Question about Logitech X-540 Computer Speakers
Fuzzy & crackly
These x540 worked great till one day out of the blue speakers got fuzzy an crackly an the left ones are louder then the right ones....nothin out of the norm happend to them.... the sub still bumps very loud...i have an old altlc sub an speakers so i hooked up each of the x-540 speakers to see if it was them (if they where blown) and its not the speaker...there crystal clear....any advice
    Scholar:
  • 46 Answers
Its the problem with the ac adapter which you are using might be your adapter is not working properly the adapter consists of step down transformer which is not very much durable some times so change the adapter and see if u dont have any adapter to connect just the direct wire to the supply then the adapter will be inside of woofer or the speakers change that adapter check this it works
Posted on May 09, 2008
SOURCE:
Nissan Maxima 1997 Stereo not turning on at all!!
Here is a list of radio wiring harness wire color codes and what they do. I have given both with and W/O Bose.
Nissan Maxima Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Pink/Blue
Radio Ignition Switched 12V+ Wire: Blue/Black
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Blue
Radio Dimmer Wire: Red/Orange
Radio Antenna Trigger Wire: Black/Red
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
1997 Nissan Maxima with Bose Stereo Wiring Diagram W/Bose
Car Radio Battery Constant 12v+ Wire: Pink/Blue
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Each speaker has its own amplifier located at each speaker.
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Pink
Right Rear Speaker Negative Wire (-): Blue
Mar 27, 2017 | 1997 Nissan Maxima
Why do my right speaker inputs cause fuzzy sound?
HI KYLE...
I think I have experienced this problem before with my Sony stereo set. It could be a sign that your receiver's amplifier is giving out. Best that you can do is bring it over to an audio repair shop for a checkup. If my suspicion is right, you're gonna have to replace it with a new one. Don't worry, amplifier chips are not that expensive.
And lastly, when any part or component is replaced, be sure to ask the technician to give it to you. You can keep it for your reference.
BOB (June 23rd '12 3:20am)
Jun 14, 2012 | Sherwood RX-4109 Stereo Receiver Black
I have the logitech z-2300 just the other day the
mine did the same thing today , i just bought these new 2 weeks ago . the black prong speaker works in both ports ..
the yellow prong speaker is the one with the malfunction .
it works sometimes but when i turn up the volume louder it dies out .
Feb 23, 2010 | Logitech Z-2300 2.1 Computer Speaker...
The mains transformer in my Logitech x540 has blown (oc on the primary). I've taken it out and its a simple single coil primary and secondary, but there are no markings on it to indicate the secondary...
You would need to rewind the coils.Do not try to do it by yourself if you have no idea what you are up-to...this time it was transformer next time it could it could be your circuit.Take it to a professional,the charges won't be much.
Good Luck.
Dec 27, 2009 | Logitech X-540 Multimedia Surround Sound...
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
Front left speaker is louder than the right one Replaced my altec lansing speakers because left speaker was louder than right. They were about 6 years old, replaced with Logitech 2300. Same problem. If I...
JUST ADJUST THE BALANCE IN THE VOLUME CONTROL, YOU CAN FIND IT IN THE CONTROL PANEL OR AN ICON AT THE BOTTOM RIGHT OF YOUR SCREEN, THE RIGHT NEXT TO THE CLOCK.. PLEASE VOTE FOR MY POST
Oct 29, 2008 | Audio Players & Recorders
Sony str-de875 amp. one speaker louder than the rest
hi. i have a sony amplifier. i plug the speakers in like normal. i turn it on and the right side speeker works fine. but you half to crank it up all the way just to barely hear the left speeker. we switched speakers and its still the same effect. we think its the amp itself. we tried our balance settings. it was fine. but right now its just playing one speaker louder then the left one. can anyone help me?
Apr 03, 2008 | Sony STR-DE875 Receiver
Fuzzy Speakers
Suggest that the speaker cone is damaged
Nov 15, 2006 | Dell A525 Computer Speakers
Logitech X-540 Computer Speakers Logo
213 people viewed this question
Top Logitech Audio Players & Recorders Experts
Ekse
Michial Gueffroy
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
