The 9th addition of the asd steel manule has a coversion chart in it's index from inches in one foot to tenths of that same foot. Ie. 1'' = .o8' like 4'' = .333' of a foot. I would like an on line access. I could duplicate this by duing my own arithmatic. However I'm lazy and is'nt that what the net is all about. William
    Brigadier General:
  • 10,406 Answers
Access: http://www.rexxla.org
and install the 'REXX' software.
Then, you can use REXX as a programming-language.
Use NOTEPAD to put the following lines into a file named 'lazy.txt':
/* lazy rexx */
numeric digits 5
do x = 0 to 12
y = x / 12
say right(x,3) y
end
exit
Then, from a command-line prompt, enter:
rexx lazy.txt
to "run" the REXX program.
Posted on May 14, 2010
99 Cherokee sport fuse block diagram
the book is free, online,
no spark, is a
check all fuses, first.
then scan it problem. if the ASD relay drops out , then must be scanned.
chapter 8w, is all wiring, and fuses.
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
ASD is covered here.
http://jeepdied.com/ASD.html
Sep 01, 2016 | 1999 Jeep Cherokee
Can you tell me where the asd relay is located
one more Guessyah question, where is... easter egg hunts
if you read the manual its clear. (posted 100s of times here)
or read the door index in the PDC box it lists the ASD there.,
1993 to NOW.
here we go posted 100s of times.
the ASD can drop out for 8 reasons,, scanning the PCM finds that easy. if you dont scan it ,i bet you never find why it drops.
gas engines,(answered)
here is page from chapter 8w-10-7, free to look)
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
now the relay.
my guess, (hey no symptoms posted, so....)
asd skool
http://www.fixkick.com/Jeeps/ASD.html
there is no need to post complex PDC wiring using words, omg hard....
the link1 above has the full schematic, every inch off it.
read the schematic and see that the PCM controls the ASD !
at all times.
and has been posted here over 100 times, ever search here?
see those?
Aug 13, 2015 | 1996 Jeep Cherokee
2004 jeep GC stalls out after running awhile.Changed fuel pump still have stalling problem
which engine.????
why guess?
ill assume the full 60k mile tune up was done.
you picked the most hard fix of all and guessed wrong, wow.
if the engine is good, compression great.
there are only 3 causes of stalls, in pure Physics. bla bla....
in reality parts wise over 50,, guessing is not going to work.
what does worK? diagnosis, want to test or guess.?
on all jeeps we have this funny thing called ASD,
but first, i must ask a key question. can your right FOOT save the stall if it gets happy footed , at the stall point?????? bid deal important that.?????
ill pretend NO, for THAT.( post the facts ,im showing real tests , and real results here) yours will vary.....
lost spark?, is the cause, not fuel.? (efi cuts fuel for loss of spark in the ECU LOGIC, so spark is first ,if hot compression is not dropping)
but id check the ASD next or drive with a scan tool attached (any) and see the PCM/ECU tell you why it stalled ! , it will 1/2 the time.
in addition to that, the ASD relay must be monitored, (scan tool will do same)
if the RELAY DROPS? then we know why , see?
see the 8 ways to DROP and ASD here !
see those, if they drop , each tells you why.
if the ASD did not drop, then it starved for fuel. (compression good)
Examples more./......
say , you get no DTC errors (scanned), and ASD holds fast,. at stall?
more examples::::
does it starve for fuel with gas cap loose , then wrong cap
its missing the vacuum breaker inside, a 5 buck fix. and kids can change it. or worse?, caused it.LOL
More examples:
we use a fuel pressure guage at the fuel rail (TOOLS RULE)
if the pressure drops, at stall , and not ASD drop.?
then you have bad wiring from the fuel pump relay to the tank pump.
or a bad relay. the volt meter will prove that.. easy.
very common on all EFI cars, bad wiring, and 10x that in the salt belts.
google salt belt, or wiki it.
this is how all 1993 jeep to present run. ASD is first to watch , hint.!
ASD dont drop:
if fuel pressure is good?, then wrong tree to bark up.
if fuel pressure was low, check voltage to pump cranking
must be 12v, or 11, if cold and battery weak
less voltage , is BAD. fix bad. (clean connections.)
only takes 3 tools.
  1. volt meter
  2. compression gauge.
  3. fuel pressure gauge.
a vacuum gauge part of a hand vacuum pump is nice.
most fail paths can be found with minimal tools. about 60 bucks worth. in any DIY shop.
and sorry , you cant fix modern cars with out a scan tool
buy, rent or barrow one. they are everywhere.
all answers, USA and no engine stated so 100% generic answers.!
not flex fuel opted, not CNG engines.
and P0181 not set, pump dead, error fuel pump.
see this page.
here,
click WJ
click Emission
click on diagnosis section see all those DTCs, get any????
no P0215?
loss of cmp , loss of CKP
gross missfiring? codes.
endless really, scan it. at stall , scan it.
fsm
here
free.
Sep 24, 2014 | 2004 Jeep Grand Cherokee
Fuel pump relay wiring schematic 1997 jeep grand cherokee
which engine?
fsm covers this.
ZJ car.
just RTM it here.
under wiring
page 8w-30-3
why not?
post symptoms, and ask for help
do you have no fuel pressure cranking?????
or dont know how the ASD controls this>
ASD 101:
Sep 09, 2014 | 1997 Jeep Grand Cherokee
How to test the asd relay on a 2003 dodge caravan 3.3l engine
This can be done with a ohm meter, but you need a chart of the internal wiring. Better, if there is another exactly the same relay you could swap them to test.
Mar 31, 2014 | 2003 Dodge Caravan
CANN,T FIND SHUT DOWN FUSE
fuses are easy to test. DMM in hand.
Ohms 101:
set to low resistance (dial) Rx2 or as low as it goes..
then check fuse. 0 ohms is good, infinity (OR/OL) is bad.
now the rules of ASD.
got spark cranking?
got spark for 2 seconds cranking,
is the ASD closing for 2 seconds, the drops out cranking?
here are the 7 /8 rules of ASD.
there are many fuses to get EFI running , on all cars.
fuse 6,11,16,21 all kill it.
the FSm shows which, see chapter 8w-30
the fSm is the deal working on any car FSM free, is a head against wall experience. and 100x that today.
get one, and keep it with car.
Mar 23, 2014 | 1996 Jeep Grand Cherokee
Runs for an hour then will not start act like its vapor locked
its EFI they dont vapor lock , like carbs, not at all.
so lost spark, test spark on all cylinders.
if you lost it all , you dropped the ASD relay?
if you have spark try test fuel,. (spray)
im now posted this everytime , no spark. my 3 time now, trying to reach a new record..... LOL
no scan , tool so on your car , you do the CEL falsh code deal.
see in the fsm under emission+diagnostics.
quoting my self.... on this forum...
posted to fixya many times
ASD "automatic shut down relay"
what is it?
it cuts fuel (and spark) if the PCM thinks, there is any danger of crash and burn.
The PCM drops the ASD for many reason, this list is all years. (some are missing on early years)
1: sees the spark weak or dead on the ignitor or coil primary pin. (it knows spark is bad)
2: Crank sensor bad. or misfiring. CKP
3: cam sensor bad, or misfiring , CMP.
4: ASD input read back pin fails. (PCM commanded it but it refused to do its job)
5: same ASD output fails. i commanded it but the relay is bad. dead.
6: Immoblizer active. (failing or bad key etc,)
if the ASD drops driving or even parked idling
one of the above caused it.
the ASD has engine startup logic that is unique to JEEPs.
you must crank with in seconds or the key on is ignored by many jeeps.
you crank and the above 6 must not fail during the start event or it cuts the ASD.
note carefully, if spark is bad cranking, the ASD cuts spark 100% more dead.(funny, but very true ,read the ASD schematic)
you only get 2 seconds to get the 6 factors true or the game is all over.
if when driving, it sees one of the 5 fail, ASD drops.
in fact ASD can drop then come back. while drive, people say it cuts out.
if true, using any dirt cheap scan tool will show why,
DTCs tell you. Cmp /ckp or spark dead.
pending or live DTC
freeze frame, dtc will show what failed.
and even seeing RPM drop like a rock, faster than any crankshaft can spin down, dig?
or loss of 12vdc power to the PCM , does all this above. DIES.
Mar 08, 2014 | 1994 Jeep Grand Cherokee
Where is the asd relay in 97 Cherokee 4L
great question the ASD, a key relay to sustained starts and running.
and told the engine, bravo !!!
post the DTC error code.
The ASD can drop out for many reasons, post all DTC codes
and never forget, crank for 5 seconds then look for DTCs
and pendings....
RTM
see wiring page
see PDF page 22, BINGO.
Feb 12, 2014 | 1998 Jeep Grand Cherokee
1997 jeep starts than quits
stalls. (do the 60k tune up yet?)
which engine? (cylinder count and displacment)
On jeeps ,we have to monitor the ASD relay. (finger pressed to case)
i try to prevent the stall with a fast right foot action, and with a scan tool see what happens, that is how i do this.
and if the ASD drops out below say 700RPM that means
the ECU dropped it ,due to ERRORS.
the scan tool will show these. errors. clearly
CMP or CMP dead, spark loss. (at least 3 ways,,,, to drop)
the ECU is programmed (hard logic) to drop the ASD if there are any errors that can cause a fire, and if yes, cuts the ASD, and this kills the injectors dead as a doornail. no fuel , no fire, and no lawsuits. dig?
Feb 03, 2014 | 1997 Jeep Grand Cherokee
1999 dodge caravan 3.0 liter. fuel pump relay not getting voltage
Have you checked the ASD (Automatic Shut Down) Relay? Check to see if that is getting power. Then check to see if the ASD Relay itself is good. You do not have to use any special tools/knowledge to check this. You can change this Relay out with another Relay that is the same shape and type on a function that is known working. For example: Check to see if your Front Windshield Wipers are working. Change out the ASD Relay with this Front Windshield On/Off Relay. Check the Wipers again. If it does not work, then the ASD Relay is bad. With the Front Wiper Relay in the ASD now check for power to the Fuel Pump Relay.
One additional fact: IF the Crankshaft Position Sensor is bad the Engine will not operate at all, meaning there will be no power sent to anything including the fuel pump relay!
Nov 25, 2009 | 1999 Dodge Caravan
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
