Installation problems I am trying to install print workshop and my computer tells me "ecall method must be packaged into a system module". What is this and how do I find it?
    Sergeant:
    Champion:
  • 326 Answers
Sounds like U are trying to install from a bundled package not intended for Ur machine. Need more info to help.
Posted on Mar 31, 2008
How do I connect to an HP LaserJet 1020?
As the Laserjet 1020 not officially supported by the OS, you will need to download and install the HP Printer Drivers 2.11 package which include the Laserjet 1022 drivers, those should allow you printing using your device.
Install the package by following the Download below:
http://support.apple.com/kb/DL907
After completing the installation go to System Preferences ' Print & Scan and click the Plus sign,
Select the listed printer and click the Print Using drop-down.
Click Select Printer Software and then select the Laserjet 1022 which should be available now.
Complete adding the printer and try printing now.
GuruAid.com
Jun 27, 2015 | Apple MacBook Pro Laptop Computer with...
Icannot open folder, it gives an erro wiindows cannot find 'microsoft.vbs.'make sure you type correctly and try again
1. How are you sure that this must be because of window installer package?
2. Are you able to install any other softwares on your computer?
This happens if the scripting runtime filevbscript.dll is not registered correctly in the system.
Try the method 1 and check if you are able to install windows cleanup utility.
Method 1: a. Click on start button, type cmd. In the search result right-click on cmd and selectRun as administrator.
b. Type cd %windir%\system 32 (Note: there is a space between system and 32) and press enter.
c. Type regsvr32 vbscript.dll in command prompt and press enter.
d. Type regsvr32 jscript.dll in command prompt and press enter.
If the registration was successful, you should now see the following message:
DllRegisterServer in vbscript.dll succeeded.
e. Now right-click on windows cleanup utility setup file and select Run as administrator.
Method 2: Perform sfc scan on your computer.
Refer: http://support.microsoft.com/kb/929833
I would suggest you to re-download the java software and try installing it.
Feb 06, 2014 | Microsoft Windows 7 Ultimate for PC
I have connect usb cable and did all the instruction from manual and it doesn,t print i need help
1. Connect to a USB port on your computer, NOT on a hub. This might solve the problem.
2. Your computer hasn't found the printer drivers. Manually install them (download from Canon website) If when connected the printer does not show on your "Devices and Printers" panel, then the drivers have not been installed.
3. Try another USB cable in case it is faulty.
4. Make sure you have removed all transit packaging (if any) from inside the printer, and have set the ink cartridges correctly.
5. When you try to print, does a warning sign appear in your system tray? If so, do what it tells you.
6. If all else fails, read the installation instructions again, step by step.
Hope this helps.
Jan 27, 2013 | Canon IP2700 Inkjet Printer
How do i download missing firmware for ubuntu
Loading Missing Firmware As described in the section called "Devices Requiring Firmware", some devices require firmware to be loaded. In most cases the device will not work at all if the firmware is not available; sometimes basic functionality is not impaired if it is missing and the firmware is only needed to enable additional features.
If a device driver requests firmware that is not available, debian-installer will display a dialog offering to load the missing firmware. If this option is selected, debian-installer will scan available devices for either loose firmware files or packages containing firmware. If found, the firmware will be copied to the correct location (/lib/firmware) and the driver module will be reloaded.
note.png Which devices are scanned and which file systems are supported depends on the architecture, the installation method and the stage of the installation. Especially during the early stages of the installation, loading the firmware is most likely to succeed from a FAT-formatted floppy disk or USB stick.
Note that it is possible to skip loading the firmware if you know the device will also function without it, or if the device is not needed during the installation.
warning.png Support for loading firmware is still relatively basic and is likely to be improved in future releases of the installer. Currently debian-installer will for example not display any warning if you choose to load missing firmware, but the requested firmware is not found. Please report any issues you encounter by filing an installation report (see the section called "Submitting Installation Reports").
Preparing a medium Although in some cases the firmware can also be loaded from a partition on a hard disk, the most common method to load firmware will be from some removable medium such as a floppy disk or a USB stick. The firmware files or packages must be placed in either the root directory or a directory named /firmware of the file system on the medium. The recommended file system to use is FAT as that is most certain to be supported during the early stages of the installation.
Tarballs containing current packages for the most common firmware are available from:
Just download the tarball for the correct release and unpack it to the file system on the medium.
If the firmware you need is not included in the tarball, you can also download specific firmware packages from the (non-free section of the) archive. The following overview should list most available firmware packages but is not guaranteed to be complete and may also contain non-firmware packages:
It is also possible to copy individual firmware files to the medium. Loose firmware could be obtained for example from an already installed system or from a hardware vendor.
Firmware and the Installed System Any firmware loaded during the installation will be copied automatically to the installed system. In most cases this will ensure that the device that requires the firmware will also work correctly after the system is rebooted into the installed system. However, if the installed system runs a different kernel version from the installer there is a slight chance that the firmware cannot be loaded due to version skew.
If the firmware was loaded from a firmware package, debian-installer will also install this package for the installed system and will automatically add the non-free section of the package archive in APT's sources.list. This has the advantage that the firmware should be updated automatically if a new version becomes available.
If loading the firmware was skipped during the installation, the relevant device will probably not work with the installed system until the firmware (package) is installed manually.
note.png If the firmware was loaded from loose firmware files, the firmware copied to the installed system will not be automatically updated unless the corresponding firmware package (if available) is installed after the installation is completed.
hope this helps
Jul 17, 2012 | Computers & Internet
Cannot re- install fix it 10 tells me a version of fix it needs to be removed first when i try to uninstall it tells me it cannot find " installation package" ( WIS5158ect...) Even when i try...
Hi headshotbill
Install RevoUninstaller from http://download.cnet.com/Revo-Uninstaller/3000-2096_4-10687648.html
Select the advanced method ( point 4 ) and when you get message " cannot find installation package "
, ignore , click next for a full registry cleaning . It's all automatic and free .
When done , you will be able to install your program .
Best regards ,
fanaudi .
May 30, 2011 | Avanquest Fix-It Utilities 10...
When I try to install my 2010 Print Workshop it will not install. This is the reason why: Error 1001 Exception occured while initializing the installation: System. Configuration....
win xp or win 7 could be a compatibility problem so check the operating systems as well as the bit requirements (32/64)
also check that a security program is not causing a problem
Nov 19, 2017 | ValuSoft Computers & Internet
Is there a users guide/manual for print workshop 2010
The manual for Master Clips Print Workshop is located on the CD. To access the manual, double click on My Computer then RIGHT click on your CD-ROM drive and choose Explore.
Double click on the Manuals folder. The manual file name is Mcpub.pdf. If you already have an Adobe Acrobat Reader installed on your system you should be able to simply double click on the file and it will launch the Reader and you will then be able to view or print the manual.
If you are not able to open the file you simply need to install the free Adobe Acrobat Reader by double clicking on the Setup.exe file located in the Manuals folder. After the Reader is installed, double click on the Mcpub.pdf file to view or print the manual.
Aug 22, 2010 | ValuSoft Print Workshop 2010 Full Version...
Microsoft Word 2007 would not allow me to insert clipart into the document I created.
hi,
Please verify that your office installation contains the cliparts modules installed on your system, else, you need to re-install and customize the installation to include clipart module as well.
Need some more info, if the problem still persists:
I got your problem but to get into the root cause I'll need more details viz.
1. Installation type of your Office 2007 package (typical, full, custom); just to make sure that you have cliparts installed with office package.
2. It would be more easy for us, if you can provide us the screen shot as well of the problem.
Mar 11, 2009 | Microsoft Windows XP Professional
Computers & Internet Logo
David Payne
David Payne
