Question about Kenmore 16874 Built-in Dishwasher
I have a tdx6ss-2 technika dishwasher, the three end buttons keep flashing and beeping. i cant start the wash cycle
  • heysarg May 16, 2010
    tdx6ss-2 technika australia
  • lyndonm_uk
    lyndonm_uk Apr 02, 2013
    I too had the same problem and here is how I fixed it.... Turn off the machine from the front panel, hold down the Start/Pause button and then turn on, keep the Start/Pause button fixed and the machine will show every light lit and number 8 on the display. This shows that the machine is fully resetting itself. It will after a few minutes just display the power light and there you go.... As long as there are no physical hardware problems you should be back washing again.
  • Kenmore Master
  • 3,051 Answers
Hello there:
It doesn't work at all If your dishwasher doesn't work at all, check these: first Power from the house Door switch Wiring Timer or selector switch Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker. Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it. Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors. Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Posted on May 16, 2010
  • Kenmore Master
  • 12,061 Answers
Http://frigidaireservicetips.com/pdfs/486_5.pdf
http://www.servicematters.com/maytag_library/docs/16010622.pdf
Dishwasher Repair Guide: How To Fix a Dishwasher - ACME HOW TO.com
Please find above A couple of service and repair manuals for your generic dishwasher, use these to troubleshoot and hopefully repair your unit, below them, is a DIY help link, that should prove invaluable.
This "Fix" below, works many times regardless of why... So it is worth a try. Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Posted on May 15, 2010
  • Kenmore Master
  • 19,396 Answers
Trip the circuit breaker and check if there is water inside the tub.
Connect power back and try starting a cycle.
If the problem persists after connecting back, give me the model number. Technica dishwashers have reset procedure. Technica Most Dishwashers have a reset button,or a
Posted on May 14, 2010
  • Ginko
    Ginko May 14, 2010
    Hi.
    By mistake I posted an incomplete comment.
    Trip circuit breaker.
    Connect back power.
    If light are still there try holding down start or clear button for few seconds.
    If lights do not clear that means that there is a fault. In that case I can be more specific by knowing the model number.
    Regards.
  • Prabhdeep Singh
    Prabhdeep Singh Nov 20, 2016
    I have techinka model - VDW6SS-4098157A
    First it wasnt draining , something was stucked in drained hosewhich i cleared but now lights are keep flashing nd beeping and dosent start wash cycle ,is anything i can try to reset it please
    I tried holding start/pause button nd starting again but didnt work
    Thanx
    Plzz repky with any fix
Why doesn't it work?
please provide model number of the Dishwasher and the exact keys where the three lights glow.
Perhaps a photo without flash will help
Mar 29, 2016 | Samsung Dishwashers
The light keeps flashing an going beep beep dishwasher isnt doing it's job not washing
On my dishwasher if I hold down the start button for a few seconds it resets the cycle could you do that with yours as mine is a different make?
Feb 02, 2013 | Dishwashers
How do I stop my washing machine door alarm beeping?
do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint WMA74 Front Load Washer
The program light goes off and the BF162 doesn't start...
When you keep the button pressed for a few seconds the lights go off, this resets the dishwasher. Then press the p button again to the program you want 1st light is heavy soil 2nd light is normal soil, 3rd light is eco wash, 4th light is rinse. At the end of the cycle the program light you have selected will flash.
Apr 24, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
I have a technika diswasher,not sure of the model, is approx 3 years old and has a big dial on the left hand side with 7 wash functuions and the power button is smaller and is on the RHS. I cant remember...
I have the same model. You just turn the dial to the setting you want, push the dial back in, turn the (right) power button on then turn the smaller start button on. I use different cycles all of the time depending on whats in the load and this works fine for me.
Apr 27, 2008 | Dishwashers
Kenmore 16874 Built-in Dishwasher Logo
1,824 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
