Question about Refrigerators
Ice maker pump
I have a Kenmore Coldspot Model 106.72862101. I recently had the ice maker replaced and now the trays are no longer filling with water. I called the people that put the ice maker in and they said that the pumps sometimes go bad after a new ice maker is installed. They said they could replace it for $154.00 parts and labor. I found my refrigerator on Sears Parts Direct and it appears the part they refer to as the Valve Solenoid is the same as the pump. Can you tell me if I'm correct before I order the part? Also, can I replace this myself if I'm far less than a plumber?
Thanks,
RSmith
    President:
  • Refrigerators Master
  • 2,651 Answers
That sounds like a company thats not willing to back there work if you ask me. Im to assume that there ws no ice before replacing the ice maker correct. and if thats the case , then perhaps the water valve was bad all along and you didnt need a ice maker.
Posted on Mar 30, 2008
Kenmore coldspot model 105-56532400 ice maker leaking water. How to fix?
The water supply solenoid valve may be malfunctioning or the fill tube to the icemaker may be mis-positioned.
Mar 01, 2015 | Kenmore Refrigerators
I have a Kenmore side by side, model # 106.57032601 that I bought 4 years ago. The ice maker suddenly quit working. The refigerator/freezer work fine otherwise and I continue to have water from the...
Is your ice tray filling with water? If not, then I would suspect the water inlet valve (http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657032601/0582/0165000/K0607002/00012?blt=06&prst=0&shdMod=10657032601 - Item 10)
If it does fill with water, but does not eject the ice cubes to start a new cycle, I would suspect the ice maker motor(Item 37). BUT if it is the motor, that part costs $91.22 and you can replace the entire ice maker (Item 100) for $157.95
Jul 10, 2011 | Kenmore Refrigerators
Kenmore Coldspot Model 57577791 S/S Ice Maker Problem
Probably the solenoid (electric valve that opens when the ice maker calls for water ) is leaking and has to be replaced (it's a very common problem ) . To be sure the solenoid is the problem , turn off the ice maker by raising the arm up , and check after a few hours if is any water in the ice tray , if yes the solenoid is leaking , if not , the ice maker control board has a problem , and to replaced it will cost you almost as a new ice maker.
Oct 19, 2009 | Freezers
Kenmore coldspot top freezer auto ice maker, water
Dear customer,
               We suggest u to perform the following checks to solve ur problem...
  1. Check the refrigerator for level
  2. Check the ice maker for level
  3. Inspect the fill cup alignment
  4. Inspect the water supply line
  5. Test the water inlet switch
  6. Test the water inlet valve
  7. Check the shutoff arm
  8. Test the shutoff switch
thank you..
Apr 08, 2009 | Kenmore Refrigerators
I have a coldspot kenmore
Tim,
At first blush it sounds like the water valve that supplies water to the ice maker is sticking or leaking and letting too much water in.
If you can, watch how much water fills into the ice maker tray (very boring stuff). If it overfills the icemaker tray, then the water valve or timer is malfunctioning and needs repair or replacement.
Apr 08, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kemore coldspot no ice?
no you ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Mar 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
I have a kenmore coldspot side by side model # 106.53662300.
The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
Jan 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker won't make ice
The ice maker tells the water valve when to send the water on up. Replace the ice maker! goodluck!!!
Dec 16, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
Dec 08, 2007 | Refrigerators
Refrigerators Logo
151 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
