Question about Peg Perego John Deere Gator HPX Ride on Toy
Only has high speed, drivers side rear tire does
Only has high speed drivers side rear tire does not move and it does not go into reverse any suggestions to what is going on with our john deere gator hpx?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Bad motor, you can order a new one here www.powerwheelsoutlet.com
Posted on Jun 14, 2012
2 Suggested Answers
  • 65 Answers
SOURCE: Only has high speed, drivers side rear tire does
fried motor or bad wire
Posted on Mar 30, 2010
I have a 2005 ram 1500 4x4.when i put it four wheel drive high it feels like its in low and back tire on driver side skids
There's something seriously wrong in the transfer case or controls. It seems the rear driveshaft is locked up, and the front wheels are driving. The driver's side rear tire is skidding because it's trying to turn backward - rear passenger rear tire is going forward and rear differential has no option but to turn the driver tire in reverse (driveshaft locked). DON'T TRY TO DRIVE IT. Get it checked out and fixed.
Oct 25, 2016 | Cars & Trucks
Tire moves front to back
The bushings in the a-arms are shot. Replace the bushings.
murf427
Aug 02, 2012 | 1999 Volkswagen Jetta
My montana shakes/vibrates up and down when speed passed 75 mph. It is ok below 60 mph
Most likely a tire/wheel balance issue. The weights that are used to balance the tires can sometimes fall off. Generally how far out of balance it is determines when and how bad it will shake. Unfortunately this is not fixable without a tire balancing machine, has to got to a tire shop.
Were the tires rotated or replaced recently? Most major tire shops will check the balance for you at little or no charge if you take it back to the shop where the work was done.
You can also try to identify the problem tire by rotating the front and rear tires one side at a time. For example, if the vibration is coming from the front, swap the front and rear passenger side tires and drive the vehicle again. If the vibration moves to the back it's most likely the (now) passenger side rear tire that's out of balance. If the is no change, try the driver's side tires.
Hope this helps!
Sep 15, 2011 | 2000 Pontiac Montana
I have a creaking noise coming from the front driver side when making turns at low speed. Also, the front driver side tire is wearing off on the inside. Kim
the tie road end + rack end is the main proplem for making your tire wearing off
the noisy at slow speed coming from tire
you can check that by make the tire free by putting the car on the lift then you catch the tire from side and try to move it (in-out) if its move that mean you need to change even tie road end or rack end or both
Feb 19, 2010 | 2001 Chevrolet Impala
Im am rotating tires on a 94 jeep cherokee the
Move the passenger side rear tire to the front, and passenger side front to driver side rear. Switch the driver side rear tire to the front and driver side front to passenger side rear. Repeat this "X" pattern each time you rotate the tires. Rotate the tires from side to side if the tires are different sizes on the front and rear.
This is the better solution. Hope helped (remember rated this help)
For more details about Jeep Cherokee, review the Service Manual.
Good luck.
Nov 11, 2009 | 1994 Jeep Grand Cherokee
I HAVE A 1991 LEXUS 400LS THE REAR DRIVER SIDE WHEELS SHACKS WHEN I DRIVE UNDER THE SPEED OF 25 MPH. WHY?
You have a seperated tire or a loose wheel. A seperated tire happens when the tire's plys seperate from each other, this makes the car bounce or shake at low speeds. High speed vibrations are caused by unbalanced wheels. Vibrations under braking are the rotors.
Sep 10, 2009 | 1991 Lexus LS 400
Peg Perego John Deere Gator HPX Ride on Toy Logo
82 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
