Question about Dishwashers
Dishwasher will not wash
My dishwasher will go thru cycles but not wash dishes
  • Grimaldi Feb 04, 2009
    The dishwasher cleans the bottom portion somewhat, but not great. It does not clean the top at all. It seems like very little water is being sprayed up on top. It also seems to be depositing some dirty scum in the stuff on top. We have run several 'dishwasher cleaners' through the system with no improvement. The inside of the dishwasher appears spotless and no water builds up or collects in the bottom.
  • 53 Answers
Hi
so many possibilities here, a couple possible solutions.. check the sprayer arms to see if they move and check to see if all the holes on the sprayer are clear. check the drain lines they may be clogged or the motor may be clogged or broken.
Posted on Mar 30, 2008
My Bosch SHU436UC/17 goes thru its cycle OK, but dishes aren't very clean. During the wash, the water isn't very warm, but at the end of the cycle, the dishes are very hot. Any ideas?
Is the water supply hooked up to the hot water are you rinsing the dishes before you insert them in the dishwasher did your dishwasher low on
Nov 28, 2015 | Bosch Dishwashers
How to repair - no water is entering the dish waterr
Your dishwasher is equipped with a safety system which is able to detect any operating problems. These anomalies are reported by
one or two wash cycle indicator lights "E" will flash rapidly.
Any flashing combination of LED diodes (Intensive wash, Regular wash, Eco wash, Rapid wash, Soak and Crystal care) means different error code. Take a note of which lights are flashing?
If you have problem with fill water than following two LED should be flashing.24428775-0h3kxpflbez5mdeb5anq3st4-3-0.jpg
In this case could be:
  • Water valve disabled
  • Turbine disabled
  • Control board faulty
Dado
May 15, 2014 | Ariston Technologies LL65 Built-in...
Dishwasher not drying dishes
Depending on hardness of your water you will only need 1 teaspoon of soap in dispenser 1 teaspoon for prewash. Your water temp needs to be 140 or more. Run the hot water at the sink till its hot before starting wash. Dont forget to use jet dry....
Apr 30, 2014 | Asko Dishwashers
I have GE GLDT696TSS. The dishes are not clean and one time noticed water leak from the back of the washer.
You should check the water outlet - probably discharges into your sink through a garbage disposal - the water outlet is likely plugged and water can not discharge down the sink. You can remove the hose and clean it out.
Apr 06, 2014 | GE GLDT696TSS Builtin Dishwasher
Frigidaire dishwasher 15 months old. just started not washing dishes very well. set it for high temp wash. put plenty of fresh dishwashing liquid in. the unit goes thru a full cycle. you open the door and...
First I would check to see if it is getting enough water. There is a screen in the water inlet valve that tends to pick up debris. Follow the links Dishwasher not cleaning starting with the video on the water inlet valve.
Nov 05, 2010 | Frigidaire Dishwashers
I have washed and rewashed my dishes with no soap and my glasses have a horrible white film and any of my plastics now have white film almost as if the soap is not rinsing off. I have resorted to hand...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
l'l
Sep 25, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishes not clean after cycle!
Is the water coming into the dishwasher and is the wash motor working or is the sump clogged up so the water cannot get thru.Depending on the purchase date of the dishwasher, if it is a under a year old call who ever you bought it from as it usually comes with a 1 year manufactures warranty.
Feb 06, 2010 | Dishwashers
Mold growing on dishes
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
Jul 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Dishwashers Logo
222 people viewed this question
Top Dishwashers Experts
