Back to:
Tags:
Frigidaire FRS26ZSG
Frigadaire freezer cold but fridge compartment is... (by 2 users)
posted by bigbooka53 on Mar 30, 2008
Model FRS20ZRG side by side about 8 years old. The bottom vent keeps forming ice frost on the coils at the back bottom of the freezer. I have unplugged it for 20-30 minutes, took the protective panel off the back bottom wall of freezer, used a hair dryer for 30 monutes or so to defrost coils, plug unit back in and the air flows again in the refrigirator (top air vent in back). But within 5-7 days it goes warm again, no air flow at all, and bottom coils in freezer are frozen again. What could it be?
Thanks Rico
Comment by bigbooka53, posted on Mar 30, 2008
Fridgidaire Model # FRS20ZRG (Side By Side) about 8-9 years old.
Oh Sorry. It's frs20zrgd7
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by neddamk, posted on Sep 24, 2008
Same model (FRS20ZRGW9), same age, same problem! Repair techs have replaced both the timer & the defrost thermostat...also compressor is hot to touch...need a new compressor or a new refrigerator?
Best Solution
FixYa! (100)
tech17
Rank:Guru Guru
Rating: 88%, 1052 votes
i need the complete model number to narrow it down they still make the frs20zrg to this day the last two numbers like frs20zrgwo or frs20zrgw9 is what will tell me what kind of defrost system it has the serial plate is in the fridge side up by the light bulb or on the left hand side or right hand side of the fridge compartment up near the top sorry to be a bother but its necessary
Comment by tech17, posted on Mar 30, 2008
look open the freezer door pull the lower kick plate off look for a small little hole there its a mechanical timer model should be close to the wheel in that hole will be a plastic piece open the freezer door you will hear the fan running in the freezer take out the four or five screws on the lower panel where you keep seeing the frost and remove it you will see a silver honeycomb looking piece that's the evaporator on one of the tubes will be clipped a silver dome looking piece with two wires on it that's the defrost thermostat now turn the timer with a screwdriver that's the piece in the little hole slowly to your right till you hear a click and the fan stops in the freezer now as your turning it it will make a ratchet sound you want the click and the fan to stop look at your watch and note the time then wait about 5 minutes and look at the heater to see if its on if its all frosted up the frosted should look all watery if the heater is on then just let it run if not then reach up and turn the freezer control to the off position then un plug the two wires on the defrost thermostat and take the two wires that you unplugged the thermostat from and plug them back together and turn the freezer control back on and wait stay there and watch the heater come on let it defrost the evaporator if the heater comes on when you do that .that means the thermostat is bad if the heater comes on without you having to by pass it that means the timer is bad if you do all that and the heater does not come on then the heater element is bad now its going to get red like an oven and pop and sizzle but don't let it freak you out now if you had to by pass the thermostat and the timer cuts the compressor on before the frost is all clear just turn the timer around again till the fan cuts off and the heater will come back on if you by passed the thermostat then when all the frost is melted then reach up and turn the freezer control back off and reconnect the thermostat.Now after about 30 mins after turning it off the timer should cut back on if its not bad when you change the timer back out the two screws reach under the fridge and turn the timer and its shield till the screws are in the removal position when the timer is loose remove the shield and unplug the timer plug your new one back in then put the shield back on and back where it goes now id recommend changing both the timer and the thermostat as they fail pretty close together the stuff i described above is to make the unit defrost to save your food with out having to use your hair dryer also when all the frost is melted at he bottom of the evaporator on the right hand side is a hole in the cabinet that has to be clear of frost for the fridge to cool properly now any time during this defrost technique if you have a problem turning off the freezer cold control will turn off the defrost system too if i can be of help or you need to know something just reply to this post
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Frigadaire freezer cold but fridge compartment is warm:
I don't want to Accept this solution
Can you Help with these Refrigerators problems?
Frigidaire FRS26ZSG
i have problem on lg Double Door refrigerator upper...
Frigidaire FRS26ZSG
How does one access the oven door to clean the glass. ...
Frigidaire FRS26ZSG
I am having the same problem. I don't believe that this...
Frigidaire FRS26ZSG
washing machine does everything expect after water drains,...
Frigidaire FRS26ZSG
cold air from freezer not getting to refrig........ cold...
Loading problems.
Repair Service
Find Refrigerator Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
