Question about Nextar MA168 (128 MB) MP3 Player
Need driver for Nextar MA 166 2 GB - Nextar MA168 (128 MB) MP3 Player
  • 10,421 Answers
Can't get my nextar MA 166-200 MP3 player to work with Windows 7
Hi robertdmoone...
Downloading Music to MP3 Player
1...You must download and install Windows Media Player 11 on your computer.
NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11.
If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10.
2...After you have downloaded and installed Media Player on your computer.
3...Open Media Player on your computer.
4...Install all your music into Media Player that you want to install on your MP3 player.
5...Plug in your MP3 player to the computer using your Data/Sync cord, be sure that Windows Media Player is on.
6...Media player should recognize the MP3 player and sync with it.
7...After it is sync'ed with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player.
Please take time to rate me four thumbs up.
Sep 03, 2011 | Nextar MA166 (2 GB) MP3 Player
I have a GB Instruments GMT-19A. I want to measure current under 500ma. Scale selections are 500ma, 50ma, and 5ma. The scale readings include 250, 50, 10. What scale reading do I use to read the...
You would use the 500ma range to read anything that is under 500 ma. If the reading comes up below 5o ma, then you can disconnect and change the range to 50 ma. I say disconnect before you change the range because it can damage the instrument otherwise. ie: do not use the switch to change the range while it is already connected in circuit and measuring in progress.
Remember that to measure current, you have to have the meter in series with the load and the supply.
Oct 08, 2017 | Gardner Bender GB Electrical GMT-19A 19...
I have a Toshiba HDD2190 C DC +5V 0.7A 40 GB Laptop harddisk which when I plugged into USB drive (by using a USB cable), WIndows XP Profesional detect it but I can't find it's Partitions in my computer. In...
In general, you need to install the correct drivers for the enclosure, not for the hard disk. Seeing as you have XP Pro, this is probably unnecessary though.
Also, 0.7A is 700 mA, and this exceeds the USB port maximum current which is 500 mA.
Most (not all!) laptop drives will run even if under a slight undercurrent, but this depends on USB port electronics and enclosure electronics.
Chances are that you won't be able to run the disk unless you plug it into an externally powered USB hub supplying at least 750 mA per port. The 100-500 mA supplied by your PC's USB port is enough to power the enclosure electronics and the host controller, but not enough to get the HD to spin properly. As a result, the HD can not be initialised and the enclosure will report an error.
Some hard disk enclosures come with a "USB Y Cable" or "double power cable" which joins two USB ports to get double the current, and can support HD up to 1.0A. If your enclosure comes with one of them, try that first.
Nov 02, 2009 | Toshiba (HDD2190-50PK) 30 GB Hard Drive
Is there a way to ''hack'' the nextar ma 166-200 to randomize play?
hi yumpfan,
I personally don't think that one is able to modify the player's firmware in the desired way, there is no button to it, too.
Just too small. Please think about purchasing another player if you wish to have such function.
Good luck
Sep 07, 2009 | Audio Players & Recorders
Nextar MA 166 MP3 Won't Charge
You have to install the software for the mp3 player BEFORE connecting the mp3 player to the computer, or else Windows XP will override the native drivers. That particular Nextar is not compatible with Windows Vista, so you may have a problem if you have a newer computer.
-Tha Mp3 Doctor
Jan 24, 2009 | GPX ML648B MP3 Player
STMP3500 driver for PhilipsGogear 1 gb
The driver is installed when you install the Firmware Manager software on the product CD.
The player will show as STMP3500 when it is in recovery mode (usually caused by corrupt firmware)
Install the Frimware manager.
Connect the player.
If asked for a driver let Windows search automatically.
If you get a Signed Driver message just click ok to continue.
Run Firmware Manager and follow the on-screen prompts, and all should be well.
Feb 27, 2008 | Philips SA1200 MP3 Player
Driver for mp3
MD299iCD 1GB MP3 player
Jan 21, 2008 | GPX M2104 MP3 Player
Open Questions:
See all Nextar MA168 (128 MB) MP3 Player Questions
Nextar MA168 (128 MB) MP3 Player Logo
489 people viewed this question
Top Nextar Audio Players & Recorders Experts
 Grubhead
Grubhead
topcat7736
Level 1 Expert
Joseph Hoffmann
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
