Hi, There is nothing much that can be done to speed up the system as it can not go beyond 1GHz Processing speed, but several operating system tweaks and some hardware upgrade could make a little but notable difference. As for Hardware, you may increase the RAM. You can upgrade memory on ECS Elitegroup Computer G320 upto a maximum of 1.0 GB (The ECS Elitegroup Computer G320 takes the PC2100 DDR SDRAM SODIMMs
Memory) Secondly, You may increase the size of PAGE FILE, uninstall unwanted software, Remove unwanted start-up items, Clean Junk Files/ Temporary files, De-fragment the Hard Disk to achieve the maximum speed and performance that EliteGroup G320 PC can give.
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
Insert the recovery disk. Restart the computer, and press the "F11" key.
Press the "F" key to "reinstall factory settings." If your computer's operating system is damaged, you may only see "perform a full system recovery" as an option. In this case, press "R."
Insert any disks if prompted by the restoration program. Otherwise, permit the computer to restart as needed.
- go to device manager
right click computer if your using win 7 and click properties click device manager on right side
- try to uninstall the keyboard driver and restart your system
- hope this works
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
Most laptops either use the [F2] or [Del] key to access the BIOS. If not, it could be either [Esc], [F1] or [F12]. You might also try [Ctrl]+Key, [Alt]+Key or [Shift]+Key combinations if the previous keys don't work.
Make sure you don't get past the initial POST screen when trying the keys.
