Question about Sony Playstation 3 (PS3) Console
Keeps switching off goes from red led to green to yellow to flashing red
    President:
  • 1,139 Answers
What you are referring to is called the Yellow Light of Death (YLOD). This indicates a general hardware failure normally due to overheating. When these PS3's were produced Sony decided to use lead free solder. The problem with lead free solder is that it is not as flexible as leaded solder but it is cheaper and more environmentally friendly. When the console gets hot and cools down hairline cracks appear within these solder joints and a good electrical contact cannot be made. This then causes the console to fail. It could be on a number of different components including the CPU, GPU or memory. There is a temporary cure that may or may not work but ultimately the console will need to be repaired professionally or replaced. As it is out of warranty Sony will not replace it but will offer a refurbished unit for around £130. If you look on Youtube for Yellow light of death fix there is a way that you can re-heat the solder joints using a heat gun but if you are not confident taking apart electrical items then this really may not be something you want to try.
I am sorry I cant give you any better news but unfortunately it is a very common problem with the PS3.
Hope this helps and thank you for using FixYa
Posted on Sep 13, 2010
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
My air hogs switchblade's controler keeps turning off while its charging whats wrong?
always turn the switch blade off when charging it or it wont charge it and the red light goes off to save batteries on the controller..when done right it flashes red..only when it's flashing red and green will it be charged
Dec 31, 2010 | Master Heaters Air Hogs Switchblade Black...
My blackberry 9700 keeps vibrating and flashing a green light every few minutes
Hello you may have enable your led lighting on the blackberrry . Blue ii s the bluetooth. red is charginf green is data coming down. Yellow ie a warning that the bateery charge is low.you go into options and then scroll down do you want to enable led lighting just switch it to off. OKay hope this can help you. You can also do a battery pull and reset the phone afterwards.
Nov 06, 2010 | RIM BlackBerry Bold 9700 Smartphone
Led goes green then flashes yellow then keeps flashing red
You may be suffering from the dreaded yellow light of death. Follow this link and it should give you some insight. If you have any other questions let me know.
http://ezinearticles.com/?How-to-Fix-Ps3-Yellow-Light-of-Death&id=2583044
How long have you owned the ps3 and how long have you had this problem?
Thank you and good luck,
Lee
May 07, 2010 | Sony Playstation 3 (PS3) Console
When turning it on the LED goes from Red to Green, then I get 3 short beeps and the LED flashes Red
if it flashes yellow to you have ylod. google it. or without yellow its just overheated. to much MW2 right lolz
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
This is the equivalent to xboxes red ring of death.You can try to replace the inner cooler or if it is still under warranty then send it back to play-station.
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
Power/standby led beeps red light 6 times
crazyford359
Your Thermal fuse is out. I just replaced mine, the part is only $4.85 on Sonyparts.com. Ordered (2)
Feb 16, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv keeps turning itself off
You most likely either have a faulty power supply or high voltage transformer that is failing. You can test them both with a voltmeter or multi-tester. The capacitors on the newer sets seem to overheat and burn out quickly
Oct 10, 2009 | Televison & Video
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Well when I turn on my ps3 the green light turns into a yellow light some people call this the yellow light of death after it goes yellow it turns into a flashing red light I try to repaet it but it keeps...
well yes obviously the flashing red light means that if u do not turn off ur PS3 it will die. but depending on how long u have had ur PS3, it may be becuase the life span is almost over.
if u have not had for a couple years it is most likely a manufacturing error
u should send it in to sony before the warranty is up and have them take a look at it
Jul 25, 2008 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
29 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
