Question about IBM ThinkPad 600 E Notebook
CMOS Can you please tell me what a CMOS is? sorry if i sound unknowledgeable about this. THanks
  • 1 more comment
  • dimplesmed Apr 08, 2008
    I tried F1,F2 or the delete button and still have these problems. When i do hit either one the numbers 301 comes up and still has same issues. Thanks
  • dimplesmed Apr 09, 2008
    I have IBM thinkpad 600X. As soon as i turn on my laptop it gives error message 161 and 163 then a screen pops up saying ERROR.. i have to either push ok or ignore . If i do either then i get to another screen that says OFF / ON i can't do anything really but i hit tab button 3 x then i have to turn it on. When i turn it back on for the most part it will start up windows.
  • dimplesmed Jun 19, 2008
    I am thinking of just crashing the laptop and just reload windows xp.
    Do you know how i can crash it?
  • 98 Answers
Complementary Metal Oxide Semiconductor (BIOS)
CMOS setup is the settings, for the motherboard, you get into before the PC boots into windows.
Usually by pressing F1, F2, or Delete during system startup.
Posted on Apr 02, 2008
P4P800 - VM BIOS Version 1012 to Upgrade 1018 Now CMOS can't save Date & Time
I'm sorry to have to say this but your CMOS battery connection is bad. There is basically nothing you can do other than replace the whole motherboard if it is too much of a problem.
One of my many computers is like this as well. I'm lucky in that as long as I leave that computer plugged in (it doesn't need to be turned on just plugged in), the CMOS won't reset its self. If you aren't that lucky then I would seek out a replacement motherboard.
Jun 18, 2012 | ASUS P4P800-VM Motherboard
Hello Im new here so please forgive me if i sound unknowledgeable. I have a Compaq Evo N620c and i finally got it to connect to the internet. After it was connected it started installing updates. After...
As far as the computer world is concerned we are all unknowledgeable to some degree - but you described the problem accurately and gave correct information that is the first step to get help. I am unable to suggest a solution but maybe you can post your problem on this hp help forum or seek a solution already there.
http://h30499.www3.hp.com/t5/Notebook-HP-ProBook-Compaq-Slate/bd-p/bsc-274
If this computer has a CD (for XP) or DVD (for Vista and Win 7) and you have the installation disc you can try a system repair by starting to re-install, and when asked press R for repair (not install- that may delete your data). For that better study more about the correct steps for your system and operating system.
Feb 09, 2011 | HP Compaq Evo n620c Notebook
It looks like something behind my rear wheel is broken; the part the brake pad is attached to; either that part or behind that part something is broken causing the wheel to wabble like its about to fall...
Sounds like a wheel bearing. If you jack up that side of the car and the wheel flops around than the bearing is bad. It is not uncommon for these vehicles. They usually start to make a lot of noise before they get that sloppy.
The bearing is a bolt in style and as long as you have a basic set of tools, a socket to fit the axle nut, and a 1/2" torque wrench to torque the axle nut on the new bearing, it is a pretty easy job to do.
Dec 07, 2010 | 2002 Pontiac Aztek
My intel dg31pr motherboard is not diplaying any thing and when i take the ram out from motherboard it not sound any beep please help me and tell me what the solution of this problem please please help me....
Refer to your manual and clear CMOS settings also replace your CMOS "coin sized" battery before clearing CMOS with a new one.
looks like your motherboard or processor can be faulty
Nov 21, 2010 | Intel DG31PR Motherboard
My Vizio 47'' LCD TV is not as bright as it has been. There is a hissing noise coming from the TV (not the speakers). Is there any help?
the help should be of the professional type as this sounds very much like a High tension lead leak
leave it OFF till you can have it looked at.
Killer voltages here and not to be touched by the unknowledgable
Please rate my help++++Thankis for using FIXYA
May 21, 2010 | Vizio SV470XVT 47 in. LCD TV
Intel 102ggc:The Firmware has detected that Cmos Checksum Error
Hi there.
Basically you first bios update was bad, if you can get into the operating system re-flash the bios again, that will sort it out.
Good luck and thanks for choosing FixYa!!
Jun 02, 2009 | Microsoft Windows XP Professional Upgrade...
My computer has a problem with card sound inside mother board.
Disable the onboard sound car in cmos , then plug in a pci slot fitting sound card, reboot, windows will report new hardware found, load the drivers, restart for changes to take effect, job done.
Nov 16, 2008 | Computers & Internet
CMOS BATTERY
Check out this link and you will find the steps with pictures showing a CMOS battery replacement.
http://www.liverepair.com/encyclopedia/articles/cmosreplace.asp
I am sure that this would help you change your comps battery.
Sammy.
Dec 05, 2007 | Samsung V20 XVC 2400 Notebook
No display
The first thing to try, is to look on the motherboard for the CLRCMOS2 terminal pins, this allows you to clear the data in CMOS. The data in CMOS includes system setup information such as system password, date, time, and system setup parameters. To clear and reset the system parameters to default setup, please turn off the computer and unplug the power cord from the power supply. After waiting for 15 seconds, use a jumper cap to short the Clear CMOS jumper for 5 seconds. After shorting the Clear CMOS jumper, remove the jumper cap. If you have changed the ram make sure it's compatable, but if the above has
Jun 12, 2007 | Asrock K8Upgrade-VM800 Motherboard
IBM ThinkPad 600 E Notebook Logo
75 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
