Question about Dryers
I have a whirlpool dryer and when you push the start button the motor just humms and the tumbler doesn't spin. i opened the door spun the tumbler and push the start button and closed it quick and it started spinning. Does the mean that the motors bad or some thing else is wrong?
    Novelist:
  • 145 Answers
You need to test it, but when the drum doesn't spin on its own, that more than likely means the motor is going bad. If you remove the belt from the motor pulley and run the motor with no load on it for a few minutes and then reattach it see if the motor runs this way, you may get a few more runs out of it. You can usually access the belt pulley form the rear compartment of the dryer.
Posted on May 14, 2010
My front end load dryer makes a humming noise when started then goes to pause
Have you checked the drying drum to see if it spins freely? Open the door and verify it spins freely. if it does then the motor may just be in a bad spot. usually after spinning the drum a turn or two it will get it running. it humms and clicks because of the motor not turning and trips an thermal overload switch and you have to wait for it to reset. Now if the drum dosent turn then you have a problem with drum rollers or something stuck in the way of the drum.
Dec 06, 2013 | Frigidaire Dryers
Whirlpool dryer makes a buzzing sound whey start button is pushed. sometimes it will turn on for a few seconds but most of the time it just buzzes.
The buzzing is probably the relay trying to start the motor. See if the motor has a capacitor, have it checked. If the motor is all clogged with lint, the start/run switch can get blocked. Clean out all that lint with a vacuum cleaner.
Check the tub bearing, and make sure the drum spins freely.
Nov 29, 2013 | Whirlpool LER4634J Electric Dryer
Duet dryer is making a humming noise when cycle starts a d during
whenever i hear a humming sound in a dryer it's usually the motor or something caught in the blower wheel stopping the motor from spinning.open the door and see if you can spin the drum.if it spins by hand try this,open the door,push in the door switch with one hand,have someone push the start button while you hold in the door switch and spin the drum by hand helping it move,if it runs you have a bad motor,if it doesn't remove the bottom panel and see if the belt is broke and stuck in the motor but like i say usually it has something to do with the motor not spinning.hope this helps
Oct 21, 2013 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
I bought an amana dryer, the tumbler does not turn, it just humms.
What is the complete model number of your unit?
The start relay on the motor is bad. Open the door, hold the door switch in and spin the drum as someone else pushes the start button and post back your results.
Dec 07, 2012 | Dryers
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
I have a whirlpool dryer model # LEP6848AW0 and when you hit the start button it just hums like something is binding. Open the door and hold switch in and hit start button it hums and you spin the the drum...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Whirlpool Dryers
Whirlpool gas dryer wont spin
timer relay is bad
Feb 24, 2010 | Dryers
WILL NOT START WHEN YOU TURN THE START SWITCH, THE MOTOR JUST HUMMS
two possibel reasons for this
1, you have something stuck in the blower moter
look down the lint trap you may just be able to see it
2. your motor is going bad
open the door and hold the door switch with tape or something like it
push the button and try to spin the tumbler while you hear the buzz
if it starts up and the buzz goes away,,,, your motors start wionding is gone and you will need to replace the motor
Oct 21, 2009 | Dryers
Frigidaire dryer hums when button is pushed in but won't start
ok can u turn the tumbler freely,
if no well there is something stuck in you blower like a sock or something
if the tumbler turns freely
keep the door open and hold the door switch
try pushing the start button
and tuning the tumbler, yes all three at the same time lol you may need a hand
try tuning the tumbler when you hear a hum
if it takes off bad news your start winding on the motor is bad or the capacitor depending on your model
if it does not turn, but the hum continues longer than 1-2 minutes it could be just a belt
Oct 19, 2009 | Frigidaire Electric Dryer
Dryer startup
motor is going out ,, repl/ check door switch is it in good shape should make cliking noise ,,,when good
Dec 28, 2008 | Dryers
Dryers Logo
67 people viewed this question
Top Dryers Experts
