Question about Dryers
I have a maytag gas dryer Model # MD69316AWW and up to now worked fine. It now failes to heat. What should I look for in fixing this problem? Paparup
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: I have a maytag gas dryer Model # MD69316AWW and
You might have a bad 664532a.jpgignitor
or you could have a bad sensor751e797.jpg If either of these to partners in crime are open(no continuity) nothing will happen in the way of heat however the dryer will run. If those 2 are ok Next thing to look for i a blown duct fuse or open control themostat0b6e3ea.jpg
If these 2 check good then you might have a problem with those04fab08.jpg pesky operator coils, when these die they usually work a little bit the have to cool off and they work a little more, very aggrevating to diagnose.
I have a late model Maytag repair manual HERE Note: this is probably not your model manual but it gives an idea what to check for.
Posted on Mar 21, 2010
Gas igniter not glowing
The igniter may have failed while the other work was being done. Some igniters develop a hairline **** and fail.
Sep 29, 2017 | Dryers
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
I have a Maytag dryer,model# mdg2706aww. Its about 5 years old, was working fine then all of asudden it stopped getting hot completely. Need it fixed but dont have a whole lot of money. What part can it be...
heatman101
Jul 18, 2011 | Maytag MDG2706A Gas Dryer
Gas dryer dosn't heat properly
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jul 07, 2010 | Maytag MDG3600BW Gas Dryer
Mar 21, 2010 | Maytag Dryers
Dryer does not heat up.
Hello there:
normally on these units if the dryer was working ok and then suyddenly stopped heating your heating element or the ignitor (excitor ) has failed and is need of replacement
so i would start by having these things checked first by contacting a local repair man to do a evaluation on the unit and if kyou still have a valid warranty i would use it ok
I hope that this is very helpful for you
Best regards Richard
Nov 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag proforma gas dryer no heat
The model says electric and is listed as gas. If it is electric. Move all the settings (exercise the controls) If that does not work Turn both of the breakers off at your electric panel and back on. If one feels loose you know it may have tripped and you just reset it. Your drier will work fine now. Just turn it on.
Aug 12, 2009 | Maytag PYE2300AY Electric Dryer
Igniter works fine but there is no flame so therefore no heat
Replace the coils on this burner assembly. this will fix this issue you are having at this time.
The coils open and close the valves, which are responsible for gas flow. these coils are damaged.
May 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer won't heat up
i am having the exact same problem with this model as well just happened 4 days ago.
Mar 18, 2008 | Maytag Performa PAV2200
Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Oct 22, 2007 | Dryers
Dryers Logo
49 people viewed this question
Top Dryers Experts
