Question about RCA P52921 52" Rear Projection Television
RCA P52921 changed channels by itself and unplugged it to reset it and
RCA P52921 changed channels by itself and I unplugged it to reset it and it did the same thing a few minutes later. Unplugged it again and now it won't come on at all.
  • 2 more comments
  • Lora Wolford Mar 31, 2008
    OK, hubby got the tv to come back on by checking a board that has the #'s 1518844D. TV won't change channels by remote but will by the controls on the tv's front. Could this board be the problem and if so where can I buy one.
    Thanks
    Now turned tv off and back on and can't get the menu to go off even with conrols on front of tv.
  • Lora Wolford Apr 01, 2008
    rca projection t model p52921.
    Started changing channels on the screen (numbers only not the channels themselves). Unplugged it and turned it back on and it did it again after a couple of minutes. Then unplugged it and wouldn't come back on. Finally got it back on today after checking circuit board with 1518844D on it, while checking this board it came back on. Won't work with remote, and sometimes works with controls on front of tv, but sometimes menu won't go off and controls on front of tv won't do anything. Remote control won't work at all, with new batteries installed. #'s for channels still changing on screen. I hope I put it in words that everyone can understand what I mean is happening to it.
  • Lora Wolford Apr 02, 2008
    Where can I buy the tact switches? I have already put so much money in this tv for repair after repair that I don't want to put much more. If they aren't much I will replace them myself. Really appreciate the help.
  • 818 Answers
Buy a control to see if there is a problem with your control.
Sergio
Posted on Apr 01, 2008
  • 790 Answers
Hi
you have defective tact switches! at the panel board front of your TV thats why your Tv System is in abnormal function!. If you have experience in electronic repairing you can change all tact switches at the front panel board.
thanks!!!
  • 1 more comment
  • carlos fernandez Jr.
    carlos fernandez Jr. Apr 01, 2008
    If the Tact switch have abnormal resistance, that is happen to your tv...
    Do Not Take Service mode if you dont understand the SERVICE MODE...
    carlos fernandez Jr. Apr 02, 2008
    you can buy the tact switch at electronics spare parts store... tact switch is very chip...
    Thankyou!!!
  • RCA Master
  • 19,396 Answers
Take batteries off the remote and check if it is the remote , otherwise it is a stuck key on the tv or the control board is gone,
regaards
Posted on Mar 31, 2008
  • 1 more comment
  • Ginko
    Ginko Mar 31, 2008
    If it does not come up at all it may be the PSU that was starting to fry up, that may be reason why your tv started doing funny things.
    However, it is possible that the PSU is fine and just some other part have blown.
    You should also test or have tested from a service centre, the DTV board, which is the main board inside the tv, that may had been damaged.
  • Ginko
    Ginko Apr 01, 2008
    Test and eventually change the control board. #1518844D is the audio/video IO board. If you had problem with that usually your audio or video has problems.
  • Ginko
    Ginko Apr 01, 2008
    You can also try to do a diagnosic, I have the following general procedure, it works on most RCA tvs :
    GE TELEVISIONS / RCA TELEVISIONS / PROSCAN TELEVISIONS
    Read the _ SERVICE MODE WARNING _ before proceeding.
    To enter service mode, push and hold the [Menu] button on the set.
    While holding, push and release the [Power] button, then the [Vol +]
    button.
    You will now have some information on the screen: "P0 V0"
    To actually be able to change these values, you must push [Vol +] on
    the remote so the information reads V76. Then pushing on the Channel
    +/- will change the "P" value.
    P1 - 3 are error codes. If there is a problem with the set that can be
    self-diagnosed, the "V" will report the code. These codes are available
    in the RCA repair manual.
    P4 - 7 control the horizontal size, shift, vertical size and shift.
    You may also find a summary leaflet for the service tech clipped
    somewhere inside the chassis. The procedures for getting into the
    service mode, as well as the service items of interest will be there.
Rca L40FHD41is stuck on menu,cant change input or volume . how to reset the tv???
Unplug the TV for a few minutes it should reset itself.
Make sure the menu button is not stuck, if it is try cleaning the button.
www.aaatvservice.com
Jan 28, 2012 | RCA Televison & Video
P52921...TV was dead. I turned it off last night no power this morning small fuse was blown and I replaced it and cleaned very dusty lens and hard reset. Now TV is not showing on entire screen but has a...
Ur tv have a problems known as a convergence problems,it dead.The tv convergence board require the 2 STK convergence ICS and some or all it resistors,must be change to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 28, 2010 | RCA P52921 52" Rear Projection Television
I'm having difficulities with a RCA entertainment series television. A little while ago my T.V started going crazy. For example, Sometimes when i go to turn it on to change the channel it will say panel...
Best Way reset the set,U right it well reboot itself,before u go to sleep unplug the tv,take out the bateries to remote.Morning,plug in and put the bateris back might reset it self.
Aug 17, 2009 | RCA 32F531T 32" TV
RCA model DRC8335 Loosing the date and time
That will be a problem from the text side of the broadcast, the clock is set from the text transmission, ( in other words a problem from the transmitter ) possibly due to digital switchover or work on the transmitters. One possible solution would be to turn off auto clock setting, and/or auto summer time adjustment.
May 16, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Rca P52921 52 in. projection made apopping noise
sounds like possibly the high voltage amplifier' just a guesas
May 08, 2009 | RCA P52921 52" Rear Projection Television
Sudden channel changing,flipping off and on and channel searching
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Apr 21, 2017 | RCA F36649 36" TV
Channel keeps skipping on rca t.v
Problem with channel skipping has rectified itself. I simply unplugged the set and and started over with remote intructions on signal and channel setting. The tv was also turning itself off and on, this also has ceased. Thanks, hope I don't need you later.
Nov 24, 2008 | RCA Universal Remote Control
RCA p52921
You will need to connect your antenna and do an auto search. When the search is over you might have to choose the broadcast option over the cable selection. That might bring in the picture.
Jul 21, 2008 | RCA P52921 52" Rear Projection Television
56" RCA projection TV
If you can find the horizontal output transistor which is located near the flyback transformer,one lead of this drive transformer is connected to the base lead. (horizontal output transistor). There may be a little coil in series with this lead going to the transistor.
Jan 17, 2007 | RCA P52921 52" Rear Projection Television
RCA P52921 52" Rear Projection Television Logo
160 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
