Question about Bunn NHB Coffee Maker
I have a bunn coffee maker the nhbx is the # it is leaking water from the resevoir
  • 189 Answers
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
Posted on May 19, 2010
My Bunn nhbx-b leaks water when brewing coffee
you could remove the cover and look for the connection that isn't connected properly - - be careful not to touch electrical connections/bare wires when cover is off - or take it to a technician - or contact Bunn directly for suggestions.
regards,
Feb 11, 2017 | Bunn Coffee Makers & Espresso Machines
How to fix a Bunn NHBX that produces warm, not hot, coffee?
Thermal fuse is blown. Above and almost behind tank, and most likely brown. New one at www.bunn.com
Mar 02, 2015 | Bunn NHBX-B Contemporary 10-Cup Home...
How to remove the top water resivour from a nhbx bunn coffee maker
lift filler led and remove 2screws on top of reservoir
Then remove 4 screws that hold the reservoir on an you should be able to lift it off
Sep 03, 2014 | Bunn NHBX-B Contemporary 10-Cup Home...
How to fix a leak on a bunn NHBX coffee maker
The leak is most likely between the water reservoir and the tank. Bunn uses a soft silicone seal for that connection that gets compressed over time and starts to leak water whenever you make a pot of coffee.
It's planned obsolescence. Bunn won't sell you a new seal. So you have to improvise. But it's simple enough to do.
Remove the top cover and the plastic water reservoir right below it. Don't tamper with the little valve that opens when you close the lid.
Look for the seal. It could be stuck to the bottom of the reservoir, or sitting loosely on top of the metal tank. Make sure to preserve its top-to-bottom orientation (don't put it back in upside down).
Apply a narrow bead of clear silicone into the grooved side of the seal. Press the seal gently onto the reservoir, then apply a thin layer to the smooth side.
Re-install the reservoir and reassemble the unit.
Aug 09, 2014 | Bunn NHB Coffee Maker
Bunn nhbx leaks water
Jun 30, 2014 | Bunn NHBX
Bunn nhbx leaks out of the bottom
according to BUNN it is not repairable . they won't sell the parts needed
Jan 19, 2014 | Bunn NHBX-B Contemporary 10-Cup Home...
New Bunn NHBX takes about an hour to make 10 cups of coffee. Water is dispensed drop by drop instead of a stream. 4 dispensing holes are clean
It sounds like you might have a problem with the water tubing. If you will call Customer Service at 800-352-2866 we will be happy to assist you with this issue.
Sep 21, 2010 | Bunn NHBX-B Contemporary 10-Cup Home...
I have a bunn coffee maker the NHBX is the # it is leaking water from the resevoir
If you will locate the date code on the bottom of the unit and then call Customer Service, the machine will be replaced at no cost or if over 3 years old, at a reduced price.
Mar 21, 2010 | Bunn NHB Coffee Maker
Bunn NHB Coffee Maker Logo
1,096 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
