My 61LCX70-k wont turn on.the green light comes on it clicks like it wants to startbut then the light turns red.
    President:
  • 3,130 Answers
So9unds like a bad lamp
Posted on May 14, 2010
  • Larry  Dillon
    Larry Dillon May 14, 2010
    or a bad ballist????
    techman
96cura tl 3.2 traction control light came on and it wont start
Hi
Trac light will not cause the not starting
Ther can be many things to cause the not start
But common problems that I've repaired on the TL IS crank shalf sensor locate & inspect the wire harness & clean or replace the sensor
Let us know how you get on
Apr 18, 2014 | 1994 Jeep Grand Cherokee
Wont power on
time for a flatscreen, major circuit is out
Apr 06, 2014 | Mitsubishi WS-55413 55" Rear Projection...
Nothing works wont startbut does turn over
Hi Chris, Open the hood and check the battery connections. I think one cable may have come adrift. Regards John
Oct 26, 2012 | 2001 Ford Crown Victoria
My 98 dodge stratus won't startbut it will turn
You need to check if its got air, fuel, and spark. spray some throttle body cleaner in the throttle body and quickly try to start it. if it fires up then your not getting fuel so you may need a fuel pump and filter. If it does nothing check for spark, if you have no spark then you need to check the coils and crank position sensor.
Sep 08, 2011 | 1998 Dodge Stratus
THE GREEN LIGHT IS ON (FLASHING) BUT AFTER THE RED LIGHT(LAMP ,FLASHES TWICE ) AND I DONT HAVE IMAGEN TV IS ON BUT THE SCREEN IS ON BLACK.
When did you replaced lamp last time in tv?
It seems tv needs lamp replacement.
Let me know to provide you lamp replacement info.
Thanks.
Jan 02, 2011 | Panasonic PT-61LCX70 61" HDTV
My panasonic pt-61lcx35 has red and green spots all over the screen. ii have changed the lamp and still have thr problem
Ur backlight video board is dead,not the lamp,it video prob. must change the backlight video board.
Dec 09, 2009 | Panasonic PT-61LCX70 61" HDTV
Wont turn on. Green light comes on for a few seconds, andthen goes back o0ff.
Hi if its a Lcd or Dlp rptv most likely its time to replace the lamp if tv is between 2-4 yrs.If you hear clicking it could be the ballast which is the board that powers the lamp.Make sure fans are running ok ,dust them out if they are dirty.God bless you!
Oct 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
My vs-6055 you can hear it click but it wont turn on
check q570 if shorted replace it,also regulator ic401 goes bad along with c402 100mf/50volt electrolytic cap
Sep 01, 2009 | Mitsubishi VS-6055 60" Rear Projection...
2001 Jeep Grand Cherokee Limited 4wd 4.7L won't start when hot
vehicle needs serviced fuel filter blocked hope this helps?
Aug 25, 2009 | 2001 Jeep Wrangler
Panasonic pt-lcx70
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 18, 2017 | Panasonic PT-61LCX70 61" HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
