Question about Garden
Model EXVRB2321 would run only with full choke,
Model EXVRB2321 would run only with full choke now wont start after cleaned carbtankwhat is the plug gapi got a champion ez start5843spark plug replaced fuel line pvc boot getting juice to plug and compression is 60 to 62 lbs psi.
    Problem Solver:
  • 5 Answers
You have a clogged intake jet in your carburetor. Remove the bolt below the carburetor bowl. Take a very fine wire (like a floral wire) and pass it through the small horizontal and vertical hole in the bolt/intake jet. Use some Sea Foam Carburetor cleaner in the gas to further clean any deposits. Should take you five minutes. Let me know when she's up and running.
Posted on Apr 04, 2011
  • 2,100 Answers
What engine is it? The plug gap should be preset, But I'm glad you mentioned the compression, it should be 100 lbs.. , 70 lbs min, or it won't start. You might have a valve burned out from the choke being on. Most engines won't run with the choke on, so something was wrong. You can pull the head and the valves easy enough to see what it is. One more thing, make sure there is nothing holding the engine back from running, like the pressure washer is full and ready to go, let the pressure out if you can. Hope this helps.
Posted on May 14, 2010
Weed wackier gas trimmer
didnt specify the make and model so generic answer ---check fuel mixture is correct --check the filter in tank is not plugging up--look for damaged / crack in fuel feed lines-look at spark plug --carb may need cleaning --exhaust port may need cleaning
Jul 04, 2016 | Garden
Wont stay running
You should only use choke until you get a turn over. After that, turn off choke and it should start right up.
Apr 30, 2016 | Garden
Earthquake Vector Compact Tiller Model#26750
Did you pull the spark plug and clean it, as well as the plug well and compression ring. Blow it out with canned air and dry before replacing the plug. Be certain the plug GAP is correct and it is free of carbon deposits. Rest the plug, tighten by hand and let her go. See if that fixes the problem.
Feb 27, 2014 | Earthquake Vector Compact Front Tine...
Mcculloch 210 strimmer lost power now wont start for more than afew seconds
remove the muffler and run it the mufflers plug up and restrick the exhaust some mufflers you can open and clean the screen
Sep 14, 2012 | Garden
Bolens cultivator model BL410 won't keep running
clean the screen inside the muffler
Aug 03, 2012 | Garden
Toro recycler model number SR-21 S lawn mower wont start changed plug, filter, new gas. Mower ran for two lawn cuttings but seemed to overheat and choke out frequintly in high grass now it wont start at...
check your oil is it up to full, then I would check to see if you have compresson, pull your plug and roll over and feel with finger ,but don't touch spark plug wire or you will light up! next I would check for spark, then for fuel, make sure the carb is getting fuel,,,check your hoses and fuel cap and clean your carb and needle/seat and make sure gas will run through the fuel line. Also you could have sheared a flywheel key
the choke out you are talking about could of been a lean condition and smoked the eng rings
Good Luck compresson test should tell all 2StrokeJim
May 17, 2011 | Toro Lawn Mower With Toro Power Tools
Blower wont run at full throttle
Start with the spark plug it is the easiest.
But sounds like the carbourator is dirty, Probably fouled with old gas varnish. When it is idling give it a little throttle, flip the choke on and then full throttle. If it goes full throttle and doesn't conk out, it is a fuel issue.
Good Luck
Dec 07, 2008 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Garden Logo
445 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
