Question about Husqvarna Viking 1
My needed is too far back and hits the foot and cannot get to the fabric. I have tried everything I can think of and cannot get the needle forward. All the controls for side-ward motion etc are working fine. I really don't understand what happened it worked fine the last time I used it and when I took it out today the needle is in the wrong position too far back and help.....
  • Husqvarna Master
  • 9,530 Answers
Consult your manual. The flat side of the needle may be facing the wrong direction.
Posted on May 23, 2015
    Problem Solver:
  • 13 Answers
Is it just the needle or the whole shaft? I would try 1 make sure the presser foot is correct one for the stitch,2 changing needle, 3 rotate shaft (needle out)manually slightly pull forward on shaft.it might have come disengaged
Posted on May 14, 2010
I have a Husqvarna Optima 120 The needles are being bent forward at the bottom. They start hitting the metal foot/feed dog and snapping. What does the knob on the far left end of the machine do?
First, check that you are installing the needle correctly. The needle has a flat part and it is important that the flat part be installed facing the correct direction. Inserting it incorrectly will offset the needle position and cause the needle to strike. (Be Careful--flying broken needles can be dangerous--for you and your machine! Wear eye protection.)
If the needle is hitting the presser foot, you might try a different foot. The one you are currently using could be damaged or may not be made for your machine.
If you are sewing thick materials, be sure you are using a heavier needle made for leather or denim. The heavier needle is less likely to bend as it pierces the fabric. (Likewise, you will probably want to use a heavier thread as well.)
Also, be sure that you are NOT pulling or pushing the fabric through the machine. That will frequently cause the needle to bend and strike.
The knob on the left may be the presser foot pressure adjustment. It is adjusted to increase or decrease the presser foot pressure on the feed dogs in order to better feed heavier- or lighter-weight fabrics through the machine.
Feb 27, 2016 | Husqvarna Sewing Machines
I know how to attach my ruffler foot but my needle keeps hitting the plate .what do I need to adjust to keep the needle from hitting the foot
You may need to move the needle position left or right. Try a different stitch length. If the ruffler foot is installed correctly and needle is in the correct position this should not happen. It is hitting left/right/forward or back of the ruffler needle space?
Sep 13, 2014 | Sewing Machines
I can't figure out how to replace the needle on a Juki MO-3314E industrial serger
There should be a lever (probably black) at the back left side of the machine. When you push down on it (strongly) it should release the whole foot to swing out left from the machine. I think that model has its needle holding screws on the front and you will probably need a small allen wrench / needle wrench to unscrew that small needle screw. I could be wrong. Sometimes they are just a regular needle screw that is unscrewed with a small screw driver.
Unscrew the needle screw and take the old needle out. Try not to drop it into the machine because this can start a whole new set of problems. You can use tweezers or needle nose pliers if it is hard to hold on to it. I think that this model takes a B-64 needle and probably either a 12,14,16,18 size. Use the size that was already in it if you know. If you don't know, you may be able to read it on the top of the old needle (you may need a magnifying glass if it is pretty worn).
Put your new needle into the hole where the old one came out, making sure that the 'eye' of the needle is straight forward or it will not make good stitches. You may already know this, but just in case you don't, the front of the needle is the side that has a groove straight down the front of the needle to the hole so that the thread can run down it to the eye as you sew. If you put the needle in backwards, it will probably not make stitches.
Make sure that the needle is as far up into the hole as it can go and tighten your needle screw. Thread your needle (s) and lay the thread ends towards the back of your machine. Now, make sure that the threads from the loopers are coming directly from the eyes of the loopers, not tangled up with each other and lay those thread ends towards the back of the machine.
Turn the handwheel on the right side of your machine forward until the needles are as high as they are going to go.
Now, push down on the black lever on the back of the machine and swing your foot back into place. Before you try to run it, make sure that the foot is 'locked' in place. You can assure yourself of this, by trying to wiggle the foot from left to right. It should not move from left to right when locked into place. Now turn your handwheel forward again slightly to make sure that your needles are not going to hit the foot. If all is well, run a small piece of fabric through the machine and check the stitch.
Good Luck.
Jun 26, 2014 | Juki 6716 Mechanical Sewing Machine
My needed is too far back and hits the foot and cannot get to the fabric. I have tried everything I can think of and cannot get the needle forward. All the controls for side-ward motion etc are working...
Check if the needle is inserted into the holder correctly, and that its not bent. (may not be noticeable) Also examine the foot attaching area and see if the thumbscrew is tight(may just be screw). Most machines have the removeable foot for other foot types.
Do forgive me if I seem vague, Im giving you general information.
Mar 21, 2010 | Husqvarna Viking 1
I have broken 2 needles and now the new needle (foot) will not move up and down. i have double checked all settings and nothing has helped. any suggestions
Here are several solutions for you to try.
* Your broken needle may have been too thin for your fabric. Make sure your replacement needle
is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric. When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot to make sure it’s attached securely.
* Change your pressure foot. Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins. A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate to make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle, right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 23, 2009 | Bernina Artista 180
Keep breaking needles
Here are some solutions to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Check your needle plate and make sure it's securely in position.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
Hope this helps.
Sep 20, 2009 | Singer 132QRFB Mechanical Sewing Machine
When i use my janome overlocker the needle is hitting the lower looper, and therefore breaking. This is happening with both needles. I have taken the covers off and the needles are hitting the metal. Is it...
Here are a few things to try.
* When you insert anew needle, make sure it’s positioned correctly. Usually with the flat side
away from the bobbin, but consult your manual. Make sure that it goes all the way into the holder, and that the screw is securely tightened.
Make sure it’s attached securely.
your needle.
Make sure it's securely in position.
pressure foot.
I hope one of these solutions help you.
Sep 14, 2009 | Sewing Machines
My PE 100 keeps breaking needles, they are striking something during use.
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    If this doesn’t seem to be the problem
    I hope this helps.
Sep 11, 2009 | Brother Sewing Machines
Needle hits needle plate with heavy fabric
that is your problem, your needle bar is centered too far to the back. There are 2 little bolts (Below the presser foot lift on the back of the machine) that must be loosened while the needle bar is repositioned aligning the needle bar assembly.
Mar 23, 2009 | Bernina 1008
Feed dog is not working.
Think of it as if it as two sets of fingers, behind and in front of where you are making the stitch. The numbers on the indicator should be thought of as X to one. 1 is always the rear hand, and X is the front one. If you go to a lesser number (like 0.5) with your front hand (feed dog) it means that they only feed the fabric one half as far as the rear one, so you are stretching the fabric at the point where it is being sewn. If you go to a larger number (like 2) that should be read as 2 to 1. In other words, your front hand is pushing the fabric twice as far as the rear one is, so it is compressing the fabric where it is being sewn. Wonderful invention!
Jan 22, 2009 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
98 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
