Technics SL-1200MK5 Turntable Logo
A
Anonymous Posted on May 12, 2010
Technics SL-1200MK5 Pitch Control Problem - Technics SL-1200MK5 Turntable
Anonymous
Level 2:
New Friend:
  • Expert 135 Answers
  • Posted on Jul 19, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
135
Questions
Helped
55782
Points
156
SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from [email protected]
i got my turntables repaired by these guys www.technmics1210repair.co.uk
i did they made my setup work like new so im going to spread the word.
give them a shot
1helpful
Technics SL-1200MK5 voltage or fuse problem
To change it from the 110 to 220 the switch is under the turntable platter. Put your fingers in the 2 holes under the slip matts and pull up evenly. It may be a little hard but it will come off. As for the fuse...its inside the deck. Unscrew the feet and all the screws. the black rubber part will come off. Good luck!
2helpful
2answers
I recently purchased a used Technics 1200-MK2 turntable. Aside from the obvious wear and tear, there is one issue that I can not seem to fix. One the pitch slider, the factory set zero (green light is on)...
sound like the pitch has been tampered with.
Right you felling confer dent if so get your self a Philips screwdriver switch the deck off & unplug it under the slip mat there are two big holes put your fingers in them then twist & pull the platter off its always a mission because of the magnetic brakes.
when you've got it off undo the 5 screws that hold the plastic cover on, then you'll see a circuit board on the top right hand side which has 2 pot one named BRAKE the other PITCH adjust the PITCH anticlockwise until it's slot is pointing up straight put it all back together but dont put the screws back in just yet.
test it first if it's still not right repeat this proses untill you nail it.
GOOD LUCK if you get stuk e-mail me [email protected]
Pitch Control issues on Technics 1200 mk2
The pitch pots have been altered.
there located under the platter & cover on the main circuit board.it's a peace of **** to sort them.
if you help e-mail me [email protected]
2helpful
2answers
After mixing for a while the turntable (1200 technics mk5) starts to lose the pitch or the record starts jerking up near the -5 or -6.
hi! there is a problem inside your turntable (on the main board) check the components  TRANSISTOR    Q2, Q3,  ZENER DIODE   D3..
CHANGE IT IF POSSIBLE..
Pitch Slider
You more than likely have to have the pitch control replaced or cleaned.
- OPTiC
Technics Repair Videos
Technics DJ Repair
DJ Equipment Sales
Technics Parts
Modification to SL-1210 Mk5
so what does the turntable do at 0?
2answers
Technics 30th Aniv Edition - help with break speed.
Do you recall the adjustment you made? That brake switch under the hod is real sensitive. For starters, try pulling back half way from which you adjusted, to get a sense of sensitivity. Did you alter the pitch switch at all?
Keep me posted.
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
