Philips 60PP9202/17F.....The convergence is out of whack... was able to partially line up the red....can only move from left to right with compatiable remote...can't move up or down..Don't have the manual for the TV. I need to figure out how to line up the red and green...Although, there's not a reference for the green..only the red and blue....Hope someone out there can help.
  • ready6six Dec 01, 2008
    do i pull the convergence ic's out, or do i pull the whole aluminum panel out along w/ the ic's? thank you
  • 8,617 Answers
You need to replace the convergence ICs they are located on the large aluminum heat sink on the circuit board on the left. Either STK392-110 or STK392-120 are used in that chassis. And you can order them at this link and they provide free step by step instructions with pictures so you can do the repair yourself in about an hour. Heres the link. Just look for your stk numbers under the convergence IC section you will need to replace both of The ICs. If you need to know what they look like heres a pic.
http://servicemanuals.vstore.ca/Philips 60PP9202/17F.....The convergence is out - a2d36f4.jpg
Posted on Mar 30, 2008
I cant line the red and green crosses up left and right but i can move them up and down. I have two pics in diferent colors
The tv have a convergence problems,it is dead.Tv have colors lines like R,G,B mis alignments,have colors pictures shadows or 3D pictures look alike?Yes,than the tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
May 09, 2011 | Philips Magnavox 51MP392H Rear Projection...
Philips 43pp92 blue will not converge
STK392-120 is convergence correction amplifier.. the problem is the convergence circuit... try to check the small Valuie electrolytic capacitors or High value resistors! maybe the said parts is in change Value... used a ohmmeter tester to find the chenge value parts!.
Nov 05, 2007 | Philips 43PP9202 43" Rear Projection...
I have a green and red shadow on the words. It appears towards the top and bottom of the screen.
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the cursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It takes time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
You can pay somebody to do it, but may cost you like 100.00 or do it yourself, it is very easy just tedious and time consuming. If you have the auto convergence than your golden because this is the easiest way to "reset" the TV.
Since it is 4-5 years old it's a 50-50 chance that the TV has the auto feature. Good luck and if you still have the owners manual, I would read up on the convergence section in the manual.
Take in solving the problem.....
Jan 12, 2011 | Philips Magnavox 51MP392H Rear Projection...
The left side of the picture is distorted with a double image. The right side is fine. As things such as the stock symbols on CNBC scroll across from right to left on the screen, they start out looking...
Hope this will help in solving the problem....
Jan 12, 2011 | Hitachi 51GWX20B 51" Rear Projection...
I am able to adjust all the color convergences except red. Won't line up. Any helpful ideas would be appreciated. Also, if I have to replace an ic, typically how much does that tend to cost? Can I do it or...
The two convergence IC's need to be changed on the convergence board, and also check the low ohm resisters that might have change resistance on the convergence too. The red and blue should move up and down and left and right. The green is sationally.
Nov 11, 2010 | Philips 60PP9202 60" Rear Projection...
I have a Philips 46PP9302 and can't find the Quick Setup guide. I'm wondering if it is located on-line. We moved our tv and want to recalibrate it.
http://www.retrevo.com/support/Philips-46PP9302H-TVs-manual/id/278ci462/t/2/
The above link should take you to the location where you can view all the parts of your models manual. Select the area of interest and rad onlinje
Please rate my help++++Thanks for using FIXYA
Nov 24, 2009 | Philips 46PP9302 46" Rear Projection...
Philips 60" hdtv. Convergence problem
what is the model number of your set and I will be able to help you with your problem.
May 07, 2008 | Sony KP-41T65 41" Rear Projection...
No horizontal red convergence control
Probably the red convergence output IC has failed. The chip is basically a stereo amplifier that serves as a horizontal amplifier and a vertical amplifier. I suspect the vertical part has failed and is not uncommon. Should be generic STK392-150's or maybe STK392-110/120 I believe. By the way when the line moves up and down that means the vertical is working when it moves side to side the horizontal is working.
Feb 03, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
1,885 people viewed this question
Top Televison & Video Experts
