Question about Sony PlayStation Portable (PSP) Console
Psp control Panel problem
Each time I try to play a game the control panel won't work right because on the game I can't move my player. What do I do?
  • Anonymous Jul 12, 2008
    my psp buttons like the O and X and left arrows dont work. ive
    remove the battery pack and tried different games, still it does not
    work. what do you think is the problem?
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 38 Answers
Try to play other games,and if the control panel still doesn't work,you will need to have it checked...the problem most likely lies on the hardware itself and not on the software.overall,regardless whether you're using the control panel for games or other functions,as long as it's not responsive,chances are the issue is with the psp hardware console.hope this helps.
Posted on May 05, 2008
SOURCE:
Psp gaming problem
remove the battery from the psp then put it again . I hope it will work
''BUST OF LUCK
May 22, 2013 | Sony PlayStation Portable (PSP) Console
When I switch on my PSP, it directly goes onto load the UMD game and when I try to quit using HOME button, the buttons and consoles dont work. Then I need to use the hold button after which though the...
Hi. Since you're in UMD Autoload mode, you need to configure that in the PSP Settings. To do this, turn off your PSP and remove your UMD. Now, turn it back on and it won't autoload your UMD since it wasn't there anymore.
Now, go to "Settings" and scroll down to "System Settings" and press X. Scroll down again the selection until you see "UMD Auto-Start" and press X. At the right side will appear the options "ON" and "OFF". Select "OFF" and press O button several times to go back to main screen.
Insert your UMD. Now, try playing games from Memory Stick. You may have to turn off your PSP and turn it on again to finally play homebrew...
I hope this helps...
Jun 07, 2011 | Sony PlayStation Portable (PSP) Console
Why doesn't my psp multiplayer work? every time me and my friend try to play multi player against each other her psp doesn't detect my psp
You have to switch on the wlan to play multiplayer because it uses wlan to play the game or your psp's wlan is broken or your friends receiver is broken pal.
Dec 28, 2009 | Sony PSP-3000 Silver Console
My PSP cant play any games any more
update your PSP's firmware to 5.00 -thats my psp firmware
Jun 14, 2009 | Sony PlayStation Portable (PSP) Console
Well i have the samething happening to me with the psp's
Game sharring works on two PSPs, like if you are playing Grand Theft Auto on one psp and ratchet on another psp, however, you can't play two games at the same time with two PSPs on you.
But if you want to see how it works, you got to make sure that you are in a wireless area with a wireless access point and select the transmit function from an in-game menu then select "Game Sharing" from the other psp menu, once they recognise each other, a short download begins and the second player can then choose to play.
The use of RAM to store the games rather than on the Memory Stick Duo means that players cannot continue with the games after the PSP has been shut down or sent back to the "Home" menu - from which players usually access media functions and launch software from UMD."
Jan 06, 2009 | Sony PlayStation Portable (PSP) Console
Help!
You might have PSP stop reading UMD discs, First you will do some trouble shooting with what might be wrong with your PSP unit.
first is the Disc Spinning motor. This will not let The disc in the UMD spin. On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
2nd is something stuck in the UMD gear, try to clean the gear of arm of dust, plastic, soda, and even hair.
and at the last is the actual laser itself. It will not focus the laser to read the UMD disc.
Hopefully this help, Pls post back should you need additional information...!
Jun 01, 2008 | Sony PlayStation Portable (PSP) Console
Psp moving by itself
Hey, looks like your PSP may have one of these two problems. There are 2 screws on the backside of the PSP System on the side of the analog stick. If either of the screw is loose then the analog stick will move by itself.
Second problem is the Analog Stick itself has been damaged. You can replace these very easily if you are good with tools and electronics.
Bimmerhp
Jan 22, 2008 | Sony PlayStation Portable (PSP) Console
I cant figure this out
it is like as crash of psp system, If this is the first time you've used the Memory Stick Duo, you must format it with psp to create the proper PSP folder structure. Copy the music/audio files from your computer into the MUSIC folder inside the PSP folder on your Memory,
You can save and play music/audio on your PSP system in the following file formats:
MP3, MP4, ATRAC3plus, WAV, WMA. press triangle for Display or hide the control panel. you can visit http://www.us.playstation.com/Support/PSP/Music/s_psp_mu_CF.html for more helps. hope this helps.
Nov 06, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
57 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
