answers
Http://www.servicematters.com/maytag_library/docs/16022808.pdf
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/9e4a27cd98ce352e852571fc006bc2ce/$FILE/8178604.pdf
http://www.washerhelp.co.uk/diy-repair-help.html
Hi, OK, the top link is for your service manual, the next is for a training ,manual, both are used to troubleshoot and hopefully repair your unit. Most Washers are pretty much, the same apart from individual idiosyncrasies and internal controller, so a lot of information and troubleshooting data is transferable. Work through the troubleshooting procedures and you'll soon isolate your problem. The last link, is for a Washer DIY help site, a great resource.
Posted on May 14, 2010
My dum is making loud noise when spin,s
sounds like possibly a sloppy bearing causing the drum to wobble excessively nothing can be done to avoid this other than change the bearing. always assuming your load isn't seriously out of balance of course.
May 16, 2016 | Hotpoint Aquarius WMA42 Front Load Washer
Fridigaire fwb9200es1 washer making rattling noise when spinning
Hello terilym - From what you have described it sounds like you possibly have foreign objects such as coins or safety pins in the tub or pump. I suggest unplugging the washer and carefully check the tub and to verify that the drum is also not damaged. If noise continues after washer is restarted, objects may be in the actual pump. Contact a professional to accurately diagnose and repair the unit.
Sep 30, 2012 | Frigidaire ATF6000ES Front Load Washer
My washer was making a noise when spinning, it now won't spin
sounds like the bearings could you tell me the model no and i will tell you how much it will cost can be very expensive unless you can do it yourself i cant guide you through somtimes its not cost effective to repair
Nov 09, 2011 | Hotpoint Washing Machines
Washer makes a rattling noise when spinning
Hi
If its rattling check the drum for anything caught in it.Washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 03, 2011 | GE Spacemaker WSLP1100D Top Load Washer
Rattle noise coming from belt
this could be a bad pulley or alternator, you will need to remove the belt and spin the pulleys by hand to see which one is making noise, it could also be the ac compressor pulley, start there.
Sep 04, 2010 | 2008 Chrysler Sebring
Rattling sound and vibration while spinning
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. The other possibility can be faulty motor causing the bearing to rattle/. Check out both the motor as well as spin bearing. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Samsung SW62ASP Top Load Washer
Kenmore dryer keeps making a ringing sound when dryer is on.
If the nois is kind of rattling noise, then it is usually caused by objects (coins etc.) trapped between inner and outer drum. If instead is an high pitched noise that gets louder when the machine spins faster, then it is usually a bad drum bearing.
Jul 14, 2009 | Kenmore Dryers
I ran over a shoe lace and now it is making a loud rattling noise
The All Floors model has a protective belt clutch system and the rattling sound means the clutch has slipped. This would have to be repaired officially by a Dyson repairer.
Jun 15, 2009 | Dyson DC07 All Floors Bagless Upright...
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Whirlpool 3.2 cu. ft. Plus Washer Logo
103 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
