Question about E-Machines eMachines Monitor E15T4
My monitor wont switch on staright away just makes a popping noise then turns off
  • 11,361 Answers
I would not plug it in the outlet any more, you need to open it up and inspect the inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 15, 2010
Brightness screen keeps popping up how do I make it stop?
Sounds like the tactile switch is faulty. You know on a telly remote, you press the button to select the channel....well the switches on the monitor are the same. Behind the switch is a rubber contact which has a conductive contact which you must not clean( as such) it sounds like this is in permanent contact with the conductive elements inside it. As the switch is probably only 5mm x 5mm, it is a tricky DIY job to put a new tactile switch in, but easy for someone who does electronics.
Nov 24, 2013 | Sceptre NAGA II X20WG 20 inch LCD Monitor
Brake lights stay on, even with the keys out.
It's probably the switch. Crawl up under the dashn and look for a wire running near the top of the brake pedal stalk. Look reall close at it, many switches have an adjustment to control how far the pedal must move away from the switch before the plunger extends which turns on the light. It's possible the switch has shifted or it may be broken/cracked. If your car is still under warranty take it to the dealer and make them fix it, if not the switch shouldn't be too much at a local autoparts store. They're pretty staright forward to install.
Jul 12, 2011 | 2002 Ford ZX2
Tail lights stay on when 2000 nisson is off
It's probably the switch. Crawl up under the dashn and look for a wire running near the top of the brake pedal stalk. Look reall close at it, many switches have an adjustment to control how far the pedal must move away from the switch before the plunger extends which turns on the light. It's possible the switch has shifted or it may be broken/cracked. If your car is still under warranty take it to the dealer and make them fix it, if not the switch shouldn't be too much at a local autoparts store. THey're pretty staright forward to install. hope help.
Jul 08, 2011 | 1992 Honda Civic
try this: unplug monitor and detach it from the PC . Then push in the monitor ON button and hold it for at least 60 seconds. Replug it and it likely/may work --you are basically resetting it.
Mar 21, 2010 | E-Machines eMachines Monitor E15T4
3232 polaroid tv,makes popping noise when i turn it on.
this sounds like the problem most LCD tv's get with swelled up capacitors in the power supply board. look for circular cylinder shaped parts rapped in plastic with writting on the sides, and metal tops, if the top is rounded over, not flat, it is bad. replace them.
Jun 25, 2009 | Polaroid FLM-3232 Television
Craftsman Tiller makes loud, shrill, squealing noise when tilling
Noise comes and goes sound like metal on metal not a belt squealing
Apr 03, 2009 | Craftsman Garden
Computer making noise
Monitor clicks, pops, or makes other noises. Issue: Monitor clicks, pops, or makes other noises.
Cause: This issue could be caused by any of the below possibilities:
  1. Monitor degaussing.
  2. Monitor changing resolution.
  3. Monitor syncing with the video card.
  4. Monitor warming up.
Solution: Noise when turned on or off It is normal for standard computer CRT monitors to make a click, pop, crackle, hum, buzz, or other type of noises when they are first turned on or turned off.
Noise when monitor goes into standby mode When the monitor enters a "standby mode" or "power savings mode" this is similar to the monitor being turned off. It is completely normal for the monitor to make a noise when the monitor enters this mode.
Noise when opening Microsoft Windows or other operating system or when opening a game When a computer opens its operating system, for example, a computer opening Microsoft Windows or when a user runs a computer game it is very common that the monitor will need to switch its resolution of the operating system or game. When switching resolutions it is normal for the computer monitor to make some type of noise and/or for the computer monitor to flick or flash.
Noise during normal operation If the computer monitor click, pops, or flashes while it is being used this is not normal operation. It is very likely that the monitor may be failing or a component within the monitor has already failed and could also potentially be a fire hazard. We highly recommend that the monitor be repaired, replaced, and/or looked at by a qualified technician.
Additional information:
  • See document CH000302 for additional information and other noises that may come from
Jan 16, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Menu keeps popping up
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Nov 04, 2007 | Acer AL1912 19" LCD Monitor
Monitor sounds?
It happened that to me last year. After 2 weeks of cracking sound symptoms, my monitor begun to blackout - no video signal but the indicator light is still available. I checked it inside using my tester, one of its transistor was burned-out. I tried to replace it and its working up to now. Possible cause of this is probably overuse of monitor without proper ventilation causing electronic components to overheat. Try to bring it to an authorized TV repair man in your local area for proper diagnosis - Don't try to fix it yourself. He's the right expert to that.
Apr 04, 2007 | Kogi L7CH Monitor
E-Machines eMachines Monitor E15T4 Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
