Question about Home
? faulty overheat function on shower
The overheat function on my Mira Sport shower has recently been coming on at lower temperatures causing the shower to intermittently run cold for several seconds.
  • 766 Answers
Check the in line filter in the inlet solenoid valve assembly. If there is crud collecting in the filter this will restrict water flow and the over heat protection will trigger to protect the heater elements
Posted on May 14, 2010
Hot water not coming through on a mira thermostatik 722 shower
Shower Doctor TV: How to Service Mira 722 & Mira 723 ...
? 15:26
https://www.youtube.com/watch?v=MnTfj-8vA_Y
Jul 5, 2013 - Uploaded by The Shower Doctor
George services a cartridge inside a Mira 723 shower. ... Until I watched this, I was stuck with a half dismantled valve, no waterin the house and a .... Fresca Verona Stainless SteelThermostatic Shower Massage Panel ...
Shower Doctor TV: How to replace a Mira Excel cartridge ...
? 5:29
https://www.youtube.com/watch?v=bvng57EMQCI
Jul 1, 2013 - Uploaded by The Shower Doctor
George replaces cartridge inside a Mira Excel shower. ... Hi, I have this model of shower and turning the temperature selector to the hot side turns the ... I just got the place so cannot rule out incorrect shower installation but Im not sure if its ... to those with a booster pump in the loft how to turn off the water.
Fault Diagnosis: Support - Mira
Jan 01, 2016 | Home
My Mira Jump electric shower will not change temperature when the temperature dial is operated, just stays hot, any ideas?
Is your cold supply to shower for some odd reason? How old is the device? warranty? persue that route. Customer service is usually helpful (they need to know about problems) .
Mar 08, 2015 | Home
Mira 88 manual mixer not supplying hot water.
You need a new cartridge for the shower located behind the handle.
Jan 26, 2014 | Home
Have a Mira Zest shower. Its about five year's old. Recently started to switch between extremely hot and very cold. Now only has cold.
I would suggest you google the Mira Zest and download the manual in PDFformat. From broosing it, it sounds like you had the temperature set too high, and that burnt out the element. But check the manual yourself and see if you agree.
But the Mira Zest is very susceptible to water pressure, so you might want to check into that also.
Jun 01, 2011 | Home
My mira sport is approx 6 years old .when switched on its hot for only 1 minute then goes cold
The Mira 416.41 - Thermal switch has gone bad this link shows where it is and you can order from here if you want.
http://www.showerspares.com/products/spare_parts/mira_sport_108kw
Mar 04, 2011 | Home
My mira sport shower when switched on runs afew seconds and stops, then when switched off runs afew seconds then goes off. pls can someone advise. thank you
detach the hose from the shower head and clean the filter screen and do the same with the shower head. When you have the shower head detached turn the water on to the shower and see if anything comes out into a towel or bucket.
Feb 15, 2011 | American Standard 1660.501 Sport Hand...
Mira Sport shower running luke warm
Your hot water must come from your coil in boiler and not from a seperate hot water heater - more then likely furnace hasn't been on for heating your house nor has it been on for any draw of hot water. You have to wait till it goes on and brings the water temperature up to your setting or get a hot water tank put in or a new type wall mounted gas instant hot water unit.
Mar 14, 2010 | Home
Shower goes cold after 5 mins
Sounds like you have got some elements out in the unit or you need to turn the heat up.
Jan 31, 2009 | Home
Does not stay hot long goes cold after 5 mins in my mira shower
This sounds like the elements or you just may need to turn the heat up. If it under two years old call the manu on the warranty. They make a good product so they should help you. I would check the heat setting first, though I doubt it is going to be the prob.
Jan 31, 2009 | Home
Home Logo
520 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
