Question about Vivitar (1607225) Telescope
Trouble focusing Vivtar telescope
I have pointed my telescope at the moon and the only way I can get it to focus (so that I can see the craters) is to focus it all the way out and then remove the lens and pull it back out a little farther. If I don't pull the lens out it is still not in focus.
  • 3,186 Answers
Put the diagonal into the telescope, DO NOT use the 2x barlow if you have one. Put the eyepiece with the largest number written on it into the telescope and try again.
Read my TIPS on my profile page.
Posted on May 16, 2010
We have a celestron 114AZ telescope. we cannot see anything with it. why?
Most problems will be overcome by reading and absorbing the instruction manual.
Assuming the telescope is in good order, it must first be pointed at a light source using the spotter scope and then aligned using the lowest power eyepiece before fitting the high powered eyepiece...
You also should be in very low light conditions.
May 28, 2017 | Celestron Optics
How to focus on the moon
Raymond, Telescope aiming and focus instructions. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Use Telescope
http://members.iinet.net.au/~champas/pdf/tips/how%20to%20use%20your%20telescope.pdf
Adjusting your telescope
Jul 21, 2016 | Optics
Do i need anything special at night table top telescope i can not see anything
All telescopes have very small fields of view-- it must be pointed directly at the object in the sky or you will not see anything. Simply put the eyepiece with the largest number written on it into the focuser-- then during the day time practice focusing on a distant object like a building or telephone pole.
The moon should be your first target at night.
Aug 14, 2011 | Bushnell Voyager 78-9470 (470 x 60mm)...
I have had this model for years and I had it focused on the moon once and have never been able to get any of the three viewers to see anything? Is there something I can do to ?
Objects in the sky are tiny-- smaller than the tip of your finger held at arms length. If you can focus on the moon and see the craters nothing is wrong except you do not know how to locate objects in the night sky.
Download this free star chart --
www.skymaps.com
and locate a local astronomy club and the members will help you.
Jan 12, 2011 | Meade Polaris 114EQ-D (36 x 114mm)...
I dontknow how to look through it andfocus on a star,or moon
Hi Joe, I'm Mark.
The small scope on top of your big scope is called the "finder" scope. Probably 2X or 4X. It should have cross hairs in the view. Find the moon with it. It will also require focusing but since the moon is bright, you can get an idea where it is in the lens by that.
Next. Find the LOWEST power eyepiece to insert into the lens holder. And rotate the focus knob.
Hopefully, you will see some bright blurry thing and then you can focus on it.
After you get it in focus, put on a more powerful lens and look at the craters on the moon.
Note: You will need to adjust your telescope to the earth's rotation. Your scope should have
instructions for accomplishing this.
Hope this helps,
Best, Mark
Dec 28, 2010 | Tasco 200x50mm Refractor Telescope
Cant see any thing
Did you remove the lens cap? If the scope is like the picture in your question this is a REFLECTOR style telescope. It has a mirror in the bottom and a smaller secondary mirror under the focuser. The FOCUSER end is pointed UP. as in the picture above.
Can you focus on a distant object during the day time? Use the eyepiece with the largest number written on it and DO NOT USE the 2x barlow if you have one. Try focusing during the day time. If this works your telescope is OK. Then try the moon at night as your first target.
If you can see the moon up close all is OK.
Jun 18, 2010 | Celestron Advanced C10-NGT (600 x 254mm)...
The telescope is designed to use the diagonal - it adds the necessary length to reach a focus point.
Mar 21, 2010 | Vivitar (1607225) Telescope
I am 9 can't see out of my galileo 700x60 telescope what do i need to do
there are 3 types of telescopes:
1)refractor, uses lenses
2)reflector, uses mirrors
3)catadioptric, uses both
try this and practice doing this during the day time, it's easier.
get your eyepiece, the one with the highest number on it (# mm); this is your lowest power eyepiece, always use this first (wider view and easier to see where you're pointing it), and place it in your telescope.
next, use the focusing knob to focus on a target (a faraway tree, lamp post, etc.). once you have it focused, and if you want to get a closer look, get the next highest number eyepiece and refocus on the target. this is how you change magnification.
if you have a barlow lens (2x or 3x) this will also change the magnification by 2x or 3x without having to buy other eyepieces, although you can still buy more.
put it together in this order:
eyepiece-->barlow lens-->telescope
use the star diagnal for land viewing.
if you have a reflector telescope,
the open part of the telescope tube next to the focuser points to your target. focus it the same as above.
oh, and sometimes, with refractors, you might have to use the
45 degree or 90 degree diagnal to focus the telescope.
and google how to use a telescope. there's nice observing tips :D
hope this helps :D
oh, and check out the moon at night. it's a very nice target.
best time to observe the moon is when it's not full.
you gotta check out the 'terminator' (area on the moon where the light and darkness is separated.
Aug 12, 2009 | Galileo 700 x 60 Refractor Telescope
How do I focus on the moon. Model 1400150. I have been gifted this telescope. Tried to focus on moon. Dont know how. Took big cap off end. Looked throughscope on top of large cylinder. Tried to focus...
first, use the lowest power eyepiece, that's the one with the high number on it with 'mm' after the number.
for a refractor telescope (uses lenses), you might have to add a diagnal lens (either 45 degree or 90 degree, whichever one you have) to focus on an object.
attach it in this order:
low power eyepiece-->diagnal lens-->main telescope
for a reflector telescope (uses mirrors, a telescope with a big tube with a mirror at the bottom and a focusing knob on one side of the tube). the open part of the tube points to your target.
hope this helps :D
Aug 07, 2009 | Celestron Optics
Vivitar (1607225) Telescope Logo
148 people viewed this question
Top Vivitar Optics Experts
Clint Collins
Level 1 Expert
Are you a Vivitar Optic Expert? Answer questions, earn points and help others
