Question about Drills
Which drill bits for b&d cordless
I have a b&d cordless drill hp9096 9.6v though no drill bits. Can I use any make or are there specific bits I should buy. Thanks
  • 623 Answers
You can use any brand drill bits yes.
Walmart sells a B&D set for about 15 dollars last I knew.
Posted on May 14, 2010
Tighten a bit in
Hi if the picture is correct this driver only takes 1/4 inch hex bits & will not hold a round drill bit
Jan 20, 2014 | Black & Decker Pivot Plus Cordless...
I bought a Black & Decker 7.2v cordless drill with
Just charge battery put bit in and your ready to go.
Jul 04, 2011 | Black & Decker Drills
you can use any brand of bit on the market,but you need to use the correct bit for the material you are trying to drill thru
Mar 21, 2010 | Black & Decker Drills
Describe how to remove drill bit and install a
Most cordless drills use keyless chucks these days. Shift the drill into reverse and hold the main body of the chuck. Pull the trigger and the bit should come out. Put it into forward and run it to tighten onto a new bit.
Dec 02, 2009 | Drills
Brand new Bosch PS 20 drill Kobalt 1/4" bits snap into place, however there is still "play" between the bit and the chuck, creating an untrue bit revolution while drilling. Anyone? ...
It's the nature of the beast. It should be snug enough not to fall out, though. Virtually all cordless screwdrivers have a bit of end play to them.
May 18, 2009 | Bosch PS20 2 Factory Reconditioned 10.8V...
How to change drill bit on black & decker plus pivot cordless drill How to change the bit on a Skil cordless screwdriver 2362 with a keyless check?
Grab the end of the chuck in one hand, and the outer ring of the chuck nearer the motor, and twist the chuck end. try both directions until it loosens.
Jan 28, 2009 | Drills
Porter cable 884 cordless drill
Most chucks have a tolerance the cordless drills where designed for drill bits 1/8 and larger the 3/8 chucks are a little better with the smaller bits .Check your owners manual and see if they have a min requirement listed for the bit size
Sep 27, 2008 | Porter Cable Cable 19.2 Volt Grip - To -...
Makita 6222D hole drill bit is stuck
When this happened to me I held the shaft of the drill bit tightly with my hand and reversed the direction of drive for an instant. It released at that point. It still does that occassionally though.
Jan 27, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Drills Logo
60 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
