Question about Cell Phones
Says car kit on display - Cell Phones
  • 71 Answers
Go into Profiles and change this to General.
Go into Settings/Configuration and look for Connections. Have this changed to Headset and you should be fine.
Regards,
Sox
Posted on May 15, 2010
Just brought a HTC wildfire and I cant find bluetooth to turn it on .
Bell;
Important:
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so HTC Wildfire S can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press howtoimage.aspx?id=106492, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. HTC Wildfire S will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. HTC Wildfire S then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to HTC Wildfire S, the Bluetooth connected icon howtoimage.aspx?id=106796 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Mar 28, 2012 | HTC Wildfire Cell Phone
Tip
Jabra Bluetooth Headset Pairing Instructions
<span><span>Connecting a Bluetooth headset or car kit</span> <span> You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free. <ul> <li>For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile. </li> <li>Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual. </li></ul> <ol> <li> <span>From the Home screen, press <span>MENU</span>, and then tap <span><span>Settings</span> &gt; <span>Wireless & networks</span></span>. </span> </li> <li> <span>Tap <span>Bluetooth settings</span>. </span> </li> <li> <span>If the <span>Bluetooth</span> check box is not selected, select it to turn Bluetooth on. </span> </li> <li> <span>Make sure that the headset is discoverable. </span> </li> <li> <span>Tap <span>Scan for devices</span>. </span> Your phone will start to scan for Bluetooth devices within range. </li> <li> <span>When you see the name of your headset displayed in the <span>Bluetooth devices </span>section, tap the name. </span> Your phone then automatically tries to pair with the headset. </li> <li> <span>If automatic pairing fails, enter the passcode supplied with your headset. </span> </li></ol> The pairing and connection status is displayed below the hands-free headset or car kit name in the <span>Bluetooth devices</span> section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls. </span></span>
on May 23, 2011 | Cell Phones
My Parrot display says "Goodbye" and I cannot pair
This kit has frozen and will need to be reset by unplugging the main blue box for a few minutes, this should rectify the fault. If this does not work you will have to upgrade the software on the Parrot.
Sep 24, 2011 | Parrot Hands-Free Car Kit with LCD Display...
How do i pair my jabra bt250 to my htc desire hd
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon howtoimage.aspx?id=12046 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
May 23, 2011 | Jabra BT250 Consumer Headset
Lg vx8300 verizon says car kit display have no
Car kit mode means one of two things, first it could have a piece of lint or paper stuck in the charge port making it think there is a car kit plugged in, or second it could be that some moisture got into the port and its giving a indication that something is plugged in. and thats why you're not getting any sound. There is no specific setting to turn on or off 'car kit' mode you can use a paper clip or something and mess with the port a little bit to see if 'car kit' goes away or replace phone
Jun 23, 2010 | LG VX8300 Cellular Phone
Parrot ls3200 displaying goodbye
Good bye appear when the car kit switch off. Then suppose to be in relation with the question of the 12 ignition. If it doesn't disconnect of switch off in relation with the car, maybe the kit has a 12 DC and not an ignition connected.
If you can disconnect the power supply of the kit, just do it, and it should normally coming back to the main screen.
Mar 20, 2010 | Parrot Ck3200 Ls - Color Cell Interface...
Cant connect my iphone to nokia ck-7w
not compatable, the nokia kit has very old software and will not work with Iphone, look at Parrot MKI car kits made for Iphone, very good.
Jan 16, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
8550DP Maintenance Kit
First of all make sure it is the right kit. The part numbers for teh 8550 and 2424 are very close, one ends in 675 the other in 657, so they have been known to be mixed up.
then here is the documentation..
Problem:
The machine displays the Replace Maintenance Kit after the Maintenance Kit has been replaced.
Cause:
There may two causes for this issue.
  1. The machine does not recognize that the Maintenance Kit was removed. This would likely be caused by a defective Drum Maintenance Pivot Plate.
  2. The machine corrupts the CRUM on the new Maintenance Kit. This may be caused by a defective Drum Maintenance Pivot Plate or IO Board.
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix.
  1. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message does not change to "Maintenance Kit Missing," replace the Drum Maintenance Pivot Plate and install a new Maintenance Kit.
  2. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message changes to "Maintenance Kit Missing," replace the IO Board and then install a different NEW Maintenance Kit. If the problem persists, replace the Drum Maintenance Pivot Plate and install a different NEW Maintenance Kit.
Apr 18, 2008 | Xerox Phaser 8550DP Printer
Maintanance kit replace
Problem:
Cause:
ETI v1.3.20.0 610606.Replace Maintenance Kit Message after it Has Been Replaced 2007-11-18 21:37:39
Mar 30, 2008 | Xerox Phaser 8400 Laser Printer
Cell Phones Logo
284 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
