Question about Sony SDM-P234/B 23" LCD Monitor
A big white vertical static band appears as soon a i turn on the power
This monitor displays a white vertical static band as soon as i turn on the power also there a few horizontal thin gray lines. This happens no matter if its connected or not to a computer.
  • einundswan Mar 30, 2008
    I'm able to remove the back lid of the monitor and see the power supply card and controller (where the chipset is) card. In the controller card i can see a capacitor with a yellow matter on both pins so may be its burned (just a guess) can it be the cause of this?
    Also this monitor has a front control panel which is connected internally to the controller card. This panel has several buttons included a power button (there is another one in the back which is attached internally directly in the power supply card) when i press this button the monitor enters into the standby state but the others buttons (menu, up, down, enter) doesn't work.
    Could you point me some parts or zones that could be involved in this behavior to troubleshoot?
    Thanks in advance
  • einundswan Mar 31, 2008
    Thanks waterppk i have two monitors of the same type and i have exchanged both cards with the other one, which is actually working, and still retains its behavior, so the capacitor were not the cause.
    Any clues?
    Scholar:
  • 42 Answers
Some of the transistors or the connection to the panel inside the monitor are damaged. There is no absolute fix for this problem.
You can try pushing on the bezel (NOT ON THE SCREEN) of the monitor at the edge of the screen directly at the lines and you may be able to push the connection back together well enough that the line goes away, but usually in desktop monitors the bezel is too rigid to allow you to put any pressure on the connections at the back of the LCD panel.
Posted on Mar 30, 2008
  • Chris M
    Chris M Mar 30, 2008
    Can you upload a picture? It's really difficult to guess and I don't want give you the wrong information.
Whire vertical band , 3 inches wide with red kine in the middle
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 12, 2014 | Sharp LC60E88UN Aquos 60 inch 1080p LCD...
Monitor displays wide vertical stripes/bands
That is the symptom of failed T-CON board (part of the LCD panel assembly, new panel will be needed), you can try reseating the ribbon connector on the LCD panel first.
This what T-CON board looks like:
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Apr 26, 2010 | Planar PT1814NUV 18.1 in. Flat Panel LCD...
Vertical white wide band - Shivering fonts
Unfortunately that sound like a defective LCD panel. You can verify this by plugging the system into an external monitor. As long as the shimmering band does not appear on external display then it is the LCD. If it is under warranty I would suggest taking it into Apple.
Aug 16, 2009 | Apple MacBook Air Mac Notebook
Continuous vertical white band display problem
What is the error from installing xp sp3?
Is the white band always there? it is either a problem with the lcd panel most likely, or the graphics card. try a different monitor if you have one.
Jun 21, 2009 | Dell Dimension 9100 PC Desktop
White 1 inch vertical band on display
just a thought.. Either your Graphics card or your Video Card has gone bad.. unfortunately DELL has a tendency of putting the graphics ON-BOARD and IF the onboard grqaphics card is bad, you'll need to get into the BIOS and turn the onboard graphics off then purchase an after market Graphics driver.. IMPORTANT: make certain that the graphic cars is compatable with the DELL PC OR purchase a less Proprietary system
May 04, 2009 | Dell Dimension 9100 PC Desktop
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
KDS K717s 17" LCD Monitor
The white screen tells me that the display cable (inside your monitor) may be unattached or broken.
The color bands if they are vertical or horizontal lines tell me that your display cable needs to be replaced.
So overall replace your display cable. If this doesn't entirely fix the problem your logic board (inside the monitor) needs to be replaced.
Feb 21, 2008 | KDS K717s 17" LCD Monitor
Wide vertical black and white bands
Hi, You may want to try and unplugging the power and video connectors of the Dell monitor. Check for anything out of the ordinary with the AC plug and the video connector. If none, plug them back in making sure that they are snug and fitted properly. If problem persist, see if it is possible to rotate the way the AC plug is connected to the mains (sometimes this works and can be done if you are not using 3-prong or the uneven 2-prong AC plug. Sometimes, this can also be done on the other end of the AC plug). Check your docking station (though unlikely but possibly). If still a no go and your laptop works ok, then your external monitor needs some looking at. This would involve circuit analysis and component level repair. Perhaps your best bet is to have a qualified professional take a look at it. Good luck and pls post back how things turn up or if you need further information. Kind regards.
Aug 20, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
Sony SDM-P234/B 23" LCD Monitor Logo
429 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
