Question about SanDisk Sansa e250 MP3 Player
Corrupt? I have this problem too, only a little different. When I put music on the sansa, it doesn't show up when I disconnect it from the computer, on occasion the system reset take a long time and the files come up corupted I have used both MTP AND MSC modes.I am worried about wiping the player because If I do when I attempt to put the music back, it may not show at all. resetting is NOT an option
  • 758 Answers
I feel that the problem you are having is because the firmware that is currently on the device is corrupted...i would recommend you to go to the sandisk websiteCorrupt? - 1.gif to get the latest firmware upgrafe for your device..the link for the firmware upgrade is below..I hope that helps...if you have any more problems please contact me....
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Please rate accordingly
Thank You
Computerrep
Posted on Mar 31, 2008
SOURCE:
Can't add or remove music off my Sansa Rhapsody 2GB
first try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
if that doesnt fix your problem try this...
1 connect your sansa to comp via usb cable
2 right click start on windows desktop go to explore
3 scroll down to your sansa's drive rifght click it go to properties
4 go to tools tab and click "check now" under error checking will take awhile and will erase your memory on the sansa but it will work again
I hope my post was helpful let me know!!!!
Mar 14, 2009 | SanDisk Sansa e250 MP3 Player
Music won't play
Some music services have a fixed-term license that they put on the songs - you may have to resychronize the Sansa to the computer AND the music service to regain playability. Alternatively, you could have a corrupt DB already - sad, but possible. The good news is that you can fix a corrupt DB by downloading the Sansa Recovery Tool from Sandisk's website. Good luck!
-Tha Mp3 Doctor
Dec 28, 2008 | SanDisk Sansa Clip MP3 Player
Songs on computer, but not on Sansa
Very interesting. What program do you use to transfer files to your Sansa? Windows Media Player? Windows Explorer (drag and drop)?
If they are Mp3 format, then the format is correct - we can rule that out.
Unplug, retry failed, so we can rule out read errors.
You could try switching the player manually from mtp to msd mode, or vice versa - see your manual for details. One mode displays music files - the other mode hides them (which is why I don't like dual-mode players).
The database could have become corrupt - this can occur for a variety of reasons, but one reason is that this player was loaded on a machine running Windows Media Player 11. Have you updated the firmware for this device?
Jun 12, 2008 | SanDisk Sansa e260 MP3 Player
I cant put songs on to my MP3
Sounda like a corrupt DB - try getting a firmware upgrade, and then try rerunning the Sansa Recovery Tool. menach- the Sansa is not compatible with iTunes.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jun 02, 2008 | SanDisk Sansa Clip MP3 Player
I can't delete my music!!! Please help.
I'm having the same problem and trying to work through it. The problem is that your memory in the music section is corrupt. You may need to reformat. If I figure it out, I'll leave a note for others.
Apparently, this is a problem with this player. Not sure why. I've had this problem in the past and was able to fix it by disconnecting the battery and then reconnecting. But this time it's gone. I had a "bad track" message before it stopped.
Apr 06, 2008 | SanDisk Sansa E280 MP3 Player
"Not enough space for Music DB. Please Free 4MB"
Corrupt database - upgrade the firmware from www.sandisk.com
-Tha Mp3 Doctor
Mar 31, 2008 | SanDisk Sansa m250 MP3 Player
The media device has either stopped responding or has been disconnected
Make sure you're not using the media with another program while you attempt to copy/sync it to your device.
Pretty late response, but meh.
Feb 28, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Help
check if the format of the music is in mp3 format this happened to me and i was told to change the format, see if this works.
Dec 26, 2007 | SanDisk Sansa e260 MP3 Player
Music not showing up even when downloaded
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
-Tha Mp3 Doctor
Dec 25, 2007 | SanDisk Sansa e260 MP3 Player
Music is lost
-Tha Mp3 Doctor
Feb 04, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
44 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
