Question about Garden
Need replacement high pressure hose for Alto 30CA Compact I
High pressure hose on our Alto 30CA Compact I power washer has sprung a leak in the middle of the hose. Looking for a u.s. Source for a replacement high pressure hose. Can anyone help?
CRTN
  • 716 Answers
SOURCE: High pressure hose connection blew up. Fix? or buy new?
Yes take it to napa auto parts and they can cut and attach a new end which are for hydraulics. They are crimped on and meant to hold very very high pressure. I used to use a pressure washer everyday for a living and it was a tractor rental/repair shop and we used the hydraulic fitting machine on the power washer hose all the time so rest assured.
Posted on Mar 11, 2009
  • 306 Answers
SOURCE: no high pressure no leaks motor runs off and on when trigger is released
check filter in wand and clean out nozzle hole for starters
Posted on May 04, 2009
  • 72 Answers
SOURCE: Cant change the high pressure hose on a Karcher
On the Kärcher, you have a bayonet mount at the base of the tip end of the pistol grip. This is where you attach different types of nozzles and gadgets after having removed the existing sprayer tube. Just push in and turn a quarter of a turn, then you pull it off the pistol grip. The hose is possible to remove from the machine as well, an ordinary threaded mount but since you need the pistol grip to regulate on/off this is probably not what you want to do. If the telescopic wand is made by Kärcher it should be very easy to snap it into place just like when you removed the sprayer tube/nozzle. If the attachment was made to fit Alto washers there is an inexpensive adapter that works very well. Good luck!
Posted on Jun 03, 2009
  • 32 Answers
SOURCE: high pressure hose. How do you get if off the karcher k 3.99
Hi, you have a little black clip in the gun hand where the hose pushes in, just pull it out and the the hose will pullout.
Posted on Jul 04, 2009
  • 114 Answers
SOURCE: can thee hose be fixed if it has a leak.
If the leak is on the OUTBOUND side that is towards the Nozzle, it CAN be repaired but for safety I would strongly recommend a new hose. Main reason being that the pressure generated in that hose will blow MOST joints you put in there.
If it is the input side then just get a hose joiner and install it.
Posted on Feb 07, 2010
Burned through the hose, repairs?
With the high pressure that these units produce, I would recommend replacing the hose instead of repair just for a simple matter of safety.
Feb 12, 2013 | Craftsman 2700 PSI Briggs Stratton...
Car is leaking power steering fluid can u give me the diagram for the high pressure power steering line
We do not have a diagram but follow the high pressure hose from the PS pump to the steering gear, clean it off with a pressure washer first and then you can id the leak which will be the high pressure hose I bet..
Sep 06, 2012 | 1996 Ford Contour
Power steering fluid leak back side engine in the middle of van
I just repaired a leak in my 1995 Windstar power steering system. The leak was toward the back of the engine but more toward the right (passenger side) of the car. There's not much clearance so I had to jack the front end up just to be able to look underneath. In my case the rubber hose had come off the metal tubing portion of the high pressure hose near the right wheel.
Fortunately, it had a screw type hose clamp, and barely enough working room, that allowed me to reinstall and tighten without having to remove the hose assembly. Yours sounds like there may be a break in the metal tubing, in which case the hose assembly would probably need to be replaced. Hopefully not.
Another thing that may come into play is whether the leak is on the high pressure side or the low pressure side. It seems that the high pressure hose assembly is long and winds in and around the engine. Probably a real dog to replace. Bottom line is you need to locate the leak and that will determine which hose it is and whether you need to replace or not.
I realize that this question is a few months old and has probably been corrected by now but, for others who may experience similar difficulties, have confidence, power steering systems aren't all that complicated and, usually, are not too difficult to repair. Hope this helps. - David
Oct 10, 2010 | 1995 Ford Windstar
Hi I have an Alto Force and it it has simply stopped operating. Fused changed etc but still no luck.
Try the machine without the high pressure hose on. if that fails you will need to check that you have power to the switch on the machine.
May 21, 2010 | Garden
Can thee hose be fixed if it has a leak.
Feb 07, 2010 | Karcher Hose Reel
Inadequate pressure from my Alto pressure washer
Clean out spay head nozzle with small diameter wire and check that head is pulled or push in or out for high pressure.
Jul 28, 2009 | Garden
Jun 03, 2009 | Karcher G 2600 VH Gas Pressure Washer
Honda crv high pressure steering hose leaking
You need a line wrench or a crow's foot. Power steering lines are hard to deal with. The fittings are fine thread and hard to start.You can cross thread them easly.be carful.
Apr 02, 2009 | 2004 Honda CR-V
Karcher/Winner 11 - motor pulses when hose is not operating
Hi, I had the same problem, Replaced the O rings and the rubber seals and cups inside the pressure washer and eventually the hose itself burst. Turns out the hose was leaking, internally between the inner sheath and the outside plastic cover, for quite some time and this caused the pulse. New hose and pressure cleaner is as good as new.
Mar 15, 2009 | Karcher K2.26 Electric Power Washer
Have a Alto Active x tra High pressure washer and it keeps contantly pulsating have followed instructions for trouble shooting but does not cure it. any Ideas.
have you bled the air out of the supply hose could be an airlock.
leave power off and pull trigger until no more air comes out of nozzle then turn power back on
Jul 14, 2008 | Washing Machines
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
