Question about Baby Gear
1983 gmc vandura 2500 firing order
My van was running rough and me and a friend decided to do a tuneup on it. we changed rotor cap pcv valve spark plugs spark plug wires air filter. guess what it runs worse than before. iam pretty sure we messed up the spark wires . could somebody give me the firing order please. 1983 gmc vandura 2500
Odds on the right side even on the left 1,3,5,7 on the right 2,4,6,8 on the left font to back
Posted on Dec 16, 2011
  • 50 Answers
How many cylinders 4 cyl 1342 or 1243 6 cyl 134652 hope this helps
Posted on Mar 31, 2008
SOURCE:
1995 toyota tacoma 2.4 liter, cranks but no start, got fuel, got air, no spark. changed cap, rotor, and coil still no spark.
did you get the plug wires on correctly. check any electrical connections you may have undone. check for codes. it may be coincidental that you lost spark and a sensor may have gone bad.
Sep 25, 2015 | Toyota Cars & Trucks
Why does my 2.2 GMC skip or miss while driving?
If you have the same problem after the tuneup as before you may have an injector problem or possibly a mechanical one. Ie. valves, timing chain, valve train.
Jul 20, 2014 | 1990 GMC C1500
Rough idle 95 astro van, I did a full tune up , plugs,wires,cap, rotor,air filter,and fuel filter and cleaned egr vavle.
I actually had to replace my EGR valve and the gasket. I clean the valve well and reused both. I don't think the gasket sealed well enough though. So I went ahead and got a new valve, gasket and changed them. It runs a lot smoother now.
Dec 14, 2012 | 1995 Chevrolet Astro
1997 gmc yukon backfiring and running rough
need to check engine compression, possible you have a burnt valve, also double check your firing order on plug wires on dist. cap
Sep 03, 2012 | 1997 GMC Yukon
Died while driving and now will not start. getting fuel and fire 1995 GMC Vandura just stalled while I was driving it. It won't start now. any ideas what it may be?
I would bet first to check and change would be cap and rotor and coil. Lack of proper spark at proper time is the main issue, that or the timing chain jump a tooth due to age and wear.
Jun 03, 2010 | 1987 GMC VanDura
I followed the firing order installing a dist cap on a 91 camaro and still running rough What do I look for now
check plugs -plug gap-vacuum leak-fuel mix-fuel pressure-timing-pcv valve-egr valve-air filter-oil sludge build up-problem in heads[valves adjustment-burnt-weak springs if only changed wires do a complete tune-up and do a compression check
Mar 14, 2010 | 1991 Chevrolet Camaro
I want to replace spark plugs (8) and wires on my '84 GMC pickup
get a 20 dollar haynes or chiltons manuel and find the module and coil. always change the ignition module and coil every 4 no more than -5 years to be safe.
Feb 10, 2010 | GMC Sierra 2500 Cars & Trucks
Rough accleration through 2nd gear
Had a loose Distributor cap and spark plug. Changed out the plug wires anyway and truck runs great.
Jun 24, 2009 | 1989 GMC Sierra
Baby Gear Logo
182 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Marvin
Marvin
john h
Are you a Baby Gear Expert? Answer questions, earn points and help others
