Hi have samsung model j1045\j845 washing machine
Hi have samsung model j1045j845 washing machine front load. Drum will not spin. Do they have a belt pulley system??? cheers Ossie
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
IFIXALL
  • 868 Answers
SOURCE: How to replace the belt on a Samsung J845 front loader washing machine
Its on the back of machine and after you remove the back cover plate youll see that its very easy to install the new one.You shouldnt have to use any tools to put on the new belt.Just loop it around the motor pulley and around the large tub pulley that you see right in front of you.It may even appear to be too tight while your winding it on the pulleys but its not .
Posted on May 20, 2008
SOURCE: How to replace the belt on a Samsung J845 frnt loader washing machine
If you stand in FRONT of the washer, leaning over the top, the drive wheel is underneath the main drive motor, on the RIGHT hand side.  Loop the belt over the drive motor wheel, then over the main pully, and it should be good to go!
Posted on May 23, 2008
SOURCE: Broken front door
you need to buy a new 'handle'. to open the door for the time being, disconnect power and then use a coat hangar to pull the latch towards you, ie. outwards
Posted on Jun 09, 2008
SOURCE: Our samsung j845 front load washing machine won't
SAME THING HAPPEND TO ME, SORRY BUT YOU NEED A NEW WATERPUMP, THEY GO ON THEM WASHERS ALL TIME. I REPLACED 2 AND HAD MY WASHER JUST OVER A YEAR. NOW ITS THE DOOR
Posted on Sep 29, 2009
My samsung WA10R3 won't spin - it making a noise as if its trying to spin but the drum isn't turning and the water isn't coming out Thanks
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | Samsung Washing Machines
Hi: My samsung washmachine J845 had problems. it wasnt pumping out the water.
heatman101
May 19, 2011 | Washing Machines
Can i use any drive belt on a front load samsung wasing machine model j1045
This is the belt number:
SAMSUNG FRONT LOADER DRIVE BELT 6602-001072 (1050323)
And this is just one source for the belt:
http://cgi.ebay.co.uk/SAMSUNG-FRONT-LOADER-DRIVE-BELT-6602-001072-1050323-/250632182892
Thanks for choosing FixYa,
Kelly
Apr 08, 2011 | Samsung Kitchen Ranges
Our frigidaire front loader washing machine does not spin and the clothes are still wet! Model FTF1240FS2. It seems to go through the cycle and pump the water but the drum will not spin. I checked the...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Mar 05, 2011 | Washing Machines
What will cause the drum not to spin during cycle? It spins freely by hand. Belt is in tact and motor shaft turns freely manually?
heatman101
Sep 15, 2010 | Frigidaire FCCW3000F Front Load Washer
Samsung J845 washing machine will not spin.
could be the dampers have failed or the drum mount is broken, try a spin with no clothes, if it is spinning with noise or the drum is not running true it will need major repairs.
Apr 19, 2010 | Washing Machines
Replace belt j845 samsung front loader washing machine. how do i get replacement belt on as back and both sides of machine is one piece of metal
There is no belt on a front loader washing machine. The way the drum spins is by a stator in the back of the unit.
Dec 29, 2009 | Samsung WF337AA Front Load Washer
Please help! My samsung 7kg J845 front loader keeps flashing UE on the error code (spin cycle) and I can't open the door. Sarah
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
Oct 22, 2009 | Samsung WF337AA Front Load Washer
Door jammed shut
normaly this is due to water still in the drum
Sep 20, 2009 | Washing Machines
May 20, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
