Audio: hearing everything twice
When I have my JVC home theater turned on and my volume turned up on my Samsung TV the sound does not come out of each at the same time. The TV sound comes out about a half second before JVC home theater system,so I hear every thing twice. Others have told me to mute the TV and just use the home theater. Is there really no way to fix this?
  • 1 more comment
  • helpme1823 Apr 01, 2008
    I have a TH-D50 and I do not see any thing called a delay time in the settings or the manual. Also not sure what DSP is and do not see a reference to it in the manual. Thank you for your help
    I did find a Delay setting. It lists all the speakers and has an adjustment beside it. All were set to 0 oms. The center speaker is the one that sounds like it is off or echo like. I changed it to different settings like 1 oms, 3 oms, 6 oms. I could tell each sounded different, but couldn't really tell that one was right. Sounded like there was an echo no matter where I set the oms. Thank you for the help
  • gcsm33 Mar 22, 2009
    I have the th-d60 and a panasonic 50 inch tv and I too get the exact same issue. I called JVC and they said this is the way it it.. I had a sony HT, and it did not do this.. I am disappointed cuz I like to hear the full sound of surround and tv.. cuz it seem a lot richer.
DSP is digital sound processing used for home theaters. i was hoping you have t]like this thing that's why you are experiencing delay. you must be having that though because there's no reason why your sound should be delayed.
Posted on Apr 01, 2008
    Novelist:
    Champion:
  • 236 Answers
You have a delay time on your home theater JVC, that is normal. So it's either you reduce the delay time of your JVC or do not use the TV sound. Set the delay time of your DSP so you can heqar the sound you wish... like the delay time of your surrond.
Posted on Mar 31, 2008
Getting tv sound from home theater speakers
Connect your sound from the cable box out to the JVC theater audio in jacks. This will give you sound through the speakers.
Jan 29, 2014 | JVC TH-C50 System
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
How do i hook up my tv to the sound system so i can hear regular tv through the speakers? I can hear it when i play a dvd but not regular tv shows.
The simplest way would be to run RCA cables from your Cable Box analog audio out (if THAT is where your TV programming comes from) to the available Audio In on the JVC. Page 9.
If the cable box has coaxial or optical digital audio OUT, run THAT (instead of the analog audio) to the correct Digital In connector. Page 8 and 9
This would free up the analog audio from the cable box to send directly to the TV's audio input for causal programming, like news, so you wouldn't need the JVC on.
http://www.retrevo.com/s/JVC-TH-D60-Home-Theater-Systems-review-manual/id/2771ag518/t/1-2/
Feb 07, 2011 | JVC THD-60 System
Cannot get home theatre to work with panasonic flat screen. Surround sound was working with old tv got a new one but now its not working. Do i need a different cable
your new tv probalby has an hdmi output. depeding on how old your jvc system is, iit may or may not have an hdmi input. not to worry, there should be some type of compatible output on the tv to send audio signal to the jvc. first look at the back of the jvc and see whats there. then look at the tv and you should see compatible output on tv and run proper cable to input on jvc. some auxillary audio outputs on the tv are driven by the volume of the tv itself, so make sure to turn the volume on the tv up a llittle to make sure its sending signal. you may have to go into the tv menu and turn the internal tv speakers off so you dont hear them and the jvc. its not a big deal if your hearing both, it just wont be true surrond sound. if it were mine, id turn the tv speakers off.
Dec 24, 2010 | JVC TH-C40 System
I just bought a Samsung HD LCD 32 in TV and want to play it through my Home Theatre System. I set the TV to external speakers, put the HTS in aux mode, but I don't get sound. My old Samsung SDTV would...
If you do not have a manual for the machine down load one at http://www.samsung.com/us/support/downloads/LN32B460B2D
It will show you how to set up a Home Theater Connection
Connecting an Amplifier / DVD Home Theater
TV Rear Panel
1 Audio Cable (Not supplied)
Amplifier/DVD Home Theater
1 Connect Audio Cables between the
AUDIO OUT [R-AUDIO-L] jacks on
the TV and Audio Input jacks on the
Amplifier / DVD Home Theater.
When an audio amplifier is connected
to the AUDIO OUT [R-AUDIO-L]
jacks: Decrease the volume of the TV
and adjust the volume level with the
Amplifier's volume control.
Each Amplifier/DVD Home Theater has
a different back panel configuration.
When connecting an Amplifier/DVD
Home Theater, match the color of the
connection terminal to the cable.
Nov 29, 2010 | Samsung LN32B460 32 in. LCD HDTV
Compatibility fo TV and Sound system
TV has audio outputs, the RCA cable type. If you connect the audio output (red,white) from the TV(look on the back), and connect the RCA cable to Input of home theater system,you should get TV sound from home theater system. You may have to set the audio on the TV for external source. Go to menu, to audio setup, to options. On the Home Theater system, you may have to select the audio source, i.e. audio input 1, etc.
Aug 09, 2009 | Samsung Theater System
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
Connecting samsung home theater to samsung lcd tv and direct tv
Need to get more granular on this, Does the volume work HT remote, for like radio, cd, ipod audio? For you to use the tv audio through the HTB the tv's audio settings should be on the "fixed" output option. This gives a line level to the Amp independant of the tvs volume adhjustment. Otherwise you will need to adjust tvs volume 75% or so before the audio amp will reproduce a good volume. Turn down audio amp prior to making any adjustments. Let me know thx
Nov 23, 2008 | Samsung SCH-a650
Surround sound and TV sound
Not by just pressing a button the Home Theatre no , I have the same problem on my Panasonic system - and I just mute the TV.
Mar 28, 2008 | JVC GL-M2915SG, Short Focus Manual Shift...
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
294 people viewed this question
 Grubhead
Grubhead
