Question about Karcher 2500 PSI Pressure Washer
Karcher 2650 power washer Honda GC190; how to remove flywheel
I have a Karcher power washer with the Honda GC190 engine. The connecting rod broke at the bottom. I've opened up the engine to replace it and can't remove the flywheel to replace the rod and piston assembly. Does anyone know how to remove the flywheel / cooler so I can replace the rod? By the way I've read a lot of posts here from others who have had a hard time pulling the starting cord. I experienced this too and had to end up having a shop replace the camshaft. If you have this problem the part from a shop was $18 + labor. If you're handy you may be able to installeplace camshaft yourself by opening up the top by removing the 4-10mm bolts from the top cover.
bestdarngood
  • 3037 Answers
SOURCE: karcher 2400 pressure washer with
The pump is correctly oiled and lined up on the camshaft, correct?
Posted on Jul 20, 2008
smjdragonfly
  • 79 Answers
SOURCE: Kracher pressure washer with Honda engine 2500
Take the spark plug out and then try to turn it over. If it still won't pull, it's probably locked up. If it got tipped forward or towards the spark plug oil may have went into the valves. If it pulls you may see some oil spray out. Clean off plug and try to wait for the smoke to clear. Hope this helps. Please rate me
Posted on Jun 18, 2009
  • 174 Answers
SOURCE: Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Posted on Aug 18, 2009
  • 3 Answers
SOURCE: Honda GC190 engine shuts down on my Karcher 3000 PSI PW
Well would you believe that I have the very same problem. I suspected that the pump was seizing up, so we tried the pump on another unit and it worked fine. On inspection of the motor we found the cam (which also operates the decompression mechanism) was worn out. It's made of hard plastic. It is only about 7 dollars too, so cheap enough to fix. I have mine ordered now and feel pretty confident that that should fix it.
Posted on Aug 23, 2009
Testimonial: "Sounds good! I'll check it out and let you know. Thanks!"
SOURCE: Karcher K 2400 HH Pressure Washer no pressure
I had the same thing. Had to use Lithium grease to get it to work properly. Must take the cheesy plastic thing with the silver top off first to get at it. Only lubed the large o-ring. Works like new.
Posted on Oct 05, 2009
Govoner arm came off how to put it on in the right place
thats a honda engine
Search Results
Honda Engines ' GC190 Owner's Manual
engines.honda.com/parts/ownersmanuals/gc190 Download or purchase Honda Engine owners' manuals for the GC190.
Honda Engines ' GC190 4-Stroke Engine ' Features, Specs, and ...
engines.honda.com/models/model-detail/gc190 Official specs and features for the Honda GC190 OHC engine. ... is a small four-stroke gas engine designed for premium residential use. ... Owners Manual.
[PDF]honda 6hp gc190 repair manual.pdf
www.publicwalls.org/honda/honda-6hp-gc190-repair-manual.pdf
Apr 08, 2016 | Horizontal Engine 6 Hp Ohc Gc190mha2
How do I remove the connectors from the output hose?
Does it have brass quick connects or is it screwed directly into the pump? Feel free to email me.
Sep 26, 2014 | Karcher G 3050 OH 3000-PSI Honda Gc190...
How can I stop the siphon?
Are you using the black nozzle? Switch to a different nozzle. If you are not using the black nozzle the siphon fitting is bad.
Sep 24, 2014 | Karcher G 2600 XH 2600-PSI Honda Gc190...
How do you replace the honda gc190 decompression mechanism
This is a problem with GC-160 and GC-190 engines on pressure washers, tillers, etc. Once they get some hours on them and as things seat in-wear in, they get to a point you can not pull the start cord. If you remove the spark plug, the engine turns easily. The valves need adjusted. The valves are set .005" to .006" off the seat. This allows enough compression release but the engine runs. I find the valves need adjusted every 25 hours, not the 100 hours Honda states.
Mar 16, 2013 | Karcher 2500 PSI Pressure Washer
Honda GC190 can't pull starter cord
This is a problem with GC-160 and GC-190 engines on pressure washers, tillers, etc. Once they get some hours on them and as things seat in-wear in, they get to a point you can not pull the start cord. If you remove the spark plug, the engine turns easily then the valves need adjusted. The valves are set .005" to .006" off the seat. This allows enough compression release but the engine runs. I find the valves need adjusted every 25 hours, not the 100 hours Honda states.
Aug 29, 2012 | Honda Garden
Honda GC190 pressure washer has no compression
take the plug out and put a screwdriver in the hole turn the engine over by hand if it does not move the piston up the connecting rod has broken.
Apr 04, 2012 | Honda Black Max 2600 PSI Pressure Washer
My karcher pressure washer g 2650 oh wont start
Will it start if you pour a small amount of gas in the carb? If so your carb needs to be removed and cleaned.
Jun 30, 2010 | Karcher G 2650 Gas Pressure Washer
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
Aug 13, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
182 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
